Question about Sewing Machines
Manual for Bernina 910
Does anyone know where I can get a free download for this manual? BerninaUSA has the 930 manual (which is the same era) free for download but not this one.
  • 2 more comments
  • berniebalmy Jan 24, 2009
    thanks for the tip. At least they do have the correct manual but they want nearly $16 for it.
    Thank you Michelle, it's probably not very different from the 930 manual (which I do have) as Bernina repeats a lot of stuff (like sewing techniques, presser feet etc.) in every manual. If I could find someone who'd email me the vital pages, with specific directions for this model, that would be wonderful.
    I'll keep looking. I appreciate your time.
  • sdcentaur69
    sdcentaur69 Jan 05, 2013
    Here is a Link for a free download I got the PDF from Bernina and I will share it for freehttp://www.filedropper.com/910
  • tumorfarmer Mar 26, 2014
    Unfortunately, sdcentaur69 we have to pay to sign up for filedropper, even the free 7 day trial period requires a credit card or PayPal information, so I can't get it.
I have a Bernina 910 that I bought new years ago - love it. Please email me directly and I'll see if I can help with the information you need.
Posted on Jan 30, 2009
    Scholar:
  • 65 Answers
Try here
http://www.everysource.net/search.aspx?qrt5=sewing%20machine%20manuals
Posted on Jan 24, 2009
  • Michaelle
    Michaelle Jan 24, 2009
    oops you may want to try sewusa.com
  • Michaelle
    I looked around a bit more and couldnt find any free manuals for you, sorry.
Berninamatic 910 is frozen. Where can I find manuals so that I can service it?
Ken--
May be difficult to find for your machine because of its age.
Something may be close on this Bernina site (the 910 looks a lot like the 930 without the basting stitch, perhaps the needle up/down function, and fewer decorative stitches):
https://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/BERNINA-manuals/BERNINA-Sewing-Systems
BERNINA MATIC 910 ELECTRONIC SEWING MACHINE MANUAL CD
Most likely the machine has seized due to lack of fresh oil. The old oil has solidified and turned to glue and has stuck the moving parts together. Do not force it!
Remove the free-arm cover.
Open the top. (There is a metal peg on the top left with a screw slot in the center. Turn this screw 1/4 turn. Now lift the bobbin winder and you will see another METAL screw. Turn that 1/4 turn. Do NOT mess with the plastic screw unless you want to mess up the winder.) Now you can gently lift off the top. Pay particular attention how it fits as you will need to jimmy it a bit to get it back on without bending anything!!!
Now you can remove the cover on the left side over the needlebar.
Pick up a bottle of liquid Tri-Flow Synthetic Lube (hardware store or bike shop) with the small plastic tube dispenser. Gently rock the handwheel and apply a couple drops of Tri-Flow every place that metal rubs on metal. Do NOT oil the white nylon gears, the cams, or the belt!!! If you look closely, you will most likely see some small holes that are actually oil ports. There is a large one just on the inside of the case (left of the belt) that is part of the handwheel mechanism. This is probably where your problem exists. Do NOT over-oil or you'll be cleaning up oil for a long time and it could get into the electronics.
Work your way across the top of the machine. Be sure to move the stitch selector levers, the buttonhole knob, stitch width dial, etc and get oil into those metal mechanisms as well. There are 4 or 5 oil ports on the needlebar knuckles. Be sure to get those--one or two may be hidden so you'll need to rotate the handwheel and use the long tube to get to a couple. Oil the needlebar where it goes through the case, be sure to hit the presser foot lever mechanism.
Work your way down to the bobbin area. Be sure to get the oil port at the very back of the feed dogs next to the case (this is a very important one!). Get oil on all the metal moving parts and be sure to toggle the feed dog knob and get that mechanism too.
Now, take a handheld hairdryer and direct hot air into the internal mechanism of the machine. I've gotten the metal so warm it was difficult to touch. You may need to alternate between oil and heat, but if there is nothing mechanically wrong with your machine, this will get it running smoothly again. I've used this method on several seized mechanical Berninas and it has never failed unless a nylon gear is cracked or there is something else mechanically awry.
For sure, every time you start a project, apply a couple drops of oil where the hook and shuttle rub together (see the bottom photo below, the very bottom arrow on the left) or see page 45 of the Bernina 930 manual (Maintenance section).
Be sure to lube your machine often. Once you are familiar with the sound of a smooth-running machine, you will recognize by its sound when it needs some TLC. Other than that, plan to lightly oil every 40 hours of sewing. If in storage, every 6 months whether in use or not.
The photo below is actually a Bernina 830, but the mechanism is fairly similar to the 930/910.
Oct 09, 2016 | Sewing Machines
Free Sewing Machine Manuals bernina 1080 special computer sewing machine free manual
Go to the BerninaUSA web site and select Support. There are manuals there available for download. Perhaps your machine manual is there.
Nov 26, 2013 | Sewing Machines
How do I get a free copy of a Bernina 1008 user maual and a repair manual? soft copy or hard copy
You can download the manual in PDF format from www.berninausa.com
Feb 07, 2010 | Bernina 1008
My mother left me her Bernia (record/electronic) sewing machine, but there is no manuel. Does anyone know where I can get the manual for it?
Hi, well you must have been your moms favorite. I'm guessing the Bernina she left you was an Bernina 830 since I think this was the only electronic Record unless the 930 was also a Record electronic.
You have a wonderfull machine. You can find the manual you want here at Berninausa.com ... http://www.berninausa.com/news_detail-n486-i2238-sUS.html . Look for the model number on your machine and click on it. You can download the manual there for free.
Regards,
Rick
Oct 29, 2009 | Bernina Sewing Machines
Lost Bernina 1090 operating manual
Simple Can you get it on the Bernina web site? ask some one to copy theirs and you will play for the copying, You really cant expect it to be free $42 doesnt sound too bad considering how much info is in the book
Jun 21, 2009 | Bernina Sewing Machines
Where to oil mashine
Please do a Google search, the older manuals for the Bernina Artista are free to download as PDF file.
Feb 16, 2009 | Bernina Artista 180
Sewing Machines Logo
1,010 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
