Question about Diablotek Elite 450W PSU ATX Mid Tower Case ATX MidTower Case
How do i restore a diablotek elite atx mid tower to factory settings
Will not get past the starting windows screen. hit f8 f9 f10 f12 and no options to restore to factory settings. tried restoring to last good config and still nothing.
  • 109 Answers
Cases don't have "factory settings." This sounds like a problem with the motherboard configuration. Make sure to re-check all your pin connectors leading to USB, Audio, and HD. Also, you may need to remove the MB to check if there's any damage, and to be sure that you don't have a short somewhere.
Posted on Jan 15, 2013
Hi, When I press f8 at the start menu the restore to factory settings doesnt work, I just get a black screen, help!
F8 is for Windows boot options, not for its reinstall. Depending on what laptop you have you will have to either press F2 or ALT + F10 or (if you're using a less known model or brand) F12 or DEL.
Jul 25, 2011 | Computers & Internet
How do i restore my c650 back to factory settings as i cant access my desktop because i changed my windows password and forgot it
Hi
If you want to use the recovery disk to reset all to Factory settings, you need to press either F10 or F11 when you start the Laptop.
Switch laptop on and start pressing F10 once every 2 seconds till you see the recovery starts. Then follow the recovery wizard.
If F10 does not work try the "F" keys usually the F8 takes you to safe mode options and F12 to the Bios setup.
Hope this helps
Feb 15, 2011 | Toshiba Satellite C650DST2N02 Laptop
Hi when i satrt up my hp compaq mini 110 it wont load past the bios. it comes up with the options for F9: change boot device order, F10:BIOS setup options, F12: Network boot. if i leave it to laod past...
Check to see if any media is in you CD DRIVE, or any other drive because if BIOS is booting from the CD or other media first, it never gets to your hard drive thus never boots windows. If clear, Press F9 and enter into your BIOS setup. You will have to make sure your boot sequence/order is in order to boot first from the hard drive. If all is in order try F8 hitting it repeatedly until safe mode options appear. If this doesn't work post a reply and we'll go from there.
Jan 11, 2011 | Computers & Internet
How to restore my laptop without a recovery disc? (acer aspire 5100)
Hi
You could try hitting the f10 key at the top of your keyboard as soon as you start the computer that should take you into factory restore to start with it looks likes its loading windows but in about a min it takes you into the option to take back to factory settings
If f10 dont work try alt\f10 or the blue fn\f10
if none of them work hit the delete key on startup and go into bios to make sure that f10 is not disabled because sometimes it is by default disabled
But be very carefull not to alter anything else in the bios or you could and probably have big problems just enable f10 0r f12 if they are disabled then hit save click yes
windows will then restart and try the f10 key again
good luck
Nov 13, 2010 | Acer Aspire 5100-5022 Notebook
Need to know how to restore back to factory settings
1.
hi,
try these steps, hope they will help you:
1. Copy all your files and documents to an external storage device.
2. Shut down the computer.
3. Turn the PC back on and hit the F8 key repeatedly until the Advanced Boot Option Screen appears.
4. Click "Repair Your Computer" if you are not already on it and then press ENTER
5. choose your country and click OK
6. On the "System Recovery Options Screen" click "Restore Application" which is the last option.
7. Follow the on-screen instructions
8. When prompted, click on "Full Factory Recovery"
9. "Next"
10. Click "Yes"
11. you will notice for a while it seems like nothing is happening, give it some time.
12. After some minutes, recovery will complete and you click "Finish"
2.
1) Hold down the power button for 10 (ten) seconds to switch off your machine.
Please note: Holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
3) When the machine Starts beeping; release the 0 key.
4) When prompted by the warning screen; select Yes to continue with the system recovery.
5) Select Recovery of Factory Default Software; click Next.
6) Select Recover to out-of-box state. Click Next again.
7) Click Next to Start recovery.
3.
Each computer manufacturer has a special key you have to hit WHEN YOU POWER ON the computer Here are some of the keys,
HP and Compaq desktops/towers use F10,
E Machines and Gateway PC use F11,
Toshiba laptop F12,
Sony PC F10 .
IBM and Lenovo F11
Here is the trick- power the computer off, and then power it back on and start tapping the appropriate key eg F10 until a screen pops up saying "DO YOU WANT TO DO A SYSTEM RESTORE" Once this system restore window opens, stop tapping and just follow the instructions. Some of the older computers may ask you for the restore discs so have those ready. Most newer computers do not need restore discs. The whole system restore could take 2 or 3 hours. When done, reboot your computer and it should be all new and speedy again.
HOPE, THIS WILL HELP YOU !!!!
Jul 26, 2010 | Acer Aspire 3680 Laptop
Hi, Ive been having problems with my laptop Dell Inspiron 1545 i was told to reset it to factory settings, how do i do that?
Hi i'm Rain.
some of the dell models have a built in factory reset .
It will be either F9 ,F10 , F11 or F12
If this option is not avalible to you you will need to go to start then all programs then you will need to go to accessories . In accessories click system tools then system restore.
Follow the on screen instructions.
Select a date before the problem accured. click next and allow the system to restore itself.
Nov 23, 2009 | Dell Inspiron 1545 Notebook
How do i reset my e-machine that didnt come with a cd?
If you want to reset your computer to factory defaults, reset it, when the computer starts to reboot press either F8 or F10 or F12 repeatedly until you see a screen. Go to "Restore Computer" and you'll have options to choose, pick "Restore to Factory Defaults"
Mar 29, 2009 | E-Machines eMachines Desktop PC
Diablotek Elite 450W PSU ATX Mid Tower Case ATX MidTower Case Logo
Top Diablotek Computers & Internet Experts
David Payne
David Payne
Are you a Diablotek Computer and Internet Expert? Answer questions, earn points and help others
