Motorcycles Logo
Anonymous Posted on Jan 14, 2013
Yamaha fazer fzs 03, keeps cutting out when i turn lights on or press brakes
Battery is fine and the bike idles fine but lights and pressing the brakes keeps cutting the engine out
Anonymous
Level 2:
  • Expert 314 Answers
  • Posted on Jan 14, 2013
Anonymous
Expert
Level 2:
Answers
314
Questions
0
Helped
93788
Points
909
Yamaha Fazer Brakes, Weight and Fuel Capacity
  • The 1998 Fazer has dual-disc front brakes and single-disc rear brakes. It has a seat height of 31.1 inches at its lowest setting and a dry weight totaling 416.7 lbs. The Fazer has and electric starter and a fuel capacity of 4.75 gallons.
2 Related Answers
Anonymous
  • 642 Answers
  • Posted on Aug 02, 2010
SOURCE: Break light and number plate light stuck on!
There are 2 switches that activate the brake light. One in the RH handlebar and the other on the rear brake pedal. The rear is activated by a spring connected to the brake pedal. Unhook the spring and see if the light goes out. If it does the unit can be adjusted by screwing the switch further toward the brake pedal (Turning clockwise)but you will have to undo the lock nut first. What usually happens is that the rear brake pedal return spring gets worn out and the pedal starts to droop slightly thereby activating the brake light switch.
To check the front switch. Disconnect th RH handlebar wire harness behind the headlight.(just follow the wires from the handle to their connector. Repair of the switch is rarely succesfull, replacement being your best bet.
Anonymous
  • 8909 Answers
  • Posted on Mar 01, 2011
SOURCE: Click, click, click, click, click etc, etc !!!!!!
Could be a faulty starter motor. I would check the power to the motor when you try to start it.
Hope that helps.
Hi guys, my bike keeps cutting out if i put lights on or press the brakes front or rear. bike starts and idles fine. totally stumped and any help would be great
  1. Yamaha Fazer Engine and Transmission
    • The 1998 Fazer is powered by a four-stroke, 16-valve, in-line, four-cylinder engine with displacement measuring 36.55-cubic inches. This motor generates 95 horsepower at 11,500 rpm and 45.0 foot-pounds of torque at 9,500 rpm. It has a six-speed transmission and a liquid cooling system. The 1998 Fazer has a top speed of 139.8 mph.
    Yamaha Thundercat Engine and Transmission
    • The 1998 Thundercat is powered by a four-stroke, 16-valve, in-line, four-cylinder engine with a displacement of 36.55-cubic inches. It generates 100.00 horsepower at 11,500 rpm and 48.7 foot-pounds of torque at 9,500 rpm. The Thundercat has a six-speed transmission and a liquid cooling system.
    Yamaha Thundercat Brakes, Weight and Capacity
    • The Thundercat has dual-disc front brakes and single-disc rear brakes. It has a dry weight of 412.3 lbs. and a seat height of 31.3 inches at its lowest setting. The 1998 Thundercat has an electric starter, a 5.0-gallon fuel capacity and a top speed of 158.4 mph.
2003 Yamaha FZS 1000 Fazer will not start
I had the same thing happen and still can't figure it out
Break light and number plate light stuck on! My bike is a fzs 600 fazer on an '03 plate and yesterday I noticed that the brake light and numberplate light wont turn off when the ignition is on. All the...
1helpful
2answers
I have a '99 FZS Fazer 600, and it won't start. I've been having problems with the battery running down when riding with lights on, and I sometimes have to push start the bike. Now though, the bike cut out...
i had same problem turned out to be electrical issue check all your wiring connections under the seat and under your fuel tank and if there all fine try checking that your fuel pump motor is running mine wasnt because of damp on my wiring connectors. when you turn on the ignition the bike should click a few times and your fuel pump should come on look under your tank looks like this with 2 tubes running from your fuel tank http://cgi.ebay.co.uk/yamaha-fzs-600-fazer-00-fuel-pump_W0QQitemZ250559832283QQcmdZViewItem?rvr_id=&rvr_id=&cguid=6d2769071260a0e2048322d3fffcee00
this needs to be running or you will be riding the bike on gravity fed fuel and as soon as you open the bike up you will not get enough to the engine and will cut out hope this helps
Bike does not start
Hi, I would start by checking to be sure the battery has a good enough charge, if not then locate the starter relay and try jumping the two terminals on it and seeing if the bike will start that way if so then you will need to replace the starter relay. good luck
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
