Question about Fujitsu LifeBook S2020 Notebook
Do I have a burned motherboard?
My computer refuses to boot after my little bro left it on for some very long hours with multiple programs running. It just turned off with a snap, no error messages whatsoever. I took the whole thing apart and found some "I dont know what it is, looks like solder flux or burn marks". Could this be a burn? How can I fix this?
  • sam waiban Jul 09, 2007
    I had cleaned out all the dust with a camera lense cleaning brush and water. the fan was removed and clean throughly. still not boot. MB replace?
    Scholar:
  • 36 Answers
Yea it is probably toasted. I see it all the time. Many many people have toasted their laptops by not using them on a flat surface and covering the air intake. Others have thought they shut them down and put them into a laptop bag and let them cook for a few hours causing failure. Simply running many programs should not kill your laptop, unless it was prevented from breathing properly. This can also be worsened by a lack of maintainence. I can't even begin to describe the nasty things I have pulled out of laptops, the most common is little fluffy's pet hair clogging the intake or the exhaust. As far as your "burn marks" you are probably seeing normal soldering effects, slightly brownish flux that was burnt during the mfg process. I have only seen one board that was visibly burnt, and that laptop had smoke pouring out of it and smelled really really terrible. It is hard to tell but with experience believe it or not you can sniff the board and tell if it is toasted or not. Also bad RAM will keep some systems from booting. If the video is shared memory you will see nothing at all. If it doesn't it may halfway boot then shut off. I have had many laptops that will not post and replacing the dimm, or if there are two dimms try one, then the other. If that does not work its a toasted board bro sorry. Hack
Posted on Jul 09, 2007
SOURCE:
Cimballi m1 says boot 030
Download this file to your computer and burn it to a CD:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
If you don't have an app that can easily burn .iso files to a CD then get this awesome little FREE app and install it:
http://www.majorgeeks.com/downloadget.php?id=4870&file=9&evp=0636b68877cb69b15faa3374cb1dcd89
The Bootable CD you burn should fix your computer. It's really easy to use. Just follow the instructions from page 15 to page 33 in this pdf:
http://support.kaspersky.com/downloads/guides/kasp10.0_rescuedisk_en.pdf
You basically want to update the virus definitions and select all of the checkable boxes to scan and run the scan and then allow it to delete or quarantine the bad files. If you have any questions give me a call. It usually runs about twice as fast as a complete virus scan with a regular anti-virus program in windows so if that normally takes an hour then this will take 30 minutes.
Aug 26, 2012 | Computers & Internet
I have intel 101 Ggc Mother board and intel pentium D processor , i was using 756MB ram (512+ 256MB) RAM. But after i brought 1 GB ram and Used it instead of 256 MB Ram the system started restarting...
There is a chance that you have faulty RAM module. If computer is stable on POST (until Windows boot-up) I would suggest to use some testing tools to test that RAM with your motherboard. There is a good program called MemTest. You can find it online if you search Hirens Boot CD. Download it, burn image to disk, put 1GB RAM into motherboard, start-up PC and boot from CD. Then you'll search for Memtest program. I would suggest to leave PC for at least 6 hours for testing to find out if it's faulty or not (better to leave for 24 hours).
Aug 17, 2011 | Intel D101GGC Motherboard
I am trying to run multiple operating systems, from two separate hard drives. I have 2 operating systems on my SATA Hard Drive and one on an IDE hard drive. I can not get both hard drives to come up on my...
I am suspecting that you didn't change the jumpers on the back of the hard drive to master and slave ,but that is one of the things you have to do. Then your motherboard has to have the capacity to run a program called 'Raid' which is a multiple hard drive configuration which has five choices or methods for doing so,you might want to look into it a little further.
Mar 30, 2011 | ASUS Computers & Internet
Can not get it to turn on
Download Hiren Boot cd from http://www.torrentzap.com/torrent/622163/! (9Down.COM) Hiren's BootCD v10.0
Instruction on how to use it...
  • The disk is downloaded as an ISO file. The ISO files can be burned using software programs such as Nero. Burn the disk to a DVD instead of a CD by using a program such as IMGBurn.
  • Booting
  • Once the disk is burned, place it on a DVD or CD drive on the computer and restart the computer. After the computer displays its default first screen, the disk will scan and load the Hiren's Boot menu. The menu gives users three options. The options are to start the computer normally, load Mini Windows XP or load the disk. Choose the disk-loading option to work within the disk parameters and run in DOS. DOS is a simplified process that uses only text. The CD provides shortcuts to each utility.
  • Mini Windows XP
  • To clear a virus and use a large collection of Hiren's Boot tools, choose the Mini Windows XP option. A simple version of Windows XP will load on the computer. It might take a few minutes to load everything because it processes files directly from the CD. Once it has loaded, wait for the Hiren's Boot disk menu to pop up. Select the "Menu" option and scroll through the programs. The disk features Windows password hackers, registry cleaners and a large collection of antivirus software.
  • Antivirus
  • A main portion of the disk feature antivirus software. Spybot-Search and Destroy scans a computer for the most likely spyware and removes it. Malwarebytes Anti-Malware finds root kit viruses and Trojans that could affect computers and spread through networks. Super Antispyware is an all-in-one scanner that detects and eliminates all types of viruses. Run one scan at a time. Do multiple scans because one program might find a virus that another program misses.
  • **Please give a 4 thumb rating..If you find my solution useful**
    Have a Nice Day
    Sep 28, 2010 | Computers & Internet
    So I replaced a burned out motherboard with this motherboard. However, it'll crash when windows tries to start. . I've tried Re-formatting the Hard Drive, at the suggestion of a friend that the current...
    when you format a hard drive, everything is wiped clean
    no operating system , nothing
    what you have to do now is to used a cd drive ,internal or external, and put the win vista operation system in it
    Now start the computer at the same time holding down the delete button until you get the bios screen up using the arrows move to the boot up section
    set the cd as the 1st boot option save yes and press escape button
    shut the computer down , wait a few seconds the press start again
    If you have saved the boot sequence correctly the cd will start and the win vista program will load and the screen will open
    when it is completed and the computer is running and you have finished , close it down wait a few seconds , start band hold the delete key down , go to boot in bios and change the 1st boot to hard drive
    for future reference , when you are having problems do not format the hard drive , instead in the search bar under the programs , type in chkdsk and enter and let the computer do the job
    it will take around 6 hours to fully check every file folder program, and registry and will repair as it goes
    Nov 11, 2017 | Intel D945GPM 945G Ewith Windows XPress...
    How to wipe out HP mini hard drive
    To restore your hard drive using Disaster Recovery, follow the steps below.
    1. Shut down and power off your HP Mini if it is not already powered off.
    2. Connect an external USB optical drive to the HP Mini.
    3. Connect the flash drive or external USB drive that you used to create your Disaster Recovery disc.
    4. Power on your HP Mini, insert your Disaster Recovery disc into the external USB optical drive, and then restart your computer.
    5. Follow the on-screen instructions to select a Disaster Recovery Set and the drive or drive partition you want to restore.
    Mar 28, 2010 | HP Mini 1000 Netbook
    Toshiba satellite a205-s5804 keeps shutting down
    when you start having this problem it's normally caused by a critical systems error. worry not.. with a little time on your part we can fix this- this is how-
    Go here
    using a torrent program ie (utorrent2.gif, shareaza, etc) download SPINRITE.exe. Burn this on a disk, the program is written with freedos included, but this will not work with 100% of laptops. if freedos won't allow the program to run successfully then you need to use a program such as PowerISO to burn the disk and make it a bootable image,
    after burning the program to disk-
    • press any key to boot from cd if asked
    • type SPINRITE to start program
    • use recovery option 5
    this may take a few hours or a few days depending on the condition of the HDD.
    I have used this program to fix computers I've picked up on the side of the road. I would power it on, start to load then go into a loop. after running this program overnight I was able to reboot (after removing disk) and the pc started right up.
    Make sure you run a program like Ccleaner (you can get at www.fileippo.com) to clean your registry and junk files after completion. ^_^
    Sep 13, 2009 | Toshiba Satellite A100-S8111TD Notebook
    DV6220LA won't boot and hard reset didn't work
    lets try this before we give up all hope.
    Go here
    using a torrent program ie (utorrent, shareaza, etc) download SPINRITE.exe. Burn this on a disk, the program is written with freedos included, but this will not work with 100% of laptops. if freedos won't allow the program to run successfully then you need to use a program such as PowerISO to burn the disk and make it a bootable image,
    • insert disk and reboot
    • when you see Prompt, change to cd drive
    Sep 13, 2009 | HP Pavilion dv6000z Notebook
    I think my motherboard needs replaced.
    Hi
    First I would suggest you test all your memory
    Heres a program for that
    http://www.micro2000.co.uk/products/microscope/MemScope_Free_Memory_Tester.htm
    You will need to burn the Iso to a cd, let me know if you need help with that.
    Stress your memory for a hour or as long as you wish with this tool and see if errors come up?
    You possibly have
    • Faulty memory Or
    • Faulty powersupply Or
    • Faulty motherboard
    Theres also bootcd with multiple programs you can use to test your hardware
    http://www.ultimatebootcd.com/
    Jan 12, 2009 | Sony VAIO VGC-RB42G PC Desktop
    1 Long beep every 2 seconds
    This particular symptom may reflect a problem with any number of components. A bad CPU or video card, for instance, may prevent the computer from booting properly. Often the number of beeps will clue you in to the offending hardware. Check your system or your motherboard manuals' troubleshooting sections for a list of beep codes.
    If the beep codes indicate a memory problem, make sure all memory is properly seated and secure. If you've recently added new memory, make sure it's compatible with your system. You may also want to try cleaning the pins on each module and each socket on the motherboard.
    If you have multiple memory modules, try to isolate any bad modules by removing all but one module and booting the system. If the system boots, turn it off, replace the module with another and boot the system again. When the computer refuses to boot, you've found your problem module.
    Again, you may want to reorder your memory modules. Faster modules in the DIMM0 slot can cause a problem on some systems.
    Feb 28, 2008 | MSI K9VGM-V Motherboard
    Fujitsu LifeBook S2020 Notebook Logo
    313 people viewed this question
    Top Fujitsu Computers & Internet Experts
    Ekse
    Alun Cox
    Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
