Question about Curtis 326A LCD TVDVD Combo
Dvd is stuck in tv - Curtis 326A LCD TVDVD Combo
How do I remove stuck DVD?
If this is a combo unit the first thing you have to do is remove that dvd from inside the player. Open up the unit and do the deed. THEN see what happens. Often when the player gets jammed or whatever, it will render the rest of the set useless until the hassle is removed. In this case get that disk outta there.
If still nothing disconnect the power line that feeds the dvd to see if that has any effect on overall tv operation.
Sep 05, 2015 | Sylvania Televison & Video
19 in. Coby TFT LCD TV with side-loading DVD player. How do I remove a stuck DVD?
Hi Joanne, The eject button ( micro switch ) on the TV is defective. Please get it changed and the stuck DVD will come out.
May 28, 2015 | Coby Televison & Video
Tv stuck in dvd mode
There should be an input button on the tv to allow you to switch between dvd, tv and any other device you have connected.
Aug 22, 2014 | Akai LCT3201TD 32 in. LCD Television
Dvd is stuck in player - won't play and won't eject
open cabinet of your dvd you will find out a lock open that pick up your disk during proseeing that is stucked
Mar 05, 2010 | Mintek DTV-263 26 in. TV/DVD Combo
There is a DVD stuck in the built in DVD player in
try unpluging set while tv is on and plug it back in it should come out
Feb 03, 2010 | LG Televison & Video
Akura tv/dvd dvd stuck in tv
Ha! I stuck a long nail file in and twiddled it around a bit turned the tv on and Hey Presto! It worked!!! One up for the women and their nail files ha ha ha!!!!
Dec 21, 2008 | Televison & Video
Stuck DVD
Have you tried unplugging the set for a few minutes, then plug it in.
Hopefully it will reset and eject the disk.
If it is actually jambed (wedged in) this probably won't work.
Sep 12, 2008 | Mintek DTV-263 26 in. TV/DVD Combo
DVD Stuck in TV/DVD Combo
This may not sound technical, but I stuck the end of a paper clip into the opening until I could feel the dvd.....jiggled it a bit, and out it popped while pushing the eject button!!!
Jun 19, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
DVD Stuck inTV/DVD combo unit
Same here.  Had the TV for about 6 months and had a DVD get stuck for the second time.  Used the same method of unplugging and plugging back in.  Then hitting the Stop/Eject on the side and it came out.  When plugging it back in I could hear the DVD "engage".
Jun 06, 2008 | Westinghouse SK-32H590D Television
Can't Change Inputs on TV
make sure that your remote is on the tv cotrle mode rather than the dvd control mode
Nov 10, 2007 | Mintek DTV-323-D TV
Curtis 326A LCD TVDVD Combo Logo
22 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
