Question about Whirlpool 24 in. GU3200XTP Built-in Dishwasher
Err 3 on Every Wash Cycle
On every wash cycle my dishwasher sounds the ERR3 the book says LONGER HEATING TIME NOT REACHING REQUIRED TEMPERTURE Can i fix this????
  • 38 Answers
Sounds like a bad heating element, or bad door switch, or bad heater relay. You need to buy a multi-meter if you don't have one to troubleshoot which component is bad. And yes you can fix this. Also make sure you have hot water going to the dishwasher.
Posted on Feb 23, 2009
Didhwasher taking longer up to 3 hr to complete regular wash
John: According to AcmeHowTo.com: When the cycle time is too long, "
  • Test the timer motor
  • Test the heating element
  • Test the thermostat"
  • May 21, 2015 | Dishwashers
    Stuck on washing cycle
    Thank you for your post, Patrick Chow!
    From my understanding your Frigidaire dishwasher is getting stuck in the washing cycle. Sounds like you may have a possible issue with a sensor or control panel. I would suggest performing a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for approximately ten minutes. If you continue to experience problems with you dishwasher not cycling I would recommend reaching out to a technician for a diagnosis to be completed. The technician would be able to pinpoint the cause of the failure and complete repairs. Hope this is helpful. -Matt
    Nov 17, 2014 | Frigidaire Washing Machines
    Drying light flashes after pre wash cycle
    check water temperture might be to low might turn the hot water temperture up, water temperture for best wash is 120 degree
    Dec 21, 2017 | Hotpoint 18 in. DC27 Slim-Line Built-in...
    Hobart LXIH stuck in Wash mode after running multiple loads. Shutting off breaker for several hours fixes problem until multiple loads have been run again and then it is once more stuck in Wash mode.
    How long does it stay in the wash cycle? Indefinitely? Does the display continuously show "WASH"?. If it stays in the wash cycle indefinitely (i.e. continuously shows "WASH" for significantly beyond approx. 3 minutes), it's probably a control board malfunction. If it continues to wash after the "WASH" indicator goes out, it could be a shorted wash motor relay on the relay board or a fauly control board.
    If the internal rinse water booster heater doesn't reach it's programmed setpoint temperature in time, the dishwasher will run an extended wash cycle to give the booster heater more time to finish heating the rinse water. If this is what's happening, the wash cycle would last approximately 3 minutes, then it would rinse regardless of whether the booster heater has finished heating or not.
    The booster temperature thermistor may be bad, giving a false booster temperature reading, causing an extended wash cycle as described above. The booster heater elements or contactor may be bad, preventing the booster heater from heating and reaching proper temperature, also causing the same extended wash cycle to give the booster more time to heat.
    Jan 06, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
    The dishwasher runs for 1 1/2 hours on the wash cycle.
    This may sound strange but that is a normal cycle time for today's dishwashers. They use much less water and the water is 'recycled' within the filtration system in the pump.
    By reusing and filtering this water they save on heating energy and water consumption. The motors are not as powerful so they use less power even when running longer. Many machines will alternate the wash between the upper and lower arms, this type uses much less water and energy but again the trade off is long cycle times.
    If you were to select a heavy or pots and pan cycle with hi temperature wash and a sani rinse your times can be up to 4 hours in some machines today.
    The reason behind these savings are mostly due to the energy standards that the appliance manufactures have to abide by today.
    I know this may not have been what you wanted to hear but it is how they work today.
    May 11, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
    Ariston LS 2020 taking more than two hours to go through cycle.
    Ariston and on and on...lol
    The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
    Apr 26, 2010 | Ariston Technologies Dishwashers
    Du1100xtpq7 has had the touch pad replaced along with the circuit board that goes behind it and yet it just keeps repeating the wash cycle and goes for hours
    i would guess that you are having a problem with the optical sensor inside the pump housing. it is suppose to sense when the water is clean or dirty and allow the unit to continue washing or advance to the next cycle.
    i have seen these test good but be just out of calibration enough to cause long run times.
    you can try to change it yourself or have the service company try that instead of a new board and panel.
    Jan 07, 2010 | Whirlpool 24 in. DU1100XTPS Built-in...
    Loud Buzzing Sound from Dishwasher
    have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
    Jul 30, 2009 | Dishwashers
    E3 - Non Release of Tablet
    The E3 code means - Longer heating time.Not reaching required temp. Cause - Malfunction of temp. sensor or heating element. Good luck !
    May 10, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
    Whirlpool 24 in. GU3200XTP Built-in Dishwasher Logo
    294 people viewed this question
    Top Whirlpool Dishwashers Experts
    Oloyede Monsuru
    Mike
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
