Question about Casio Exilim EX-S5 Digital Camera
Camera comes on, says card is locked
I've taken the battery and the memory card out and re inserted and it still says card is locked, can't take any pictures this way.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Jan 14, 2013
Konica minolta DiMage Z10 doesn't recognize sd card
Might one enquire how you have assessed the intelligence of the connecting lead ? I know of no definitive tests for this area of electronic equipment.
Mar 16, 2017 | Konica Minolta DiMAGE Z10 Digital Camera
Unable to view photos i have taken, Screen says Read Error
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
May 16, 2012 | Fuji FinePix Cameras
My Panasonic DMC-FZ20 says Memory Card Error.
Hi
Please check your cameras capability to support larger sized SD cards.It may not support those two SD cards.Also check for slide locks on the side of the cards and slide them to 'open' before inserting.
Hope it helps.Thanks!
Feb 18, 2012 | Panasonic Lumix DMC-FZ20 Digital Camera
Hi Sir My CANON A470 it shows memory card is locked & memory card error, most of the file are in it how should i retrieve it, i ve tried with new batteries also.My PC also doesn't support it
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Sep 17, 2011 | Canon PowerShot A470 Digital Camera
I've bought a new samsung pl121 camera & taken a
Your camera is obviously defective. It may have been a return and resold to you. In any case, you should return it immediately....this problem will only get worse.
Aug 20, 2011 | Samsung Cameras
Camper says internal memory is full and i have only taken 12 pics. i think there might be "protected" pics. but i don't even know how to protect pics or to un protect them.
Digital cameras that come with internal memory usually have a very small amount of storage capacity (usually 32 or 64MB). I'm not sure why the manufacturers even bother with internal storage when you can get memory cards that have much more capacity. You need to either download the photos you've taken to your PC and then delete the photos so you can take more shots, or you need to insert a memory card. Depending on your model of camera you need a microSD or SD card. Let me know the model number of the camera and I will tell you what you need to get.
Hope this helps!
Tom
Jul 21, 2011 | Kodak Cameras
How do I download my pictures from my Sony camera to the computer?
Here is one instructional video tutorial from Sony Support; also could try this procedure:
- Take off your memory stick from your camera and insert it into your memory stick adapter. Open your camera's battery case and gently push the memory stick until you hear a faint "click," then remove it from the camera. Place the memory stick inside the adapter that comes with your camera.
- Insert the adapter into your computer's memory card reader, if you have one. The adapter, which is larger than the memory stick itself, is approximately the same size as an ordinary SD memory card.
- Connect your Sony digital camera to your computer using its USB cable if you can't find or don't have a memory stick adapter. Insert the small end of the USB cable into the camera. Insert the wider, flatter end into one of your computer's USB ports.
- Click "Open Device to View Files" to open your memory stick or camera. Search for the DCIM folder and click on it. Navigate through any photo subdirectories you've created and highlight photos you want to transfer to your computer. Right-click anywhere in a given folder, then click "Copy." Go to the location where you want to store your images, then right-click within that folder. Click "Paste" to transfer your images.
Hope this helps (remember to rate and comment this answer).
Jul 03, 2011 | Cameras
I purchases a vivitar vivicam 8025. Unfortunately the instructions got thrown away. I've only taken a few pics and the camera says "memory full insert sd memory card to transfer and take more...
You can download the manual from the manufacturer's web site at
http://www.vivitar.com/files_products/13/VC8025%20User%20Manual.pdf
The camera needs a memory card in order to save pictures. You can take pictures without one and view them on the screen, but those pictures are lost when you turn the camera off.
Jun 16, 2011 | Vivitar ViviCam 8025 Digital Camera
My camera is giving me a "no memory card" sign, but the card is inserted correctly. I have taken it out, cleaned it, and put it back, replaced the batteries, and everything. However, to no avail....
If the camera displays Memory card error, No Memory Card, or takes an abnormally long time to write an image to the memory card, when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. For SD card, make sure that the card lock switch is in the correct position and not stuck in-between.Try formating the memory card ,if after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Mar 19, 2011 | Canon PowerShot S51S Digital Camera
Casio Exilim EX-S5 Digital Camera Logo
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
