Towels and Sheets all smell musty, have tried white vinegar, non-chlorine bleach, baking powder and cleaned all the seals. Nothing seems to work. I am tempted to use bleach, but machine says not to. Any suggestions?
SOURCE: Which dispenser to use?
usually you would use the rinse compartment but i would have thought the bottle would tell you
SOURCE: Bad Smell
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and remove out the bad smell. Good luck!
SOURCE: Laundry comes our gray and
Hi onemrsn
It soundsl like tehre is acouple of things going on. after a while detergent builds up inbetween the tubs and starts to come out. pick up POWDERED dishwasher detergent and runt 2 hand fulls on a HOT cycle with no cloths in it and cut back on the detergent , that should help.
brent
SOURCE: Bosch 3.81 cu ft Nexxt 500 Plus bleach not dispensing
We had the same problem with the bleach dispenser. It was under warranty so Lowe's sent a repairman that replaced some part in the control panel that he said was faulty on this model. He also said to only use 1-2 Tablespoons of HE detergent and leave the door open. Also dilute any softeners before adding them.
SOURCE: Cleaning agent placement
From left to right as you see.
1 This is for your frontloader soap powder or other detergent.
2 Fabric conditioner or softener. If this is too thick, mix with water to prevent clogging.
3 Detergent for soaking agent. I dont see 'bleach' anywhere
There is an panel, front bottom right which holds your pump filter, unscrew to clean out. But wait. Plug off the mains.
You will see a hose on the left, this is if your water in the tub cannot drain, you can drain it here. Your tub can hold upto 20 litres/4.4 gals.so have a suitable container to collect; carefully remove cap to drain out. Reason why it doesn't drain is because there is a block in your pump (right side) which you must clear.
To keep your pump from probs (a tip which you seldom see) empty all pockets of clothes before putting into machine. I have a non electronic Philco which i dont remember cleaning with hotwash or anything, 10years +
For exteriors do not use solvents or steel wool. Only hot soapy water with a mild non-abrasive cleaning agent, dry with soft towel.
Above should be useful. Pl rate.............
