Question about Desa International CBN30T Central Heating System Heater
Radiator cold in the middle - Desa International CBN30T Central Heating System Heater
  • Desa Interna... Master
  • 2,523 Answers
Rad needs taking off and flushing out , if more than 1 rad cold you may need a system flush
Posted on Jan 15, 2013
1990 toyota celica gargles and blows coolant as if overheating.
Bad radiator cap...new one should fix it if it is not overheating
Mar 01, 2014 | 1990 Toyota Celica
My 2004 Chrysler Sebring just started overheating. I started to notice I wasn't getting any heat, not sure if the two are connected. Then the gauge needle starts to adjust from middle to extremely hot. ...
first make sure you don't have white smoke coming out of tail pipe then check the radiator if it is cold after warmed up then you could go to the two main hose coming from the radiator be careful one could be hot follow the cold one ie water pump thermostat head gasket are as easy as a radiator cap good luck
Nov 02, 2013 | 2004 Chrysler Sebring
My temperature guage stays in the middle, is this ok?
Yes, the temperature gauge should normally stop in the middle, between the cold and hot points on the gauge. When the engine is cold the thermostat will be closed and will keep recirculating the coolant in the engine block until it warms up sufficiently. Then the temperature of the warm coolant will cause the thermostat to open the channel to the radiator to get rid of excess heat, which should stop the coolant from over heating. So the effect of the thermostat keeps the coolant at a fairly stable temperature. When the coolant runs low, it can't transfer enough heat to the radiator and the coolant and engine then over heats. Watch for radiator leaks under your car after you have been driving it. If the coolant goes low again fairly quickly you could have a leak in a hose or the radiator itself.
Apr 19, 2013 | 2003 Mazda Protege
Air pockets in radiator
Air can be purged. While your engine is cool remove radiator and reservoir caps. Place funnel in radiator. Turn heat to the highest position and start vehicle. Add coolant to radiator as needed while vehicle warms up. You should see bubbles coming out of radiator. Fill reservoir to between cold and hot fill lines. Replace caps when bubbling stops but before coolant temperature reaches normal operating temperature. Never remove the radiator cap until engine has fully cooled down.
Jan 15, 2013 | 2008 Nissan Frontier
Cold to hot
yes you could have air in the coolant system after replacing the hose. You need to bleed the coolant system.
Jul 19, 2012 | Cars & Trucks
Temperature gauge is always cold
For temperature gauge remain at cold problem,click the link below :---http://technoanswers.blogspot.in/2012/02/temperature-gauge-stays-at-cold-on.html
---------Thanks.
Feb 08, 2012 | 2004 Jaguar S Type
Temperature display flashes for about 2 minutes when pressed
try checking your thermostat. it is under the top hose that comes out of the radiator to the block. if it doesnt move when you try to compress the spring in the middle then that is your problem.
Mar 24, 2009 | 1994 Chevrolet Suburban
Open Questions:
Desa International CBN30T Central Heating System Heater Logo
Top Desa International Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
mcijoe
Level 1 Expert
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
