Question about Dell SE198WFP LCD Monitor
Power save mode, i dont know how to get out of it
  • 240 Answers
2 option disable it to display/LCD menu and windows power option under control panel
Posted on Mar 16, 2009
Gateway fpd 1530says
If you see a message box that says "Power Saving Mode" after pressing the power button, then it simply means that the monitor/display is not detecting the computer. Check the connection/cable between the display and the computer and make sure your computer is not in standby mode by moving your mouse.
From what you stated in your problem, you dont need a inverter or a bulb. If you have any image like the message box displayed then its working fine. It just isnt seeing any signal changes on the input and therefore goes into power saving mde. Try another cable or hook it up to a different computer to check the cable.
Oct 16, 2012 | Gateway FPD1530 15" Flat Panel LCD Monitor
Tip
Power saving mode officejet 6500 series
did you know that officejet 6500 series doesnt have any configuration about power saving mode (sleep mode).
it will turn to sleep mode after 1 hour.
if it is wireless, you need to turn off/on the product for you to use it again
on Mar 21, 2010 | Office Equipment & Supplies
Acer pc and lg monitor blank screen says power save mode on start up, anyone know how to fix this?
Actually during start-up there is a slight delay before the HDD & OS is detected by the CPU. Normally all monitors slip into power saving mode within 10 secs of inactivity of either mouse or keystroke. This inactivity is read by the monitor which promptly switches to power saving mode. However the moment the HDD LED starts blinking, the monitor wakes up & starts displaying. This power saving mode in most of the flat screens is only associated with movement of mouse or keypad. This does not register till the CPU starts up & thats why the monitor switches over to power saving mode till it starts receiving signal from the CPU.
It is a normal behaveour, so don't get worked up over it, plus you can always hit the Auto set feature on the monitor after booting the PC completely. ( I think the time out for the monitor to enter power saving mode is only 10 secs). Hope this helps.
Oct 08, 2012 | Computers & Internet
Gateway desktop enters power save mode while in use.
boot and adjust the power settings for all "when on A/C" to never. to take it out of power save press any key on the keyboard or press the power button (but dont hold it down)
Jul 08, 2012 | Gateway Computers & Internet
How do i turn off power save mode using the screen buttons
I don't know if there is a monitor with a function button to turn off the power save mode.
As far as I know the power save mode of the monitor can be found in the display setting of the windows..
Anyway... If you want to turn off the power save mode of the monitor via windows display setting then here is what you need to do:
On control panel, double click display settings.. click the screen saver tab... on the lower portion Press the "power" button.. Select power schemes tab.. Change the settings of" turn the monitor off" to "never"
Click apply and then OK..
Hope it gave you an idea..
Much appreciated if you rate this help...thanks..
Uncheck the box
May 19, 2010 | Dell E173FP 17" LCD Monitor
Every time i turn on my daewo monitor it saying "POWER SAVING MODE' then turn off power auto.
Hi this means your Monitor is in power saving mode , it is trying to save power when you dont use it, Change your power saving settings and it will work perfectly
Thanks
Dec 28, 2009 | Computers & Internet
LCD Flatron 21inch going into power save mode problem
this is not a problem with the monitor, it looks as your computer is not sending any video signals to the monitor thus it goes into saving mode. Take a look at the computer, check the video card. Pull it out then turn it on, turn it off again and place the video card where it should go then turn the PC on again. This should clue the OS to re-configure the video driver. Did you try another monitor ?
Jun 03, 2009 | LG 22" FLATRON LCD Monitor
Power save mode
I had the exact same problem but it is fine now! :) And this is how you solve it .....you press the power button (single press), and a series  of options come up...if you scroll down them you will come across a 'deactive power save mode' option, click select and this should sort it out!
Hope this helps! :)
Jan 15, 2009 | Nokia N96 Smartphone
Problem with powerup for my screen
Although you didn't list your operating system, I'm assuming it is Windows and offering a suggestion to clear up the issue based on that OS. Go to settings, and then to control panel. Once in control panel look for "power settings" and click on "custom". This will allow you to turn off all power saving modes by clicking "never" on when the screen is turned off or goes to sleep. If the issue is caused by the power saving mode, this will end the problem.
Apr 24, 2017 | Sony SDM-HS73 17" Flat Panel LCD Monitor
Dell SE198WFP LCD Monitor Logo
144 people viewed this question
Alun Cox
