Cannot access the internet with the password that was provided with the router and need to either make sure that I have the right password or change it.
  • 826 Answers
Which router model you are using??
If you know the default router password then you can reset the router(using hard reset ,just pressing the reset button 30 second then it will come default setting) and login using default username and password...
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Posted on Jan 15, 2013
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Posted on Aug 05, 2007
  • 116 Answers
SOURCE: Asks for IP address and password
Try reading the Quick Installationguide and see of that helps.
http://www.edimax.com/images/Image/QIG/Wireless/BR-6204Wg/BR-XXXX_QIG.zip
Posted on Jan 09, 2009
  • 93 Answers
SOURCE: Lost password for access to D-Link WBR 2310 wireless router
Hold reset button in the back of the router. If that doesn't fully reset it, unplug it, hold the reset button for about 10seconds and plug it back it with the reset button held in for a further 5-10 seconds, release. Then should be back to factory settings.
Posted on Mar 08, 2009
TH3xR34P3R
  • 4 Answers
SOURCE: need to know how to reset password so neighbors can"t access my internet
You might want to do a hard reset then do all the settings from scratch so you can set a system pass and a wifi pass for the network. use the 128 bit WEP setting.
Posted on May 07, 2009
  • 85 Answers
SOURCE: i have a linksys wrt54g v8 cant connect to
Try this:
To configure your router manually:
Reset the router - Hold the reset button of the router for 30 seconds then Unplug it for 10 seconds then turn it back On.
Just follow these simple steps:
Open a browswer window and type http://192.168.1.1 into the address bar and click on Go.
The log-in window will appear.
Skip user name and type admin (admin is the default password) as the password, and click OK.
Posted on Jan 01, 2010
How do i cHange ssid password on my computer
Looks like no one is going to jump on this one... The one reason I'd make the change is to block someone who has access to my network.
I don't advise the inexperienced administrator tackle this task either. However, you asked. The way you worded the question leads me to suspect you need some background too. I'll give you my best answer. Hang on!
A "Router" (wired or wireless) is the device that resides (electronically) between your Internet connected devices/computers/printers and the Internet. It was most likely installed by your Internet Service Provider. Computers (printers and other devices) connected to a router wirelessly (WiFi) need to know the name (SSID) and password (WEP WPA-PSK key) of the local wireless network (router). The name and key (password) is set at/on your router when it is first installed and can be changed by logging into the router as an administrator. Be advised once you change it on the router your computer(s) will be disconnected from the router and will be required to supply the new key to reconnect.
You didn't specify who your Internet Service Provider is or the manufacturer and model of your router so I can't be of specific help on exactly how to log into your router to make the change. You didn't specify your system's OS (Apple, PC Windows X, Lenux, etc). If you do not have the owner manual for your router get it before going any further. Get:
·Manufacturer and model info.
·Download the manual from web.
·Find, on your computer where you access the WiFi. On a PC:
A- "Right" click and "Open Network and Sharing Center" the "network Internet access" icon in the System Tray (Extreme lower right of Start Bar [where clock is at]) Usually the icon looks like a monitor. Once the "Network Sharing Center" is up:
B- Left click "See Full Map"
C- Once the map is displayed poise the mouse over the router's icon and it should give you it's address. It is usually 192.168.x.x (x= variable numbers). Make a note of the address. Accessing the router with a browser (such as I.E., Firefox, or Chrome) will require you know the router's administrator account and password. Enter the address where the "www.x.com address stuff is usually at.
D- Once you're in the router you can change the key. Make sure you enter it accurately. Once you've saved the changes you will be kicked out of the router.
E- Reconnect your computer with the new key by left click on the icon mentioned in "A" above.
NOTE: It is easy to lock yourself out of your own system. If you're not comfortable doing this call in a professional.
Good Luck
In His Grace
Elton
Mar 10, 2015 | Computers & Internet
I cannot reset my password
Im presuming its your internet connection password ?
Your Internet service provider (ISP) requires a username and password to access service features, including Internet and email.
Your ISP should provide this information when you set up your Internet service.
Typically, once you complete the setup and save the information, your router or modem transmits it behind the scenes when you try to access the Internet.
As a result, the username and password can be easily forgotten because they are not used daily.
If you reset your router or simply forget the password, gaining access to network resources and the Internet becomes a challenge.
Call your ISP's technical support department.
Many ISPs set a default username and password for their routers.
If you didn't change the username and password, your ISP can provide the original information.
Before you hang up, make sure the information is correct by entering it and trying to connect to the Internet.
If the information is incorrect and you still cannot get a connection, keep the information for later reference.
Call your router's manufacturer.
The manufacturer of your router sets a username and password prior to shipping the device to your ISP.
Look at the router for the contact information of the manufacturer.
Call their customer service or technical support department and ask for the default information.
Reset your router.
If you changed your router's username and password and cannot remember what you entered, you may have to reset the router.
Insert the resource CD into your computer's CD drive.
When the software installation program starts, search the screen for "Resources" or "Documentation" or "User Manual."
Click the documentation link and search the table of contents for resetting the router.
When you reset the router, the username and password return to the default set by your ISP or manufacturer.
Enter the information provided by your ISP or manufacturer.
Hope this helps.
Nov 15, 2012 | Computers & Internet
I want to connect to my home wifi but do not know the password to connect
the wifi password is usually on the bottom of the router, often the serial number. If not and your router was supplied by your internet provider then you will need to contact them for the password.
Apr 15, 2011 | Computers & Internet
We live in France. Use live box for Internet. Can we change to net gear router?
Yes you can change it with netgear router. For that configure your router with below method. You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. .Click on wireless and enabled it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Feb 17, 2011 | Computers & Internet
WHEN I HHOK UP MY ROUTER I LOSE CONNECTIVITY TO MY DEKTOP. ALL WIRES SRE CONNECTED PROPERLY
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Jan 12, 2011 | NetGear WGT624 Wireless Router
How do you set password?
By default you access a linksys router through its web browser at this link:
http://192.168.1.1
The router's default user name is admin
The default password is admin
If the default settings have been changed, then the access link and/or password might be different.
If you need to get into the settings to change the password as requested, you will have to know the password used or reset the router back to factory defaults to regain access.
If you decide to reset the router, this is done by using a pen or paperclip and pressing in the rest button located on the back edge (near the power plug) and holding it in for up to 60 seconds. Be fore-warned, that resetting your router WILL WIPE ALL SETTINGS and you will likely lose internet access until the settings are restored as required by your Internet Service Provider.
Nov 29, 2010 | Linksys Wireless-G Broadband Router
Not able to access internet through belkin F5D7230-4 router
1.the installation CD is important and can be obtain through the manufacturer. It has pertinent files that are necessary to communicate with the operating system and the hardware on the PC.
2.Call Belkin and get a replacement CD
Jul 03, 2010 | Belkin (F5D7230-4) Router (587009)
I am getting ready to switch from dial-up to satellite internet service, I have a Compaq Presario SR1730T and need to know what type of wireless router is best or will any wireless router be compatible????
Usually the internet service provider (even satellite) provides a modem/router to access the internet. This being said to purchase a wireless router must mean that you are going to "broadcast" your satellite internet throughout the house so that others in the house can access the internet.
In that case, no it doesn't really matter what kind of wireless router to buy. Just make sure you connect your satellite modem/router (what they send you) into the wireless router correctly. Also, make sure you put a password on that wireless router so that your neighbors or unknown persons do not gain access to your internet/computer.
Thanks.
Jun 16, 2010 | HP Compaq Presario SR1730T (EK467AV) PC...
D-Link DI-704
Depending on your service provider, you may have to access the router's settings in order for your router to "talk" to your cable modem. Your service provider may require login information or you may have to determine which type of service you are getting. You may have a static ip address from your provider or some other setting you may need to change within the router. Contact your service provider and have them advise you as to what service they are providing i.e. PPoa etc. You can access your router's settings by typing in 192.168.1.1 in the address bar of an internet explorer window. This should open a window prompting for a username and password. Both should be admin. If not then the password could be "password".
Good Luck
Jun 28, 2008 | D-Link DGL-4500 Wireless Router
How To Set Up PPPoE DSL Connections with a WRT55AG Router
STEP 1: Before You Begin In order to set up your Linksys Router, be sure to first have the following: 1. A Linksys Router. 2. A DSL modem. 3. A working computer that can be wired in directly to the router for initial configuration and testing. 4. Two (2) standard Ethernet network cables. Linksys Routers come with one (1) standard network cable that you can use. 5. The PPPoE DSL username and password assigned by your Internet Service Provider. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. STEP 2: Check Your Internet Connection Before installing your Linksys Router, it is important to first verify that you can successfully access the Internet by connecting directly to your modem (without your Linksys Router installed). 1. If you are connecting for the first time, follow the instructions provided by your provider to set up your modem and computer for online access. 2. Verify that you are able to access the Internet without any problems. If you are not able to get a connection, contact your Internet Service Provider for assistance. When you are able to access the Internet using your modem, continue to Step 3 and proceed with the installation of your Linksys Router. STEP 3: Connect the Hardware Follow these steps to connect your Linksys Router to your modem and computer. 1. Shut down your computer and unplug the power cords connected to your modem and Linksys Router if they are currently powered on. 2. Disconnect the network cable that connects to the back of your computer. 3. Connect the network cable that you just removed to the Internet port (or WAN port) located on the back of your Linksys Router. Your modem should now be connected to your Linksys Router. 4. Connect a second network cable back into your computer (into the same port that was disconnected in #2). 5. Connect the other end of the second network cable to one of the numbered ports located on the back of your Linksys Router (labeled 1, 2, 3, 4, etc.). Your computer should now be connected to your Linksys Router. The following diagram shows how your network should be connected. Verify that your connections are correct, and continue to the next step. 6. Plug the included power adapter into the router?s Power port. Then, plug the other end of the power adapter into a nearby electrical outlet to supply power to your router. 7. Turn on your computer. Do not turn on your modem at this time. Only your router and computer should be turned on for Step 4. STEP 4: Configure the Router Follow these steps to configure your Linksys Router. 1. On the computer that is connected to the Linksys Router, open a web browser such as Internet Explorer or Netscape. 2. Type http://192.168.1.1 into your browser?s Address or Location bar and click Go or press the [Enter] key on your keyboard. The IP address 192.168.1.1 is the default IP address of Linksys Routers. 3. A user name and password prompt will appear. Leave the user name field blank (empty), and type in admin (lowercase) for the password. The password admin is the default password of Linksys Routers. NOTE: The following username/password prompt screen will vary by operating system. 4. Once logged in, the router?s web-based Setup utility should load. In the section labeled Internet Connection Type, or WAN Connection Type depending on router model and firmware version, select the PPPoE option on the drop down list. Click here to view what an older Linksys router interface looks like. 5. Once PPPoE is selected, enter your PPPoE DSL username and password provided by your Internet Service Provider into the router?s User Name and Password fields. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. NOTE: Be sure to clear the ?Password? field before entering your account password. AOL USERS: Enter in your PPPoE username as screenname@aol.com. 6. If the Keep Alive option is not selected, be sure to select it instead of the ?Connect on Demand? option. The ?Keep Alive? option will ensure that your connection stays connected even when it is not in use. 7. Scroll down to the bottom of the page and click on the Save Settings, or Apply button depending on router model, to save your changes. OR 8. Once your changes are saved, you will be presented with a button to return or you will be returned to the previous page automatically. If prompted, press Continue to return to the router?s Setup page. 9. Close and exit the web browser. STEP 5: Power Cycle Follow these steps to power on and off your devices in the correct o
Feb 16, 2006 | Linksys WRT55AG Router
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
