Question about Juki Sewing Machines
How to tighten belt on Juki ddl-5550
We had a spool of thread wrapped around the belt pulley thereby loosening the pulley so that it doesn't catch to sew without manually turning the wheel, I think if I tighten the belt it will work, is there an adjustment for the pulley?
  • Juki Master
  • 1,564 Answers
The adjustment is done by getting under the table and loosening the bolts on the big pully. Then hopefully it will drop some or might need to help it with a rubber hammer. Then retighten the bolts.
Posted on Jan 14, 2013
  • 12 Answers
SOURCE: thread constantly wraps around spool pin
Cut a round curcle of fabric the size of the spool from a piece of felt. Put a hole in the middle and put it under the spool of thread. If this does not work you can purchase a small net that fits over the spool. It is designed to keep the thread from coming off the spool except for being pulled through naturally.
Hope this works.
Zelma
Posted on Jan 19, 2008
yalmer
  • 549 Answers
SOURCE: threading a juki ddl 5530
Go to this link and you will find how to thread your machine.
Posted on Apr 02, 2008
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
  • 13 Answers
SOURCE: juki ddl-227 industrial machine
Before all else. Turn off machine!
(1) break screws on the hook loose.
(2) tighten one back up very skightly, one you can reach when the needle bar is at its lowest position.
(3) lower needle bar to its lowest position.
(4) loosen the screw just tightened.
(5) position the tip of the hook behind the needle hole. the tip should be as close to the needle hole as possible without actually touching the needle
(6) tighten screws
(7) slowly hand turn the machine (depress the foot pedal to disengage clutch brake on motor) several revolutions to make sure the needle doesn't hit anything on the hook.
(8) if it passes this test, try on a scrap of fabric
Posted on Dec 15, 2008
  • 5 Answers
SOURCE: threading juki DDL-227 machine
There is a free download threading diagram for the DDL-227 here:
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_552_553_555_227_Threading_Diagram.htm
Posted on Mar 23, 2009
The bobbin thread holder on the right side will not turn.
go to the right side of machine and take cover off that is where the timing belt is and see if it is broke or something is holding it up
May 15, 2016 | Juki DDL-5550 Industrial Straight Stitch...
Juki ddl 5550-6
can you tell me your control box model? some model of control include variable resistor to adjustment the speed for thread trimmer.
a waiting your answer about control model and i will help you.
thanks
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Dec 07, 2013 | Juki DDL-8300
Bottom thread on Juki DDL-5550 is coming up. Top thread seems to lie flat
Check your upper thread at the spool. I've had industrial machines randomly throw a loop around the spool holder spindle which is hidden under the spool itself.
Also check your threading guide to be absolutely certain you are threading it correctly. Also make sure needle/thread diameter are suitable for each other.
Good luck.
Dec 02, 2012 | Sewing Machines
Juki DDL-227 won't spin
:) welcome to the world of industrial machines. The good news is they are typically simple machines.
It is a good habit to take a few minutes to clean and oil your machine before you start sewing. Look for the oil points and give it one drop of quality sewing machine oil in each port.
Now let's try to determine why the hand wheel isn't turning. Loosen and remove the belt from the large reducer wheel under the table to the sewing machine. Try to turn the hand wheel. If it does turn.... Good! If it doesn't turn... we know the problem is in the the machine head and not the wheels below.
Make sure there is no bobbin thread or upper thread. Try to turn the hand wheel again. Anything?
Look carefully at the machine... is the take up lever bent? (personally had this happen with friends helped me move a big machine like this.)
Keep working this way... inspecting the machine until you find the problem. Good luck
Sep 08, 2012 | Juki Sewing Machines
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
Hello, I have a juki DDL 5550, runs great, But the tension is off. Top thread bunches up on bottom side of fabric ( bobbin thread looks ok)\r\nThanks,S
Soulds like your not geting the top thread all the way in the tension disk. Make sure you have the presser foot up when you thread the machine. also after you get it treaded check to make sure you have tension, with the presser foot up you should have not tension and with it down it should be very hard to pull.
hope this helps
Mar 15, 2011 | Juki DDL-8300
I just got a used juki ddl-5550-6 sewing machine. There is no owner's manual. I think I have the machine threaded right. When I put the pressure foot down to start sewing, it pulls the thread down into the...
PLEASE CHECK FIREST TIMMING BETWEEN NEEDLE AND HOOK
OR GO TO WWW.JUKI.COM U WILL FOUND USER GUID ALL LOCKSTICH MACHINE SAME ADJUSTMENT WITH DDL SERIES
BEST REGARDS
Jul 08, 2009 | Juki DDL-8300
Sewing Machines Logo
153 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
