Question about PaceMaster Bronze Basic Treadmill
PaceMaster Bronze Basic err 119
Set weight and incline - motor/screw turns to begin incline. Unit beeps with ERR 119. Seems to be the sensor or power supply board. Is there a way to test the sensor as each item is over $300 and I'd like to be sure before ordering. Thanks, Bob
    Top Expert:
  • PaceMaster Master
  • 12,223 Answers
Run the software calibration for easy diagnose, and troubleshooting see the steps. and Block diagram
God bless you
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Posted on Jan 14, 2013
Sportsart treadmill error 7
Treadmill Parts for SportsArt Belts Motor Brushes SPORTSMITH net
ERR7 Definition: The display board main IC didn't receive the incline variable resistor (VR) value, or the value exceeds the set range. Explanation: The incline VR voltage changes as the incline motor operates, and the display board CPU uses the VR voltage to calculate the incline position. Without this value, the CPU cannot instruct the incline motor what to do, so ERR? appears. Or when the incline set is out of alignment, the VR value exceeds the set range.
The following is a list of possible solutions:
1. Incline Set a) Inspect whether the Incline ERR LED on the drive board lights. This LED indicates that the incline set has exceeded the range. b) Inspect whether the incline set mechanically exceeds range. On DC incline motors, at the 0% position, the line on the thin incline pipe will not align with the end of the thick pipe. On AC motors, at the 0% position, the red line will not appear even with the bottom of the incline window in the incline set. See Incline Troubleshooting Manual for details. c) Inspect whether the incline VR voltage exceeds the range: Put multimeter probes on the incline VR set blue and green wire connectors, while keeping the wires connected. Refer to Incline Troubleshooting Manual for the voltage range for your treadmill. If the incline range is exceeded, either mechanically or electronically, calibrate the incline set. Refer to the Incline Calibration in the Incline Troubleshooting Manual for directions. If the incline set cannot be calibrated electronically, replace the incline VA. If the incline set is stuck and cannot be unstuck, replace the whole incline set. 2. Drive Board Inspect incline voltage on the blue and green wires at the drive board. If voltage is within range, and ERRl appears, inspect drive board component connections and components for wear. 3. Ribbon Cable Inspect ribbon cable for breaks. Inspect connections at the display and drive boards. 4. Display Board Inspect IC connections. Push down to secure connections. Re-insert les.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Feb 04, 2014 | Exercise & Fitness
Pressed express incline then machine went to top incline and received error 306. What is the problem?
Err 306 - Indicates power supply problem at start up.
1. Check all wiring for proper connections and damage
2. Replace the lower power supply board.
3. Replace the drive motor.
Recommended Parts: lower power supply board, wire harness.
I would suggest you get a tech out first. 877-805-1030
Dec 24, 2013 | PaceMaster Silver Select XP Treadmill
Treadmill will not start up error comes up in window
please LUBE the deck belt with silicone or was see the owner manuals and proceed according. However if after you did lube the problem remain, is TIME to replace the old deck board.
God bless you
May 27, 2013 | PaceMaster Bronze Basic Treadmill
Pacemaster treadmill err 133
I just fixed the same 133 error, it's about the communication between motor module and upper panel. There is an 8 wires cable, uses standard RJ45 connectors. In my case, one of the RJ45 connector to motor module is poorly done by the manufacture, so the connection is not reliable, I re-do the connector, problem fixed.
Apr 15, 2013 | Treadmill Doctor Pacemaster Platinum...
Bronze Basic Treadmill Your question about Bronze Basic Treadmill has been posted. i have a treadmill pace master bronze basic i try to start the machine and i get code 133 so ho can help me thanks solli...
yes there are some reset button see your owner manual and do it. if you do not have owner manual download for free
LUBE the deck belt and rollers bearing inmediately.
www.fitness.manualsonline.com
Happy New Year. God bless you
Jan 02, 2013 | PaceMaster Bronze Basic Treadmill
I have a treadmill pace master bronze basic i try to start the machine and i get code 133 so ho can help me thanks solli On 2013-01-01, at 1:32 AM, FixYa.com wrote:
RESET the machine and try again.
However if you can get again the code, Lube the deck belt and rollers bearing very well.
Test the motor and controller motor see the block diagram
see the video and proceed according.
Jan 01, 2013 | PaceMaster Bronze Basic Treadmill
My treadmill no longer asks me for my weight, and I'd like to reset it.
go to reset. Turn off the power and reset the button too. Try again.
After that RUN the software calibration for easy diagnose, troubleshooting and fix it.
Jan 01, 2013 | PaceMaster ProSelect Treadmill Incline...
E7 error message
see this steps and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 27, 2012 | Exercise & Fitness
I have a sports art 1180 treadmill that beeps err 7 how do i fix this thanx
ERR E-7 indicates that the DC incline motor and the variable resistor (VR) are not synchronized. Signal from the VR is not being received properly. Mechanical and/or electrical calibration is needed to reset this error message.
http://www.sportsartamerica.com/SAF/support/technicalsupport/techtips/Treadmills/DC_Incline_Calibration.pdf?utm_source=fixya&utm_medium=cpc&utm_campaign=mendi
Jul 05, 2012 | Exercise & Fitness
I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 15, 2010 | Health & Beauty
PaceMaster Bronze Basic Treadmill Logo
180 people viewed this question
Top PaceMaster Exercise & Fitness Experts
Tom Chichester
Techmotionusa.com
Techmotionusa.com
Electro Med Services...
Are you a PaceMaster Exercise and Fitnes Expert? Answer questions, earn points and help others
