Question about Maytag Neptune MAH5500B Front Load Washer
Not locking have too slam door too lock but that doesnt work anymore.
I had this problem also with my Maytag Neptune TL. The door lock would click multiple times before displaying the FL code. I was able to fix this by removing the left door look(the one with the door close sensor) and cleaning the 2 metal pones on top of the left door mechanism, which had rusted and no longer was able to since the door closed. I use a nail file i sure either that or sandpaper will do. After that it went through the whole cycle without stopping or displaying the "FL" code.......hope this helps
Posted on Jan 16, 2013
2 Suggested Answers
  • 249 Answers
SOURCE: will not lock
what you need is new Assy., Door Latch part number 22003593
Posted on Jan 14, 2013
Why my Whirlpool Duet GHW9150P Front Load Washer, doesn't work? it was fine but i slam the door and since then doesn't work it turne on but not lock
appiances are not humans but they also deserve care and love . the locking mechanism has been messed - up due to the impact when you slammed the door. if door don't lock machine won't work. check the door switch. thanks.
Feb 09, 2016 | Whirlpool Washing Machines
Hard to lock door
Lubricate latch and handle mechanisms first with penetrating oil until all works well, then re-lube with white lithium grease to prevent future failure. It may be necessary to remove inner door panel if you can't get to the sticking part.
Oct 06, 2015 | Cars & Trucks
Manual door lock won't lock
There are linkeage bars inside door that has weaker plastic clips that may be loose or broken. Removing interior car door panel will allow inspection.
Jan 07, 2014 | Toyota Corolla Cars & Trucks
Will not lock
Jan 14, 2013 | Maytag Neptune MAH5500B Front Load Washer
My central locking doesnt work but the fuses are ok
VW has this funky door lock module which is essentially a bunch of micro-switches. Over time, the solder joints loosen up and break - you may find that the doors will lock sometimes, if you slam the door hard and the switches make contact again.
Good luck - mine haven't worked for years, as I just can't seem to find the time/motivation to tear the door apart and fix it. But if you're so inclined, here's a step-by-step on how to do it: http://forums.vwvortex.com/showthread.php?1542461
If this helps, please rate my answer!
Jan 31, 2011 | 2002 Volkswagen Golf
My washine mashine doesnt work the lock door light keeps flashing
the door isnt shut hard enough for the machine 2 realise, give it a good slam and it should work
Apr 16, 2010 | Washing Machines
I slammed the passenger door too hard and now the radio doesnt stay on when key is turned off, the auto lock on that door doesnt work and the dome light wont come on 2007 ford escape
I`d check the flexible wiring between the door and the car to make sure it hasn`t been trapped or snapped.
Also check the fuses to make sure one (or more) haven`t blown
Aug 28, 2009 | 2007 Ford Escape Hybrid FWD
Bosch WFK 2401 Need to slam door several times to lock door
Sounds like you need the electric "door interlock" replaced. It is a simple matter of seperating the front of the machine enough to unplug the interlock mechanism, remove the two screws holding the mechanism in place and remove it from the back, reverse the procedure to install the new "updated" replacement part (- Bosch #170935 btw. about $37.00 from Sears). - time: approx 1/2 hour if you aren't mechanically inclined.
Jan 24, 2009 | Bosch Classixx WFL 2462 Front Load Washer
Whirlpool dishwasher wont turn on, no lights, nothing.
It will be your door lock assembly
HERE are the drawings and parts of your machine
Jul 23, 2008 | Whirlpool 24 in. DU915PWP Built-in...
Maytag Neptune MAH5500B Front Load Washer Logo
60 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
