Question about PaceMaster Bronze Basic Treadmill
PaceMaster Bronze Basic err 119 - PaceMaster Bronze Basic Treadmill
New Magnetic Key
Go to walmart and look in kitchen goods. Look for refrigerator magnets and find small one... It will work... Looks cute too.
Jun 22, 2014 | PaceMaster ProPlus II Treadmill Incline...
Pressed express incline then machine went to top incline and received error 306. What is the problem?
Err 306 - Indicates power supply problem at start up.
1. Check all wiring for proper connections and damage
2. Replace the lower power supply board.
3. Replace the drive motor.
Recommended Parts: lower power supply board, wire harness.
I would suggest you get a tech out first. 877-805-1030
Dec 24, 2013 | PaceMaster Silver Select XP Treadmill
Treadmill will not start up error comes up in window
please LUBE the deck belt with silicone or was see the owner manuals and proceed according. However if after you did lube the problem remain, is TIME to replace the old deck board.
God bless you
May 27, 2013 | PaceMaster Bronze Basic Treadmill
Pacemaster treadmill err 133
I just fixed the same 133 error, it's about the communication between motor module and upper panel. There is an 8 wires cable, uses standard RJ45 connectors. In my case, one of the RJ45 connector to motor module is poorly done by the manufacture, so the connection is not reliable, I re-do the connector, problem fixed.
Apr 15, 2013 | Treadmill Doctor Pacemaster Platinum...
Run the software calibration for easy diagnose, and troubleshooting see the steps. and Block diagram
God bless you
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Jan 14, 2013 | PaceMaster Bronze Basic Treadmill
Bronze Basic Treadmill Your question about Bronze Basic Treadmill has been posted. i have a treadmill pace master bronze basic i try to start the machine and i get code 133 so ho can help me thanks solli...
yes there are some reset button see your owner manual and do it. if you do not have owner manual download for free
LUBE the deck belt and rollers bearing inmediately.
www.fitness.manualsonline.com
Happy New Year. God bless you
Jan 02, 2013 | PaceMaster Bronze Basic Treadmill
I have a treadmill pace master bronze basic i try to start the machine and i get code 133 so ho can help me thanks solli On 2013-01-01, at 1:32 AM, FixYa.com wrote:
RESET the machine and try again.
However if you can get again the code, Lube the deck belt and rollers bearing very well.
Test the motor and controller motor see the block diagram
see the video and proceed according.
Jan 01, 2013 | PaceMaster Bronze Basic Treadmill
I have a pacemaster silver it is givin me a err code 304
Dear Sir:
Please RUN the software calibration, for easy diagnose and troubleshooting and fix the problem.See the instruction manual. If you do not have go for free download: www.fitness.manualsonline. com or www. iconservice.com
sincerely. God bless you
Apr 25, 2012 | Exercise & Fitness
PaceMaster Bronze Basic Treadmill Logo
Top PaceMaster Exercise & Fitness Experts
Tom Chichester
Techmotionusa.com
Techmotionusa.com
Electro Med Services...
Are you a PaceMaster Exercise and Fitnes Expert? Answer questions, earn points and help others
