Question about Goodman GPH1324H21A WallWindow Air Conditioner
Goodman gph1348h21ab heat works but will not cool
Worked fine last week used heat at night for a few days then it got hot out and would not cool all the blowers blow but no cool air. when i switch to hear it heats fine.but does not seam to heat on cool or cool on cool
  • 49 Answers
SOURCE: goodman ac / heat pump
Goodman energizes it reversing valve in the cooling mode. Usually in the "o" circuit of the thermostat wiring.You may have that wired hot somehow.
Posted on Nov 28, 2007
  • 182 Answers
SOURCE: Blower starts ans stops
May be a short in the wiring or a bad control board.
Posted on Jul 08, 2008
dogcatstiger
  • 5 Answers
SOURCE: Goodman compressor cuts off when temp too high
When the condenser coil is dirty come high pressure and cut out the compressor, you can wash with the garden hose around the condenser coil before disconect the unit for prevent any electrocution or the sistem is overcharged
Posted on Aug 07, 2008
meBNme
  • 334 Answers
SOURCE: heats for 15 - 20 mins then blows cool air
Look for an outdoor thermostat/temp sensor and if you find one chack to see if its adjustable. (adjustments probably found on the board.)
It could also be wired to bypass the heatpump altogether when temps are below 40.
you will want to adjust, rewire or remove that t-stat/sensor.
In some areas they are really not needed. What state are you in?
Posted on Mar 06, 2009
  • 5 Answers
SOURCE: i have a goodman heat pump and all winter it
The reversing valve may be stuck or it has a burnt solenoid coil. Also, check the defrost relay accross the contacts with an ohmmeter and see if it's bad. Goodman heat pumps also trip on high pressure. There's a resettable switch on some units with a red button. However, I think the problem is in the defrost circuit or reversing valve. If your electric heat is on, change the board.
Posted on Apr 27, 2009
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
Jun 02, 2016 | Heating & Cooling
Amana Furnace
The furnace may have a cracked heat exchanger.
Dec 19, 2013 | Heating & Cooling
The blower doesn't blow when I turn the air or heat on but the blower in the back works fine the knob from higg to low is stuck in the middle and I can't get it to move
Have you tested the front blower motor with a test lead hooked to 12 volts? Use a length of lamp cord and make up a jumper to test the blower, replace as necessary. Also inspect the connector to the blower for signs of melting or burning, replace as necessary.
Apr 20, 2012 | 1999 Mercury Villager
I have a York Diamond 80 ( P3HUB12N08001C ) that was installed about 5 years ago. It has worked fine until recently. I noticed that the furnace does not come on but the blower continues to run. I...
Hello, It very well may be the limit switch,a Limit switch opens when the heat exchanger gets too hot and the most likely cause is lack of airflow. I would check the blower motor and make sure it is running at proper speed and not running too slow, clean burners out, clean blower wheel if dirty, and have the heat exchanger inspected.
Mar 05, 2011 | Heating & Cooling
Central heat does not blow hot air, just warm air weakly
Sounds like some of the elements are not working. You being in Florida they may not have put very many elements in. It was 61 degrees last week. I know because I'm a Dolphin Fan. You will need a current sensing meter to check the elements.
Jan 04, 2010 | Heating & Cooling
I live in a very hot climate, Yuma AZ. In the
It may be getting low on freon sometimes they leak out
Sep 10, 2009 | 2005 Dodge Durango
Air Handler Blower
if you have a meat thermometer, place it in the vent when the air is on, it should be cooling somewhere around 15-18 degrees F lower than what actually temp is, so if its 84 degrees, your unit should blow around 67 degree air out of the vent. if it is not call a tech. your system could be under or over charged.
Jun 21, 2009 | Goodman CLQ36AR49 Air Conditioner
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
May 27, 2009 | Honeywell ER150B Air Conditioner
Intertherm heating
My heating unit is blowing cool air. The thermostat will start the blower when the unit is turned on at the thermostat, but the air isn't hot. But,when I turn the unit on at the furnace/blower using the "Fan On" button, I can see the heating element heat up. After the blower starts the heating element does out. What could be the problem?
Oct 29, 2008 | Intertherm P3RA-048K Air Conditioner
Open Questions:
See all Goodman GPH1324H21A WallWindow Air Conditioner Questions
Goodman GPH1324H21A WallWindow Air Conditioner Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
