Question about Whirlpool Dryers
My dryer will not start. When you press the start button... nothing happens?
I already changed the thermostat fuse and still nothing.
  • Whirlpool Master
  • 8,220 Answers
Just so we are on the same page, the skinny white fuse is what you replaced on the blower housing? Have you checked the door switch? It is on the same circuit as that fuse, kills the motor in case the door is opened, that is what I would check next. I have a repair page you might want to look at. I have the service manual and several videos that will help you diagnose:
WHIRLPOOL DRYER REPAIR by Paw Paw
Posted on Jan 14, 2013
Testimonial: "THANKS MR.DAN THE DOOR SWITCH WAS BROKEN. YOUR SUGGESTION WAS A GREAT HELP. THANK YOU SINCERELY, MIGUEL LOPEZ"
    Problem Solver:
  • 6 Answers
Always check the breaker first
Posted on Jan 16, 2013
  • 185 Answers
SOURCE: Dryer won't turn on
its a thermal fuse open up the back make sure you unplug it and turn off the gas its on your lower left side of your blower housing its skinny and white and about a inch in a half long and has 2 connectors going to it if any problems let me know
Posted on Mar 28, 2008
docjohn174
  • 943 Answers
SOURCE: Whirlpool LER5644EQ2 Electric Dryer that won't start
HI yes it could be a fuse its called a thermal fuse located at back of dryer remove back on the left sede on air duct a fuse with 2 smaller blue wirse that should be your problem thanks THE APPLIANCE DOC
Posted on Sep 13, 2008
wheelshot
  • 102 Answers
SOURCE: When I press the start button, the dryer does not run
Is this a colipso dryer, I think that is how you spell it? If so then yes it very well could be a control board.
Posted on Apr 05, 2009
  • 15 Answers
SOURCE: dryer won't start
IT SOUNDS TO ME AS IF YOU HAVE A BAD DOOR SWITCH. YOU CAN TRY JUMPING THE SWITCH OUT TEMPORARILY JUST TO SEE IF THE UNIT RUNS.
Posted on Apr 07, 2009
  • 9 Answers
SOURCE: Dryer won't start when start button is pressed and held
check door "close"contact button/switch usually the culprit..
Posted on Aug 02, 2009
Dryer turns on but will not start
When asking a question it is best to include a Brand name and model number. However this problem sounds like you have blown the thermal fuse in the heater.
There are usually two thermal fuses, one on the heater and one at the lint filter blower box.
The heater can overheat if the airflow is too low usually caused by a dirty or clogged vent pipe. There are other causes such as a bad thermostat. If it is a blown thermal fuse you should change the thermostat too.
Youtube has many videos on dryer and washer repair. I am including a link for a search of youtube dryer thermal.
Look through them and you will probably be able to solve your problem. Good Luck, Tom
dryer heater thermal YouTube
Aug 24, 2014 | Washing Machines
DRYER WONT START
Most modelsof Bosch dryers has a reset thermal fuse. Look in the back of the dryer for a little red button. Our check your user manual for the location.
http://www.on-timeappliance.com/dryerrepair.html
Mar 27, 2012 | Bosch Dryers
The dryer will not operate. you can press the buttons , all the lights come on, but as soon as you press start you hear a clicking sound and then nothing happens. I seems the dryer is on but nothing is...
go to the back of dryer,remove the back panel,look at blower housing and you see a white thermostat like part with 2 cables. that's the thermofuse. use a multimeter on continuity(beep sound) and disconnect one wire and put leads at the 2 connector of fuse. if no sound then replace it. this is the most common problem. after replacing part check vent at wall that is clean of obstructions.
Feb 12, 2011 | Whirlpool GGX9868J Gas Dryer
I have a Kenmore 70 series. About 10 years old. The inside light comes one, the timer ticks when turned but nothing happens when I push the start button. We have already checked the breaker. Is there...
you either have a blown thermostat, blown thermal fuse, or a bad heating element most likely a blown thermostat
email me if you need more help in replacing or testing
Nov 16, 2010 | Kenmore 73952 Gas Dryer
Whirlpool dryer model number WED5300SQ0 wont start
take a meter and check door switch then if good take the back off and check all thermostats,thermal fuse,AND if your belt is off theres a safety switch on the idler pully.hope this helps
Nov 15, 2009 | Whirlpool WED5300S Electric Dryer
We press the start button and nothing happens. Breaker is good.
If this is a whirlpool or kenmore remove the back and look on the exughst pipe . there is a small white fuse about the size of a quarter. You can unplug wires and put them together and then test dryer. First you want to check the door switch if you haven't already.
Mar 29, 2009 | Dryers
Dryer won't start due to delay button lights up and won't go off
1. No power to the dryerMake sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Nov 09, 2008 | Kenmore 659 Electric Dryer
Dryer won't start, light comes on
hi thanks for the question the thermal fuse fails allot caused by poor venting yo the outside this fuse is located in the front on the air duct thanks the appliance doc
Jul 08, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer won't run
take a look at your start and door switch
May 24, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
495 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
