Question about Delta T13422-SHC Chrome Classic Single Handle Monitor Pressure Balanced Tub
Dead spot water turns off - Delta T13422-SHC Chrome Classic Single Handle Monitor Pressure Balanced Tub
  • mbaker117
    mbaker117 Jan 16, 2013
    Turn the faucet half way on and the water stops. Turn it a bit more and the water turns back on.
What could be wrong,My pump wont turn on , it makes noise but wont kick on
open it up and see if the impeller will turn freely when it is disconnected from power. Call pool guy or pool store and see if it just needs a solenoid.
Sep 19, 2014 | Hayward 1.5 Hp Northstar High Performance...
Spot on screen
Do you mean dead pixels or a dirt spot ??
A dirt spot, use hot water on a soft cloth to clean it.
Dead pixels, you can try this, keep moving between screen and sometimes this will unstick bad pixels.
Go here, then click F11, now RT click mouse button as fast as your finger can. do it like 20 times.
Now click F11 on the page that shows the words dead pixel test.
If they are still there you will need to check your warranty and see how many the company allows before they will fix.
http://deadpixeltest.net/
Apr 13, 2013 | JVC JLC37BC3000 37 Class LCD HDTV - 1080p,...
My daughter sprayed round up on my lawn. How do I repair it?
Put a light layer of top soil on the dead spots and re-seed the areas. Make sure to water regularly.
Jul 09, 2012 | Roundup "" Weed & Grass Killer
I have a brown spot in the corner of the tv on the screen it almost looks like a water spot. Can this be repaired..
No,these problems are called a bruses or dead pictures pixels spots.These problems are only can causes by outer forces did some harm to the tv LCD screen panel itself.Sorry this problems can't be repair only can be replace like the whole LCD screen panel itself.Not pratical,save ur money buy a new tv.
Aug 31, 2011 | Protron PLTV-32 Television
Dead spot, no signal
Easiest fix is try another location in the house, unless the dead spot means no wireless signal any where. Then make sure the wireless is turned on in the router. Problem is really vague.
Nov 30, 2010 | 2wire (1000-400108-001) Router
The starter on my 97 gmc jimmy will start most of the time but sometimes when i turn the key over it clicks one time,when turning the key back and forth it might starts or just click , the volts on the...
Your description indicates a dead spot in the starter. When it does this and you keep turning the starter it moves past the dead spot and will start.This may require starter replacement.
Sep 09, 2010 | 1997 GMC Jimmy
My 2003 solara wouldn't start..I locked the wheel & it still would not start...when the key turned I heard a few clicks but would not start...waited about a 1/2 hour & it started..so far this has...
This means you have a dead spot on your starter. It will happen again probably when the starter stops on the dead spot in the future. If it does hit the starter with a mallet to move it off the dead spot then try the key to start it. Best of luck. Bro
Apr 04, 2010 | 2003 Toyota Camry Solara
Lg electric dryer has no power
Try to reach inside the dryer and turn the drum by hand, sometimes the motor has a dead spot and will not run...some times this helps to move the motor out of the dead spot
Sep 23, 2009 | LG DLE2514 Electric Dryer
1987 ford escort Gt hatchback 1.9 ltr engine doesn't start all the time some times it just clicks maybe solanoid. I push start it and it starts being a standard. When it turns over it turns over great....
Starter is beginning to fail. It has a dead spot or two and my luck of the draw you are occasionally ending up on the dead spot.
Plan to eventually replace the starter.
Hope that helps.
Apr 03, 2009 | 1987 Ford Escort
Delta T13422-SHC Chrome Classic Single Handle Monitor Pressure Balanced Tub Logo
63 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
