Question about Home
Bathtub spring stopper has no rocker arm or stopper. Where do I find the parts and instructions on how to install correctly.
  • 717 Answers
Your best solution for this is to contact a plumber or someone at a local plumbing wholesale store.
Rod
US Parts Center
888-521-6183
Posted on Feb 07, 2013
3 Suggested Answers
  • 127 Answers
SOURCE: drain stopper in the bathtub has come off how do
the stopper just sits in the hole. When you turn the knob the cable operates the piece that raises and lowers the drain plug. The weight of it and the suction of the water is what seals it....provided the o-ring is good on the plug.
Posted on Oct 18, 2009
SOURCE: How do I remove the
Does the tub have a lever to stop the drain below the spigot ?
Posted on Oct 28, 2010
Removing and installing rocker arm rods on a detroit diesel 6v71
Hi Edward , sounds not right , lol . You have to remove the whole Rocker shaft with it rockers before you can remove or replace the rocker arm rod .
May 02, 2016 | Cars & Trucks
Installed new oil pump and now have broken rocker arms
THe rocker arms are broken because there was not enough downward movement in the valves to allow the cam to complete its turn. IT happens when the valve spring retainer either hits the top of the valve guide or the valve springs are fully compressed forming a solid block . If you have hydraulic valve adjusters I would be suspicious of a lack of movement (seized) in the ones that broke the rocker arms
Feb 20, 2013 | Ford F-150 Cars & Trucks
Excessive lifter noise
Did you follow instructions for adjusting the valve lash? Normally, you take out all gap at the circular part of the cam and then go another half or three quaters turn.
Sep 01, 2017 | Chevrolet K2500 Cars & Trucks
I have a 1996 Buick lesabre with the 3.8 liter v6 motor. I just did a top end gasket set and need to know how to adjust the rocker arms. Can anyone help? I know I need to start on compression stroke to...
Fig. 7: Rocker arms and related components - 1991-99 VIN L engine and 1998-99 VIN 1 engine (click image for zoom)
  1. Clean the rocker arms and pedestal bolts in a suitable solution and inspect for wear. Make sure to clean all of the thread adhesive from the rocker arm pedestal bolts.
To install:
  1. If removed, install the pushrods and make sure they seat in the lifter.
On 1998-99 vehicles, the bolts rocker arm bolts are designed to permanently stretch when tightened. The correct part number fastener must be used to replace this type of fastener. Do NOT use a bolt which is stronger in this application. If the proper bolt is not used, the parts will not be tightened correctly, and part or system damage may occur.
  1. Apply a threadlocking compound to the bolt threads before reassembly.
  2. Install the pedestal and rocker arm assemblies, then tighten the retaining bolts as follows:
    1. 1988-92 vehicles: 28 ft. lbs. (18 Nm).
    2. 1991-98 vehicles: 19 ft. lbs. (29 Nm), plus an additional 90° with a torque angle meter.
    3. 1999-99 vehicles: 11 ft. lbs. (19 Nm), plus an additional 90° with a torque angle meter.
  3. Install the valve cover(s), as outlined earlier, then connect the negative battery cable.
  4. Start engine and check for fluid leaks and listen for valve train noise.
I hope this helps, and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment.
Have a nice day and thanks for using FixYa.
Jose.
Oct 17, 2011 | 1996 Buick LeSabre
I replaced the lifters in my 2000 galant 2.4 L and i need to know what to torque the rocker arm shafts to.
1.5 and 1.8 engines:
* Install the rocker arm and shaft assemblies. Tighten the rocker arm shaft retainer bolts to 23 ft. lbs. (32 Nm).
* Check valve adjustment and install the valve cover. Tighten the valve cover bolts to 16 inch lbs. (1.8 Nm) for the 1.5L engine or to 29 inch lbs. (3.3 Nm) for the 1.8L engine.
2.0 engine
* Lubricate the rocker shaft with clean engine oil and install the rockers and springs in their proper places.
* Install the rocker shaft assemblies on the engine. Tighten the bolts gradually and evenly to 21-25 ft. lbs. (29-35 Nm).
2.4 engine
Fig. Rocker arm shafts and components-2.4L engine
* Fit the rocker shaft springs from above and position them so that they are at right angles to the plug side. Install the rocker springs before installing the exhaust side rocker shaft and rocker arm assembly.
* Install the exhaust side rocker shaft assembly in the engine. Tighten the rocker shaft mounting bolts gradually and evenly to 23 ft. lbs. (32 Nm).
* Remove the lash adjuster retaining tools.
* Install the rocker cover and tighten the mounting bolts to 30 inch lbs. (3 Nm).
* Reinstall the spark plug wires to the spark plugs.
Hope helps.
Sep 06, 2010 | Mitsubishi Galant Cars & Trucks
Proper installation instructions for Rocker Arm Installation 1998 Dodge 5.9 360.
locate v8 on crankshaft damper(147 degrees ATDC). rotate engine until v8 lines up with TDC mark on timing cover. install rocker arm and pivot assemblies and torque to 21 ft. lbs. wait 5 minutes before starting vehicle to allow lifters to bleed down correctly
May 19, 2009 | 1998 Dodge Ram 1500 4WD
I need the installations for a American Standard
I had a similar problem where the Drain-Kit that I ordered was missing a part. After contacting American Standard and requesting a schematic. I realized that the missing part was the rocker assembly with stopper. I have a PDF of the schematic that I can send you if you still need it. Let me know. The alternative is to contact American Standard directly between 8am and 6pm Eastern and request the information. The phone number is (800) 442-1902 Option 3 then 1 then 2. Tell the person that you need the installation instructions for a 1583.470.xxx universal bath drain.
Mar 03, 2009 | American Standard Plumbing
Hyundai Excel Rear Supension 99-2000 model
SUSPENSION REASSEMBLY
1. Apply the specified grease to the inside of the left suspension.
2. Using special tools (09555-21100, 09555-21000), drive bushings, into the suspension arm.
CAUTION
1) Apply grease to all outside surfaces of bushings.
2) Drive bushing in until the notch on the special tool
(09555-21000) reaches the end of the suspension arm.
3. When replacing the dust cover, insert a new one up to the center position (stopper) of the right suspension arm.
4. After applying grease to the surface of the right suspension arm, install the rubber stopper.
5. Slowly push the right and left suspension arms together. Wipe away the surplus grease. Align the marks on the stabilizer bar and the stabilizer bar bracket.
6. Install the rubber bushings, fixtures and washers.
7. After aligning the fixtures with the suspension arms according to the alignment marks, loosely tighten the nuts.
CAUTION
1) Install the washers and fixtures in the correct direction
and position as shown.
2) Tighten the nut to specification with the vehicle lowered
to the floor.
8. Pack grease in the dust cover and lips, and secure the dust cover with the clamp.
Jun 21, 2008 | 1994 Hyundai Excel
Home Logo
57 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
