Question about Samsung 913B 19 inch LCD Monitor
Samsung 931B monitor (doesn't turn on)
I'm a high school student who was asked to fix a dud monitor. This monitor is the 19-inch LCD 'Samsung 913B [R] A' model (the model code is LS19MEBSBD/XAA). I have taken it apart and re-soldered the ground on the power supply. The power button lights up but the screen does not even flicker. I looked at the boards and nothing seems to be out of place and there are no scorch marks. I took it apart again today and checked the ports that I reconnected wires to, and nothing looks to be out of place. The monitor is not of great value to the school but it would be fantastically awesome if I were able to fix this and put it back in working order. Thanks everyone for all your help.
  • Chris Darius Jan 25, 2013
    Thanks. Very helpful. I identified four blown capacitors and my teacher is ordering them now. I will solder them in in two weeks. Thanks for the help! -Chris
  • Samsung Master
  • 1,684 Answers
Check for blown capacitors on the power supply board, this is a very common problem with LCD monitors. Here is a link to a web article showing what to look for. The second link is to a source for capacitor repair kits for that series monitor.
http://www.ccl-la.com/blog/index.php/capacitors/
http://www.ccl-la.com/catalog/index.php?cPath=21_33_67
Posted on Jan 23, 2013
Fix-4U
  • 293 Answers
SOURCE: Samsung 940 BW Monitor Not working (Black screen)
Hi...there,
That's indicated your backlight inverter are busted. Need to replaced a new one or repaired it. To repaired look for a bad capacitors with a bulged on top of each caps. Not sure, just replaced all the caps... Have a nice weekend!
Posted on Oct 11, 2008
GregL
  • 49 Answers
SOURCE: screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Posted on Jan 20, 2009
  • 1684 Answers
SOURCE: Samsung 226BW 22" LCD wont turn on and flickers a blue light
Hello cstafford35,
Your monitor has a very common problem. The internal power supply has blown a part called a capacitor. If you are comfortable working with electronics and with soldering I can talk you thru the diag/repair. If you are not ready to tackle that we also offer a repair service, about $30 plus shipping for your model. Let me know if you want to try fixing it yourself and we can go from there. The repair will require opening the monitor case and replacing from 2 - 5 parts. You can call me at 318-447-9040 if you have questions.
Buddy
Corporate Computer
Posted on Jun 17, 2009
  • 732 Answers
SOURCE: I have a Samsung Syncmaster 932b LCD monitor.
savato321, Most black screen lcd monitor owners don't have the smarts to open up their monitors to do a VISUAL inspection of the "switch-mode-power-supply/inverter supply!!!! You're good. Now you will need to know some stuff about electrolytic filter capacitors! First, the "uf" or "UF" means micro-farad! It is just a rating given to express the storage capacity of the device. Next is the voltage rating. A 16v rating means that the capacitor should never be placed in a circuit where the voltage will exceed 10 to 12 volts DC. Your 820 uf cap rated at 25volts will most likely be in a 12 to 18volt dc circuit. Now for temperature rating. All caps have a maximum temp rating. Most clock radios, stereos, will use 85 degree centegrade rated caps. Printers,PCs,monitors, will use 105 degree C rated capacitors. Never replace with lower specification units! You can GO up but never DOWN. If 1000uf 25v is all you can get it's OK. If you can get 820uf 35v units and they are not too big and they will fit on the board sure you can use them. I would stick with the OEM design voltage rating. Electrolytic CAPS are polarized!! You must replace them + to + and - to -!!! If you screw -up they will blow-up!! The wire lead closest to the printed STRIPE on the cap will be the negative and the unmarked terminal will be the positive. If you visit www.ccl-la.com/badcaps.htm you will get more info on recapping your SMPS. You can also watch some DIY videos at YOUTUBE for "lcd monitor repair" that might be helpful. Also visually inspect the SMPS/inverter printed circuit board for "COLD" FROSTY looking solder joints. They should all have near mirror finish to them. Let us know the name of the BAD CAPS you remove from your unit. You may even want to document with pics with a digital camera what you find. Well, good luck guy. 12fixlouie
Posted on Dec 24, 2009
  • 148 Answers
SOURCE: Samsung 931 B - Dual monitor setup. one monitor
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once inside there will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! The other screen/monitor blinking(surging) is prob caused by the other monitors faillure and should stop when you replace/fix the broken monitor.
Posted on Feb 01, 2010
Testimonial: "exceptional answer and very detailed. I already got it fixed professionally but if i read this first - i could have done it myself and saved $50"
Samsung Syncmaster 943b light blinking but screen remains blank, tested cables, message 'test good' flashes on screen then goes blank again.
try to connect monitor with other computer, this way u will confirm weather the fault is in monitor or in computer. if it is in monitor, check for bent pins in connectors which connecting computer & monitor, firmly connect both ends of connecter & tighten the screws. if problem not solves then u need to replace main board of monitor.
Aug 25, 2011 | Samsung SYNCMASTER 943B 19" LCD Monitor
My Dell moniter is a 19 inch monitor (Model No: E193FPc) and it's been working fine for 5 years. Now when I plug in the power, the power button goes green, but the monitor shuts off instantly. This...
your LCD monitor has a defective cathode driver inside, it will shut down your monitor when it has short circuit or has defective cathode bulb. you have to open your LCD case to see the circuit .you need screw driver set plus and negative to open the case. if your have knowledge in troubleshooting you can check the circuit if it has a short or defective part at the cathode driver, it has two small transformer that supplying the 2 or 4cathode tube in upper and lower screen of lcd
Aug 18, 2011 | Dell E193FPC 19" TFT LCD Flat Panel...
The Lcd as not working
Spend $50 to $100 to buy a new 17-inch or 19-inch LCD monitor.
Or, spend that much to have a qualified technician *TRY* to trouble-shoot, and hope that he/she does NOT tell you to spend $50 to $100 to buy a new 17-inch or 19-inch LCD monitor.
Oct 23, 2010 | Samsung 15.3" LCD Monitor
Samsung 19 inch lcd monitor turns on and right back off
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 23, 2010 | SAMTRON 94B 19 inch LCD Monitor
How do i unblock web sites at school if they are blocked
This can't be done. The network administrator under instruction by the principal blocks sites that are thought to be unfit to acess by students at the school. You could always ask your pricipal to unblock, if you can put up a good case.
Mar 19, 2010 | Hanns.G Corporation HW-192D LCD Monitor
Samsung LCD 19" monitor problem
Does the monitor plug into a card or the motherboard socket?
Mar 25, 2009 | Samsung SyncMaster 920N 19" LCD Flat Panel...
19 inch wide Tftlcd monitor FV926w comes on then goes black
There is power problem in your monitor maybe in the high voltage section. maybe there is capacitor that leaky that cannot hold the power. Need to bring this to the expert technician to fix it
Apr 15, 2008 | X2Gen MG19MY 19" LCD Monitor
Samsung 913B  19 inch LCD Monitor Logo
121 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
