Question about HP Officejet J5780 All-In-One InkJet Printer
Fax will not send or receive
Get a printout that says Error 388? What is it?
    Scholar:
  • 97 Answers
please click on following link,
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=uk&dlc=en&docname=buu02549
that error is becoz of poor line condition, there is a work around for that.......
click setup and scroll down to advanced fax set and click ok and scroll down to fax speed and resduce the fax speed to meduim, it should resolve teh issue.
Regards,  raj_p5983
Posted on Jan 23, 2009
5 Suggested Answers
  • 4 Answers
SOURCE: fax not working Error 388
I used to have the same problem anytime I tried to use the fax. Drove me crazy. The problem for me was that whenever HP software updated it corrupted the installed software and I had to reinstall the program.
I finally ended up copying the files from the install disk on to the hard drive so I could find it quickly when I needed it and HP would repair itself using the hd installation files.
You might also check the back of your printer to make sure that none of the cords are lose or the usb isn't loose from the pc. This will cause it to have problems with the handshake. I found especially during warm weather that they tended to get loose because of expansion.
Hope this helps...
Posted on Aug 27, 2008
laxmankumar
  • 191 Answers
SOURCE: Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Solution
Please Click here and follow the instructions to resolve the issue.
Posted on May 23, 2009
  • 121 Answers
SOURCE: my hp4225 do not sent or receive fax messages, error 388*
hiii
well this error generally arises when there is too much of disturbance in the line.It may going away with time.And if it doesn't then u must retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Posted on Sep 03, 2009
  • 30 Answers
SOURCE: Fax will not send nor receive - error 388. How do
The error code that you get is caused if there is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Posted on Jan 25, 2011
Error meassage while trying to fax
please refresh fax memory and send the fax
Mar 09, 2012 | HP Officejet 5610 All-In-One InkJet...
Sending fax for hp all in one indicate Comm Error 388
Error could be caused by the fax machine that you are sending to.
So you can receive faxes, but can't send them. Is it just the one number that causes the error, or is it all faxes sent that cause the error?
What I like to do on fax troubleshooting calls, is to call the phone company that the site is using. Tell them that you are having fax problems, and ask them to test the line.
Jun 12, 2011 | HP LaserJet 3050 All-In-One Printer
I've been trying to send a fax to an office in Sri Lanka for several days now, but it won't go. We are getting a Comm Error 388 in the fax error report. The unusual thing is we are able to send fax...
inernational fax calls quite often do not work on digitized phone lines or via satellite. You cannot fix that. maybe your fax has a "fallback 4800 bps" setting that might be helpful.
May 11, 2011 | Office Equipment & Supplies
Fax will not send nor receive - error 388. How do I fix?
Solution
Jan 25, 2011 | HP OfficeJet 7310 All-In-One InkJet...
My hp4225 do not sent or receive fax messages, error 388*
hiii
Sep 03, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Problem faxing-error message
Error 388:
Definition
Solution
Error 403:
Definition
During a V.34 transmission, the local machine is unable to connect (handshake) with the remote machine and is consequently unable to send a T30 frame. This occurs when the line is disconnected or if line conditions degrade during the session.
Solutions
  • Remove any pass-through devices from the phone line, and then try the fax again.
  • Confirm that the fax/phone cable is no longer than required, and that it does not pass near unshielded electric motors such as fans, heaters, or household appliances.
  • Try to send the fax at a different time when telephone line conditions have improved.
May 29, 2009 | HP Office Equipment & Supplies
Solution
Solution
May 21, 2009 | HP Officejet 6310 All-In-One InkJet...
What is error 388
there is not error code for the OfficeJet 4315. however, there are similar code for other Hp printer.
error "388" is lised as unable to detect T30 frames. in other words, the machine fail to establish comparable connection. this can be the machine trying to send out fax in high speed, or the phone line problem.
consult the user manul how to set a lower transmission rate, or try to send the fax at a differnt time of the day . If that still give you problem, please call the phone company and have they look a the phone line.
Nov 10, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Can't fax in or out with my L7680
386
387
388
389
390
391
392
393
394
395 The machines were unable to complete the handshake.
*Try to send the fax at a time when telephone line conditions have improved
Aug 05, 2008 | HP Officejet Pro L7680 All-In-One Printer
Fax
error code 388 says :-
Unable to complete the handshake.
*Try to send the fax at a different time when telephone line conditions have improved.
Mar 06, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP Officejet J5780 All-In-One InkJet Printer Logo
148 people viewed this question
Ben Johnson
