Question about Eureka Vacuums
Where is the reset button on my eureka canister vac
Is there a reset button?
  • 91 Answers
With out knowing the model # i can't say for sure. however most of the eureka canister vacuum's ive worked on do not have a reset button. If its not working is probably the cord or switch that has gone bad. hope this helps
Posted on Jan 14, 2013
4 Suggested Answers
SOURCE: Electrolux Oxygen Canister Vac
Did you check the powerhead drive belt. Procedures for replacement are on the electrolux website and also in the owner's manual.
Posted on Jan 08, 2008
MATRIX_MMX
  • 209 Answers
SOURCE: eureka upright vac. no suction
Dear wymanwong
Righteo, your problem is not exactly all that straight forward as i dont have a great deal of information to go on with regards to this type of issue and this make/ model of vendored appliance, so I will begin by explaining how the typical vacumn cleaner functions (in relation to your issue) and what can cause a fault of this kind.
The vacumn cleaner overall (unless is a liquid cleaner as well as a conventional dry suction unit) has the function of providing suction into either a chamber or bag which is either filtered or emptied, and the effects of loosing suction usually are effected by faults within filters, or directly through the motor that is normally powered through 240V~ (AC) within the UK or
115~ (AC) USA. Suction can also be lost through blocked exhaust outlets through the vacumn unit and also through any perforations or tears to a bag/ container that is used in order to maintain constant suction and storage of particles/ vacumned waste.
Now to investigate the fault you have in regards to loss of suction within your unit.
Firstly You should query the suction motor and the copper windings as these are both electronic and mechanical components that can be affected not only by general wear and tear, but also by various ingressions (such as water and liquids). Also heat can play a major role here, as motors can spin up to a large amount of revolutions per minute (RPM) and this will cause heat build up, add this to the fact that the windings inside most electric motors are made of copper, and you can quite easily discover that the motor will "burn out" as copper will break down at somewhat lower temperatures than other electronic components (this is also more likely as the casing of a DC/ AC motor is contained within a steel structure which is a good store/ conductor of heat).
The other factor that should be considered with vacummn failures is also associated with exhaust impedances. In otherwords, if outlets and filter channels are blocked, then overloads through the motor wiill be likely and the entire system may cease altogether.
In addition to this, investigations of the power supply and any power transformers within the unit should also be queried, along with any rectifiers (used for converting an AC signal to a DC signal for use with DC motors if necessary), as faults with these can occour even over short periods of time.
If queriying these components have returned no results to the fault, then there is always the option of attaing the service sheets for your appliance from the manufacturer/ vendor of your appliance. The best thing to do in this case is either to go to http://www.google.com or to the website that is listed for your manufacturer/ vendor. Now if google if your option, then there are a few keywords which will assist in your search for your service sheets and they are to simply either type your appliance name followed by the words "service sheet" or "repair manual" In addition to this, you can always contact the manufacturer/ vendor of your appliance directly by telephone and delegate with them in order to request user manuals and servicing guidelines, and given the fact that you have a small appliance, if you mention that there is a possibility you would order any spare parts through them, then i really cannot see a reason why they would decline offering you the servicing guidelines/ manuals at a low cost.
Now there are other things here that can be investigated, but in order for me to dfo this i will need full details of your appliance model number and maufacture code, along with full details of the fault, as accurate as possible. Also photographs of either the machine or any/ all of the internal components will greatly help as direct visuals will aide not only in the identification of your make/ vendor model, but also may give a visual clue of what could be defective within your appliance (for example scortch marks on the wiring that supplies your vacumn motor etc) But any pictures supplied will need to be of a high resolution and quality.
Well I do hope that this brief explanation will provide enough information for a fixya or even a total unit overhaul in the most cost effective manner, in addition to this i do hope that i will hear from you in the somewhat near future as so i can find out more about your fault and indeed if you have managed to resolve it elsewhere (and even how this was done).
I am here most days and nights and any contact to and from me will ensure that I endeavour to resolve your technical issue in the most appropriate way for you.
In the meantime, i do hope you take care, and look forward to hearing from you soon
yours sincerely
Oz
Here on demand for all your technical needs
Posted on Apr 14, 2008
VacuumRepair
  • 438 Answers
SOURCE: I need to replace the belt on my eureka canister
Can you please specify the type of model that you have? The model that you listed this repair question under, the S3686 doesn't even have a belt on the vacuum cleaner. The model number can be found on the bottom of the vacuum on a sticker that also contains the serial number.
Please just use the clarification request form here on Fixya, and I will then even take some pictures on how you need replace the belt.
Posted on Apr 11, 2010
Where is the reset button the eureka the boss smart vac
There are many different models of Boss Smart vac so I can't say for sure without your model number but it most likely does not have a reset button. It may have a reset switch built into the motor.
Feb 26, 2017 | Eureka Vacuums
Sanitaire canister vac 1000 watts
The obvious answer is to reinstall or replace.
May 04, 2014 | Eureka Sanitaire S3686 Bagged Canister...
My Eureka Rally 2 Cannister Vac randomly stopped working
I am going to tell you this it is trash the motor went out buy a new one
Mar 26, 2014 | Eureka Rally 2 Canister Vacuum with...
Looking for carbon brush for motor for canister vacuum eureka 3684F
Try your local hardware or look under vac repair or electrical motor repair in your local yellow pages, my local hardware has a bunch of differnt motor rush sets .
Feb 17, 2012 | Vacuums
I need to replace the belt on my eureka canister vac. have the belt and screwdriver, now what? how to get the housing off? etc.
Apr 03, 2010 | Eureka Sanitaire S3686 Bagged Canister...
Something is stuck in my hose on the eureka boss smartvac, can i dtach plastic hose on side
yes, there are a few screws that need to come out to do so, u can also use a coat hanger to loosen it up and turn it on, the vac will **** the loose dirt into the bag/canister
Jul 14, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Broken canister latch
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=604237
Posted by nestara on May 17, 2008
The little plastic latch that holds the canister in place (the lower part that is recessed) is broken. I need to find a new part to replace it. I cannot seem to find one so far...most sites just offer replacement bags/filters....etc.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Sorry you are having a problem with the replacement parts for your vacuum but if you contact the Eureka Factory Service line of which I will list below, they will either supply you with the part or give you a contact factory dealer that will get you the part and also you may as for a schematic or and owner’s manual in order to see how to repair the part. If you have further questions, feel free to contact your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 17, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Nov 18, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
142 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
