Question about Thermador Ovens
DIM DISPLAY ON THERMADOR RDFS30RS
DIM DISPLAY ON OVEN CONTROL CLOCK AND TIMER
  • 3 Answers
SOURCE: Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
Posted on Jul 10, 2009
Rotu
  • 175 Answers
SOURCE: Oven timer and temperature display dim
You need a new display/relay board package they have come up with to solve this problem. The parts generally run about $250, and if you have it repalced by a service company, the total will be a little less than $500. The display is really easy to change by itself, but you must change the realy board with it, and it has about 40 different wires going to it. If you draw a diagram as you take the wires off, and label them carefully, it isn't that hard to do the whole job..just take your time. This is a problem thermadore/dacor ovens have had for some time. If it isn't too old you may try calling thermadore and see if they are willing to at least buy you the parts, as this is a known problem. Good Luck!
Posted on Nov 24, 2006
  • 213 Answers
SOURCE: thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Posted on Nov 19, 2007
  • 6 Answers
SOURCE: Thermador SC301T oven
Thermador SC301T and SC302 stack ovens have a weakness in the radial capacitors on the circuit board behind the LED clock. They get cooked from heat. Here is the fix: Remove two screws from the control panel, located facing up at the bottom on the panel frame.. open the oven door to see them. The panel is then held in place by push in toggles at each end, pull towards you to remove. Carefully unplug the three wiring harness plug-ins, and check them to see if any wires are loose. Set the panel aside. Remove 3 screws holding in the LED assembly, and again unplug the wire harnesses, examining each for loose wires at the terminal. When unplugged, take the LED assembly to the bench, remove the plastic housing, and with a mini soldering iron and watchmaker's eyeglasses, or hobby magnifier,
identify, heat, and remove two 35v 450uf 105 degree radial capacitors, and one 35v 68uf 105 degree
capacitor. These are ordered from MCM Electronics (google it) and are p/ns 96K0326 and 96K0331.
Insert new parts, solder and clip excess leads. Carefully examine the printed circuit board around the area of the leads you just soldered, as some boards do not have the copper close enough to the hole to make contact. Scrape the green insulation from the conductor near the hole to expose copper and make sure your solder makes contact with the copper and the lead. Use your multi-tester when finished to check continuity from all leads you just soldered and their nearest neighboring contact on the circuit board. I found a loose wire on the harness to repair, and one contact on a capacitor did not have the copper close enough to make contact without extra effort. When all is completed, reassemble. Turn back on power at the circuit breaker. You may get an F7 error code. Off with the power again, wait 3 minutes. Restore power, go to oven and press the OFF position on the glass control panel... hold for 10 seconds, and the clock should now be steady at 12:00. Push clock position, reset clock for proper time. Test oven light on/off. Test bake/temp/convection buttons,
on/off. This is a good fix, and will save you about $469.00 in parts and $500.00 in labor. The new
105 degree centigrade high temperature radial capacitors replace old 85 degree, which fail, and your repair should last. Total parts and shipping costs.. about $10.00.
Posted on Mar 14, 2009
  • 114 Answers
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Posted on Mar 21, 2009
Thermador oven control panel light is very dim
FixYourBoard.com fixes this problem, and they back their work with a two year warranty!
See the photos of what your new display will look like below.
Feel free to ask questions-- info@fixyourboard.com
Apr 24, 2017 | Thermador Ovens
The control panel is very dim on my Thermador RDSS30 oven
Cannot Read Display or See Temperature Thermador RDDS30
FixYourBoard.com repairs this failure and back their work with a two year warranty.
May 14, 2011 | Thermador Ovens
F7 shows on display and display getting dimmer over months
Dim display is TOTALLY independent of F7 error.
The display will dim as the display board capacitors wear out - due to the heat. Replace the capacitors on the display board (see my other posts) and your be able to see the F7 error code as bright as can be!
Jul 16, 2009 | Thermador SC302T Electric Double Oven
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Dim LED on SC301 Thermador
local part whare house can sell you a "dim clock" kit for your machine i believe it contains a new display board as well new wire harness
Mar 14, 2009 | Thermador SC302T Electric Double Oven
Display light faded and now gone
Supposedly the electrolytic capacitors on the display board need to be replaced. See: http://applianceguru.com/forum1/18842.html
Jan 15, 2009 | Thermador SC302T Electric Double Oven
Lighting panel in my electric Thermadore double oven is dim.
The cap replacement worked....saving $250 (every 2 years !!!) I posted it on another site...now its making its way around the web....its the only value added thing I've done on the web (sadly!).
Nov 14, 2008 | Thermador SC302T Electric Double Oven
Thermador oven display is dimming
replace the capacitors on the display unit. Just did this and it now works
theblog
Nov 29, 2007 | Ovens
Thermador model sc272t oven 2 doors have dim display
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Thermador Display
Have 2 Thermador ovens, SMW272 and SC302. Both have display failure. Just repaired one with replacement display. It did not require a new control unit or harness. Have not opened up second unit yet as display is still dimly/slightly visible.
Called Thermador and received no offer of replacement parts or service. Numerous other web reports of similar failures. My neighbor has 2 dead ovens also unfixed because of outrageous repair estimates ($600 each). Do not recommend this brand.
Full kit including display, control, and harness ordered on Ebay for $170.
Sep 21, 2007 | Thermador SMW272 Electric Double Oven
Ovens Logo
129 people viewed this question
Top Thermador Ovens Experts
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
