Question about Hitachi CP-X885 Multimedia Projector
Resetting lamp light for hitachi cp-x885 - Hitachi CP-X885 Multimedia Projector
Marrie
  • 563 Answers
SOURCE: Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
Posted on Mar 26, 2008
SOURCE: Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Posted on Oct 02, 2008
fredcause
  • 51 Answers
SOURCE: Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
Posted on Dec 08, 2008
SOURCE: Reset lamp timer
found a solution... hold the reset and left arrow untill message appears on bottom of the screen then release then use arrow button to return timer to 0
Posted on Jan 16, 2009
  • 3 Answers
SOURCE: hitachi cp-s235
Did you clean the air filter? You should vacuum it or use an air dusting can to clean it out.
Afterwards, reset the time in the menu. In the manual, it says you have to go in the menu to the OPTION submenu. Go down to FILTER TIME and hold the right arrow down for 3 seconds. It will then go into a mini-submenu that, when you press the up arrow, will reset the filter time to 0. The key is to hold down the right arrow initially for THREE+ SECONDS to get into the reset filter time menu. This is NOT the submenu that has RESET - EXECUTE. That is a different thing that doesn't reset filter & lamp time.
Here's the manual online:
http://www.hitachi-homeelectronics.us/supportingdocs/forhome/DisplayTechnologiesGroup/lcdprojectors/SupportingDocuments/01CP-S235-OG-ENG.pdf
Posted on Jan 21, 2009
Pin out for control cable
pin 2 received data
pin 3 transmited data
pin 5 ground
thats all you need
Mar 08, 2011 | Hitachi CP-X885 Multimedia Projector
I replaced the old lamp with new very carfuly and exact same way but now im getting a red light on in power and lamp and no light from lamp,is there a in fuse or something? what could be wrong?
Often a lamp reset procedure is required as well as changing the lamp over. not sure for the hitachi's (check Manual) over models often requires holding poweer button while plugging into power to reset the counter.
Dec 17, 2009 | Hitachi (DT00401) Projector Lamp for...
I need to reset the lamp hours on an Hitachi CP X380 projector
hold rown reset on panel for about 3 seconds, wait for display, press reset again and select 0.
Mar 24, 2009 | Office Equipment & Supplies
Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
Hitachi CP-X960 Shutting Down
Hi Jason
This is normally a faulty Ballast ( lamp's powersupply )
It will need replacement unfortunatelly
Apr 02, 2008 | Hitachi CP-X960 Multimedia Projector
Hi there
Mar 23, 2008 | Hitachi Performa CP-RS55 Multimedia...
Hitachi CP-L850W lamp reset (No Remote)
easy on botem vent unscrew it then u see screw in ther holding balest of the bulb unscrew it litte pull up action on its arm as u will see lift it all out to get new in then reset timer ok
Feb 03, 2008 | Hitachi CP-L850W Multimedia Projector
Oct 19, 2007 | Hitachi CP-X250 Multimedia Projector
Hitachi CP-X885 Multimedia Projector Logo
57 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
