Question about Kenmore Dryers
My Kenmore dryer ticks constantly (runs fine)
Tick tick tick tick tick tick... constantly, when not running. Model 110.76922501
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Sounds like the timer running,put your ear to the timer dial to see
Posted on Jan 16, 2013
  • 1122 Answers
SOURCE: Kenmore 110.96588210 Electric Dryer
you can take the top panel back off and check the start button with omes meter,push button in you should get a reading,let button out no reading ,if it fails the test replace,let me know what you find
Posted on Sep 22, 2008
SOURCE: Kenmore dryer not running
I have a 29" Kenmore electric dryer. Apx 4 years old. It runs but is not heating. What do I need to do?
Posted on Aug 03, 2009
  • 30 Answers
SOURCE: dryer wont start
Sounds like your thermal fuse is open.
It is located behind the back panel.
It's short and skinny with two blue wires going to it.
Posted on Sep 02, 2009
  • 30 Answers
SOURCE: timer ticks, but dryer does not run
Sounds like door switch. Open door and push on door switch. you should here a clicking noise. If you can open the top of the dryer. put the 2 wires together of the door switch. Make sure it is unplugged when doing this. Make sure you use electrical tape when you put it together. Temp fix. Get a new switch
Posted on Oct 23, 2009
  • 523 Answers
SOURCE: very old dryer Kenmore model nbr 86180100.GETS HEATSUP SHUTS OFF
check the vent
Posted on Apr 25, 2010
Can someone please help me know how to open (un-screw) the dashboard of Maruti Alto car? (I am getting some constant noice from Dashboard side. Sounds like something inside is loose now, and that keep...
There are several models of the ALTO and the dash varies from one model to another.
You need to look for two mounting screws at the extreme ends , the fittings of the AC, system needs to be checked.
But to look for noise you can use a good inspection lamp to probe within , start or run the car with help as you observe and listen to find the noise. It can be a loose screw which can be taken out using a magnet or maybe if the speedo cable is loose.( old model)
Jun 16, 2011 | Suzuki Swift Cars & Trucks
The dryer makes a new noise now when the drum is turning. It is a steady "tick -- tick -- tick -- tick --etc" which is laid over the normal sounds of the motor, the turning drum, and the...
You have done a good job of isolating the noise. Sounds like you will have to replace your drive motor. Very likely a mechanical problem in your motor, that is not going to fix itself. If you continue to run your dryer with the noise coming from your motor, you run the risk of the motor burning out electrically and causing a fire or a shock hazard. It is unlikely that this will happen, but it is possible and thereby not worth the risk of getting shocked or having a fire. The Whirlpool Duet Dryer is the best dryer built, so it is worth replacing the motor. Good luck, Appliance Specialists
Dec 09, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My dryer wont start when I push the start button. You can hear the tick, tick when turn the timer on. Is it the start button or thermal fuse?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 22, 2010 | Dryers
About to purchase a 56 model, 2.8 crd limited xs - thing is its got 116K miles on the clock> Anything I should be wary of?
tick tick tick when cold
run like hell
have a mechanic do a code search for extra insurance
Jan 15, 2010 | 2004 Chrysler Voyager
Why does my dryer tick while running? not a car, my clothes dryer
Check ur oil level. Don't change a thing on the dryer if it's working
Oct 02, 2009 | 1989 Jeep Wrangler
Kenmore 70 series model 97576200
You have a bad thermal fuse , usually caused by lint blockage from the filter or vent hose .
Jul 06, 2009 | Kenmore 659 Electric Dryer
Ticking sound is the timer running--so it is not the problem unless a contact has failed or a wire has come loose.  Broken door switch, thermostat failed in open position, or clogged lint filter/exhaust vent/outlet would keep unit from running.  If you can hear the motor running but the drum is not turning then the drum belt is broken.
Jun 04, 2009 | Dryers
Ticking sound
hi try getting a service done make sure they use genuine toyota oil and filters
cheers
mark
May 30, 2008 | 2000 Toyota Celica
Dryers Logo
186 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
