Question about Panasonic CT-36HL43 36" TV
I have a panasonic 36" tv with no power. Some of the other postings suggest a blown fuse, which would make sense. How do I find the fuse?
  • tgada Feb 27, 2009
    maturco, I have the same problem, set won't turn on, I got the old fuse out, but it doesn't look blown. Did yours? I haven't be able to get a new one in to test it yet.
I had the same problem. 45karats had the answer. It was the fuse and its replacement fixed the problem. You need to get to the back of the set (moving it away from the corner wall was no mean feat; this is the heaviest set I ever owned) and remove all the screws holding the back onto the chassis. Slide the back off slightly, maybe six inches (pry around the edges evenly) and you will be able to see the small fuse attached horizontally next to where the power cord attaches. CAUTION! There are several wires and circuit boards that move with the back of the set. Don't pull it back too far, but just enough to find and remove/replace the fuse. 6.3amp slo-blow fuse is what I used. Also DO NOT DEPRESS THE BUTTONS, LIKE THE POWER BUTTON, ON THE FRONT OF THE SET UNTIL YOU GET THE BACK COMPLETELY AND FIRMLY BACK INTO PLACE. I tried to test the set to see if it would come on before I had the back completely back on and the Power button went inside the cabinet! I had a hell of a time reaching in and prying it back through its slot in the front of the set. It is a simple plastic button that actuates the power switch, but only AFTER the back is in place. The switch moves with the cabinet so there is no resistance to the button until the back is fixed in place. I got the fuse at Radio Shack. Note the fuses they sell are 6.3 amp and 250v rated, vs. 125v that I took out of the set. I don't think the voltage rating is important but I could be wrong. It is the amp rating that is important. All I know is it works and I am relieved about that.
Posted on Jan 27, 2009
What causes a blown fuse in tv samsung
Usually in a Cathode Ray Tube Television a blown fuse is either something is wrong in the high voltage power supply section or the flyback transformer is bad, or a bad horozontil output transistor.
Nov 18, 2013 | Panasonic CT-36G34 36" TV
Panasonic ct-36SL13G worked fine, one day would not power up.
the plug fuse may not have blown but the fuse inside set may have blown, or dry solder joints on pcb
Jun 27, 2009 | Panasonic CT-32SL14 32" TV
Fuse keeps blowing out on Panasonic CT36HL44J TV
Thanks for this post. It inspired me to replace my fuse in my TV and it is working great now... I took pics of the process in case anybody wants to see what they are in for. http://joedotcom.com/2009/09/01/panasonic-fuse/ Although I did use a 6.3a fuse (just like I removed). I read on another forum that you can replace it with a 7a fuse and get better results. I have had this TV for years and this is the first blown fuse. If it becomes a reoccuring theme, i may up it to the 7a.
Jan 14, 2009 | Panasonic CT-36HL43 36" TV
Panasonic HDTV /no power
the loss of power was do to a blown fuse. could not access it through the small opening near where the power cord went in at the back of set.. carefully took the back of just far enough to access the fuse and replaced it. Working fine.
Nov 25, 2008 | Panasonic CT-36HL43 36" TV
Blown fuse on panasonic tv
Maybe the horizontal output IC are on short circuit.
Nov 04, 2008 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Panasonic television
I had the same problem, however mine was a 32inch. It is a blown fuse. It is not the power cord. What you need to do is find out what fuse voltage you need. Hope this advice helps. I have a panasonic model CT-32SX12C.
Aug 20, 2008 | Panasonic CT-36SX12 36" TV
TV DOESNT TURN ON ,I SWITCH PLUGS ,I TRIED TO TURN THE TV ON FROM THE TELEVISION ,CAN YOU PLEASE HELP.
Possible blown fuse or worse. If you attempt to change the fuse use the same amps that is in it.
Mar 09, 2008 | Panasonic CT-36SX12 36" TV
36" Sony Wega - no power
There are of course internal fuses, but I suggest you better call a technician if you are not an expert, because you can blow the tv trying to rectify power supply problems. If the fuse is blown, there must be a faulty component behind that.
Jan 17, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
My tv dose not turn on
i have a ct-36hl43 it was ac fuse gma 6.3 amp its on the panasonic web site under parts cost a dollar randy vincent ragingbass@comcast.net
Dec 29, 2007 | Panasonic CT-36HL43 36" TV
Panasonic CT-36HL43 36" TV Logo
259 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
