Question about Kitchen Ranges
Gas oven is slow to ignite & preheat
Gas oven will ignite in 8 to 10 minutes, flame is very small and slow to preheat
    Problem Solver:
  • 27 Answers
What kind of range? Taking that long to ignite and small flame. Sounds like both weak ignitor and safety valve is not opening.
Posted on Jan 14, 2013
SOURCE: my gas oven flame
the flame failure device( FFD) may have malfunctioned,not allowing full volume of gas through to the burner.This is a safety feature, preventing full gas pressure to the oven straight away.
Posted on Oct 01, 2007
  • 160 Answers
SOURCE: Gas oven
Its the flame failure device faulty (FFD)
Posted on Feb 22, 2009
  • 188 Answers
SOURCE: Oven will not respond
try pressing the oven regulator knob for a while 3 to 5 seconds on ignition its a safty thing so kids cannot gas themselves all cookers have them. you have to hold it in.
Posted on Mar 26, 2009
EllaWatson25
  • 725 Answers
SOURCE: I have a Maytag Gemini Precision touch 750 series
This sounds like your ignitor has gone out. The preheat will work because the valve doesn't have to ignite to heat to 100 degrees, but whent he unit is ready to ignite, the gas can't ignite it. If you will call or email us, we'll be sure to get the correct ignitor out to you asap so you have your oven orking right away! Thanksgiving is just around the corner, so I hope you get this repaired soon. We hope this helps and we hope to hear back from you soon.
Posted on Sep 30, 2009
tbirdfan1
  • 3051 Answers
SOURCE: gas oven won't light. igniter
Hello there i got disconnected pleas reenter the chat
Posted on Nov 26, 2009
The oven will not preheat and come on
It's could be a faulty igniter, or dirty/faulty flame detector. It comes on just before the gas valve opens. If a flame isn't detected within a second or 2, the gas valve shuts off.
If the igniter glows cherry-red and the oven lights & shuts-off, then locate the flame detector (it looks like a long rod that pokes into the burner flame) and use a scotch-brite pad or some steel wool and clean it up a bit to remove any residue that can cause it to malfunction.
If that doesn't work, it will need to be replaced.
Jan 27, 2014 | Hotpoint RGB790SEHSA Gas Kitchen Range
How to operate cggf3042kfg oven
This gas unit requires the burners to be ignited by holding the knob to ignite on the control panel until the flames arise. Then you can adjust the flames to higher, or lower, heights. Also, the oven should be a simple turn to the temperature wanted and wait approximately 20-30 minutes for a preheat to occur. If this does not happen you are possibly not receiving enough gas to the unit or you have an ignitor concern.
Dec 20, 2012 | Frigidaire Gallery 30" Self-Cleaning...
Oven problem, it tries to ignite, but won't
It sounds like the igniter isn't lighting the flame, or the flame isn't sensing once lit. Check the burner to see if anything has fallen onto the burner or electrodes to prevent it from working. Also check the holes on the burner to see if they are blocked. If it is all clear it may be a control box issue.
Jul 22, 2012 | Kitchen Ranges
Kenmore Gas Range. Top burners work fine. Oven is slow to preheat. Igniter has a yellow glow and the burner lights within about 20-30 seconds later. However, the burner has a very small flame and it takes...
the ignitor should glow bright orange.it sounds like you have a weak ignitor but if the flame lites within 20 to 30 seconds it sounds like it's ok,it could be braking down though when it gets hot,it doesn't matter if it glows,it has to be putting out 3.2 amps,if you have an amp meter with a clamp on it you can read out the amps,if the broiler works ok i would change out the ignitor,then follow the tube down to the bottom and stick a paper clip in the orifice hole where the gas comes out and make sure that's clear,also there's a shutter on the tube to adjust the air flow,see if it's closed,it's usually almost wide open,check the tube to make sure the ignitor didn't burn a hole through it.i've found tubes with holes in them from a lazy ignitor,most of the time if there's a problem it will be the ignitor
Jan 23, 2011 | Ovens
My oven will not preheat and the broiler does not
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jun 03, 2010 | Maytag CWG3100A Gas Single Oven
Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
Feb 26, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
Oven takes 5 minutes to come on (ignite).
Replaced the igniter. The parts guy told me that the amperage changes with age and use; thus the igniter still glows, but it takes much longer to operate the gas valve with the reduced amperage. Cost - $70.14
Oct 18, 2009 | Tappan 30IN ELEC IGNa Oven
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
Oven flame ignites but will then not increase to the larger size
when oven is switched on the flame ignites,butthe flame refuses to go tothe next stage to preheat the ovento the required setting
Nov 10, 2008 | Rangemaster 110 (Gas) Kitchen Range
Oven heat
The problem with you oven is the FFD (flame faliure device ) also known as FSD (flame safety device) The way is works is that when an oven is ignited first time the heat from the low level flame heats phail at the end of the calliary tube which in turn increases the pressure within this tube forcing open the FSD valve to open allowing full gas through. when this fails it restricts the amount of gas flowing through it leaving the oven with a small flame. these are easily repalaced but the law says it must be done by a corgi registered engineer for gas safetey reasons...But 110 % that is your fault. HTH
Dec 04, 2007 | Frigidaire FGF316 Gas Kitchen Range
Kitchen Ranges Logo
99 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
