Question about Hunter Ceiling Fan Remote Transmitter 85095-01
Light not turning on or off but fan it self works
The fan setting speeds work just fine but the light doesn't want to turn on or off. What seems to be the issue?
    Genius:
  • Hunter Master
  • 1,617 Answers
Probably needs a new receiver.
Posted on Jan 23, 2013
  • 6 Answers
SOURCE: I have 2 Remote Control
You need to completely disassemble the hand held remote unit, remove the rubber push buttons and clean the contacts. Mine do this frequently. The contacts are black and will be slimey. I just use soapy water and a soft cloth to gently clean them. Be sure to dry them completely before reassembling. Also be sure you dont get any of the electronics wet.
Posted on Jan 24, 2011
techman
  • 3130 Answers
SOURCE: ceiling fan
there is a run capacitor inside the motor thats probably bad but 99% of the time its just not worth fixing these things unless you really like the style and color. Good Luck
Posted on Apr 27, 2006
Buffalo12980
  • 625 Answers
SOURCE: controller circuit for Hunter ceiling fan bad
try home depot they sell hunter.
Posted on Aug 31, 2007
landsend
  • 1066 Answers
SOURCE: My Hunter fan will only switch from high to low speed and won't
if the three speed switch is functioning the middle speed winding is bad.  Either replace the fan or hook up a wall speed control and keep the fan on high.
Posted on Mar 26, 2009
  • 34 Answers
SOURCE: HUNTER ceiling fan remote works with fan but not light
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
Posted on Sep 10, 2009
Fan only runs on slow speed
The receiver in the fan housing may have failed.
Apr 20, 2017 | Hunter Dryers
Minka Aire Ceiling fan turns on by its self
Try changing the frequency in the receiver & transmitter.
Mar 19, 2013 | Minka Aire Ceiling Fan
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
I have a wall outlet that turns the fan on and I turned it on and the lights are able to work on it but I can't get the blades to move
first, check to see if there is a pull chain or string on the fan motor to control the fan speed. this usually has 4 positions,off,low,medium & high speeds. someone may have turned the speed switch to off.
it done cost nothing but your time to look and you might suceed in turning on the fan motor.
Dec 27, 2012 | Hampton Bay 24002 Ceiling Fan
2003 GMC Envoy Heater Fan doesn't always blow
Your problem most likely is the resistor block. In order to limit the fan speed a reistor is placed in the circuit which will limit current flow to the motor thus giving you the diferent speeds. High speed bypasse the resistor to get full motor speed. Since you only get high speed it is very likely that the resistor block is faulty
Oct 24, 2012 | 2003 GMC Envoy
04 Saturn vue compressor turns off when fan is set to 3 or 4
The problem is the blower motor speed control resistor, it is located near the blower motor in the housing. I exchanged mine and it works like a charm now.
May 31, 2012 | 2002 Saturn VUE
My 2004 toyota celica's turn signal clicks extra fast when it's set to turn right. Also the front right signal light doesn't blink. Is the problem a broken bulb or a broken flasher relay?...
most likely a faulty relay is all... fix that and you'll be fine, they tend to speed up to let you know that they're on their way out.
Jul 12, 2011 | 2004 Toyota Celica
99 grand cherokee blower selector high position not working. Blows only level 1-3. replaced resistor, same problem.
automatic or manual a/c.
I'm going to assume manual but Auto is simular and i can give some direction if you have that as well.
There will be a black with tan wire at the blower resistor. This is the wire the HVAC control head grounds to turn the fan on high speed. With a test light hooked to power unplug the resistor, set the blower speed to high, turn the key to the run position. the test light should turn on when you probe the connector. If it doesn't pull the control head and back probe that same wire at the back of the control head with everything still plugged in. If the test light again does not illuminate the the control head is bad and not providing ground
If the test light does turn on when you probe the blower resistor connector plug the resistor back in. Turn the blower speed to the low setting. With your test light hooked to ground see if there is power on the black with tan wire. if there is turn the HVAC off and ground that wire with a jumper wire. the fan should run at high speed. If it doesn't you have a defective resistor.
Jul 01, 2011 | Jeep Grand Cherokee Cars & Trucks
1993 CORVETTE AC PROBLEM
Are you fully charged though? If you don't have a full charge the clutch will not kick in.
Aug 18, 2009 | 1993 Chevrolet Corvette
Dryers Logo
123 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
