Hotpoint Wf 546 , reduced creases and mini load flashing slow and on/off switch flashing fast
3 Suggested Answers
  • 53 Answers
SOURCE: hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Posted on Oct 26, 2009
  • 6277 Answers
SOURCE: i got the reduced creases
(same again!) Hi from retired Englishman in SW France,
Sorry but I do not know your particular machine's fault lights coding BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 19, 2011
Hotpoint WF541 problem
Technical Fault is Pressure switch jammed on empty: check switch & module... in laymans terms its either a blocked sump hose or faulty pressure switch/module
Mar 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf540 stopping on a rinse and spin and
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Error code on my Hotpoint Aquarius WF240
my hotpoint Aquarius wf340 when switch on 5 secs later on/off button flashing along with mini load lights. could u tell me the error codes for this machine?
Apr 04, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Reduce crease and mini load lights flashing on hotpoint wf541g. had pump failier and have replace with new on but still not pumping water out.
I have encountered a similar problem. The following lights were flashing on and off:
  • On/Off.
  • Reduced creases.
  • Mini Load.
I also found that previously one of the 'lifters' inside the drum had broken off and someone had tried to put it back in place and continued to use the washing machine. After a short period of time the above mentioned flashing lights began.
I first suspected the pump, but this was fine. I then disconnected the hose which connects the hole from the drum to the pump and I found a child's sock blocking the hose. I removed the obstruction, put it back together and the machine worked perfectly. I also replaced the lifter (apparently these break quite often) and the machine has been working perfectly ever since that day.
I hope this helps. Good luck.
Mar 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washing machine will not finish cycle and the reduced creases and the mini load buttons continuesly flash. Do you know how to solve this problem? My problem is same as earlier person identified sep 08. I...
Could be pressure switch jammed on empty, check pump for draining properly..
Select drain only and see if the water comes at a good rate, there are other problems that could the sequence of lights flashing that you are experiencing.
Dec 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Machine freezing with three lights flashing.
HI JOHNNYHEFF,
JUST GOT A NEW HOTPOINT STARTED TEST WASH ALL THE LIGHTS FLASHED SO SWITCHED OFF TRIED AGAIN NO JOY. TECHNICIAN COME OUT SAID THE CIRCUIT BOARD WAS GONE, NOT GOOD NEWS FOR YOU BUT THOUGHT I'D LET YOU KNOW!
Oct 23, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
