Question about Apple Computers & Internet
G4 PowerBook Titanium startup crash
G4 powerbook constantly thinks it is being dropped and freezes the hard drive and goes into standby mode. It usually was a result of too much weight being applied by my left arm using the keyboard.. so I would use a usb keyboard not to upset the machine. the problem has continued to get worse and now will not start - making the crash noise, three beeps and the sleep light flashing.. Is there a piece of hardware that can be replaced or removed; or is there much bigger problems going on..
4 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: how to replace the lcd on a powerbook g4 model m8407
Here is a service guide for the Powerbook G4. It has the step by step instructions.
http://www.powerbookmedic.com/xcart1/files/G4alum12.pdf
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 11, 2008
Joed911
  • 4338 Answers
SOURCE: PowerBook g4 won't wake from
Found this, it may help you solve your issue. Power issues on Mac G4 The PMU is a microcontroller chip that controls power functions for the computer. The PMU is a computer within a computer, as it has its own memory, software, firmware, input/output, a CPU, and more. Its function is to:
§ Tell the computer to turn on, turn off, sleep, wake, idle, etc.
§ Manage system resets from various commands.
§ Maintain parameter RAM (PRAM).
§ Manage the real-time clock.
Over time, the settings in the Power Manager may become unusable, which can result in operational anomalies with the computer. Examples include not turning on, not waking from sleep, or not seeing devices plugged into the USB and FireWire ports, among others.
Resetting the PMU is not intended for resolution of a stall or situation in which the computer is unresponsive. A PMU reset should not be necessary except as a last resort in cases where a hardware failure of the power management system is suspected. Performing a PMU reset returns the computer hardware, including NVRAM, to default settings and forces the computer to shut down.
http://support.apple.com/kb/HT1939
Click on this link or copy and paste the complete link into your browser.
Thanks, Joe
Posted on May 16, 2009
Joed911
  • 4338 Answers
SOURCE: G4 Aluminum Powerbook 15in 1.5ghz will not power up :(
Have you solved your problem.
Since you are taking it apart look at the folowing:
PMU reset:
Thanks, Joe
Apple PowerBook G4 not coming out of sleep mode
the issue is bassically with Hard drive data cable.Still check the system by reinstalling the OS.or else replace the hdd data cable.the issue may get solve
Apr 13, 2010 | Apple PowerBook G4 Mac Notebook
How do i back up a power book g4? What application do I need to do the back up?
Suchisart,
If you want a stand alone backup solution, you can download a free program called "Carbon Copy Cloner" and purchase a USB 2.0 external hard drive. You can use the CCC software to backup the entire contents of your Powerbook's hard drive or just selected files to the external USB hard drive.
If your Powerbook is unable to boot into OS X and you need to recover the files that are on the internal hard drive, you can boot the Powerbook into "Target Disk Mode" and transfer the files via firewire cable to another Mac. To do this do the following.
  1. With both Macs off connect them with a firewire cable.
  2. Turn on the Powerbook and hold down the "T" during startup.
  3. Once the large icon shows up on screen your in "TDM".
  4. Turn on the other Mac and login to your account.
  5. The Powerbook's hard drive should mount on your desktop.
  6. You'll be able to transfer your files from the Powerbook's hard drive just like you would an external hard drive, thumb drive, etc.
Don't forget to vote and leave us some feedback. :)
Thank you,
Scott Computer Services http://www.scottcomputerservices.com
Feb 16, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My dvd rom on my mac g4 powerbook won't read my disks, I insert it then it spits it back out.
Try different DVDs and then try different CDs. If it spits out all of them, then its time for a new optical drive.
Jan 22, 2010 | FastMac (APP-5693) for PowerBook G4...
Powerbook G4 titanium
Insert your Mac OS disc, restart your computer while holding down the C key. This will launch your computer on the disc system instead of your hard drive.
From the menu select Disk Utilities.
Repair permissions and repair hard drive in your computer..
Restart... you should be back up and running.
K
Jun 21, 2009 | Apple iBook G4 Mac Notebook
Powerbook G4 Laptop not starting :-(
sotware is awry 1. put in your system disk and restart holding the c key 2. when the screen shows hit continue 3. go to utilities in the header menu 4. select disk utilty 5. select repair permissions 6. select repair disk after the permission repair is complete 7. quit utility go to start up disk  select your hard drive and restart good luck
Apr 01, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook g4 going to white screen only!!
Do you have any external harddrive attached to it? If so, remove it before restarting. Try to start it up in safe mode by holding the Shift button down at startup: http://support.apple.com/kb/HT1455
Mar 24, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook g4 15 not turning on
Something is wrong with the operating system. If there is a flashing folder with a question mark, then it might be with the hard drive as well. If you just get that warning, then you may only have to reinstall your operating system (OS X). Get your CD/DVDs out and insert the OS X disk. Hold down C when you start the computer so it will start from the disk and not from the hard drive. After the startup program has loaded, you can try to check the hard drive and repair permissions and such to see if that works, or you can just reinstall the OS. Good luck.
Mar 21, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
How to replace the lcd on a powerbook g4 model m8407
Thanks, Joe
Dec 10, 2008 | Apple PowerBook G4 Mac Notebook
My powerbook g4 won't recognize my external hd or my web cam but it recognizes my ipod.
I am not really sure but i think the Camara and the External Hard Drive have to be compatible with Apple I think so you can use it. An IPOD is made by Apple so thats why your G4 recognizes it. I would just buy like a USB Drive. And also try to download the Drivers also and you can do that by google-ing it that sort of think. Anyways just use a windows based computer Bro its much more efficient. Let me know how it goes alright.
Oct 02, 2008 | Western Digital 250GB ELEMENTS EXTERNAL...
Worked fine on my macbook but not by my powerbook g4 or any other computer
I would suspect a corrupted catalog file, these are the map that a comupter uses to find its way around the drive, they are also the first casualty when a crash corrupts something. Disc warrior will write a new catalog and fix everything. PCs do not see discs formatted for macs.
Aug 21, 2008 | Hitachi 500GB External USB 2.0 Hard Drive
Computers & Internet Logo
23 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
