Question about Coffee Makers & Espresso Machines
Mixer will not run - Coffee Makers & Espresso Machines
    Genius:
  • Coffee Maker... Master
  • 1,669 Answers
The nice thing about such devices is that they are simple. The bad thing is that the parts frequently cost more than it's worth to replace them. The switch tends to be the problem. If you have a multimeter you can test to see if the switch is getting power. Next, try to use small alligator jumper cables to bring the power directly to the motor you show exposed in the video. If the motor turns, the switch is the culprit...replace it!
Posted on Jan 14, 2013
I just bought this mixer and can't seem my existing Cubase recording software to recognize it for recording. Do I have to run the mixer thru my existing interface or can the Cubase setups be modif
The mixer allows you to use the USB connection for recording without having to use an additional interface. Make sure that you have all of the proper drivers installed for the mixer. Regardless of whether you're using Mac or PC, you should be able to see the device in your list of available Audio Devices. If you do, you need to adjust the proper settings in the Cubase Audio preferences to make use of those inputs.
May 29, 2013 | Mackie PROFX12 Professional 12-Channel...
Concrete mixer motor pulley size
smallest available that fits the motor shaft ( around 11/2 ")
it is not the mixer speed you are worried about but the power required to drive a full mixer
Jan 25, 2018 | Dryers
Mixer only runs at one speed
if it runs only at high speed it needs a new phase control board if the mixer is post 1978, if the mixer is pre 1978 then you will have to replace a capacitor on the end of the power cord inside the mixer. if the mixer only works on one speed that is not high speed then you need to adjust or replace the speed control plate on post 1978 mixers and the capacitor on pre 1978 machines. Hope that helps
Jan 30, 2013 | KitchenAid Food Mixers
My kitchenaid mixer run on high at all times
If your mixer only runs on high speed there are 3 things that can cause that. The first thing to check will be the speed control plate, Remove the trim and end cover on the mixer, the first thing you should see is the speed control plate, this has 3 screws on it, try adjusting the top two screws 1/4 turn, this should slow the mixer down, do not over tighten. Also check to see if the control plate spring is unhooked. If the spring is unhooked, attach to bottom of the control plate, and squeeze the spring end.
If this does not fix your mixer, check the wiring of the mixer, you can locate a wiring diagram on the last page of the service manual.
If the speed control plate is adjusted correctly and all the wiring is correct it will be your speed control phase board. You can test the speed control phase board to see if it is shorted. With the line cord disconnected, pull the t-b ar contacts to open, and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run. If it operates at full speed, teh phase control board is defective and needs to be replaced.
Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
This will aid you in taking the mixer apart, troubleshooting and putting it back together, remember the wiring diagram is the very last page.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Jan 07, 2013 | KitchenAid K5SS Mixer Speed Control Plate...
Mixer runs backwords
if your mixer is a 3 phase, you can change any 2 legs feeding the contactor, after switching any 2 legs , looking from the front of the mixer rotation should be ccw
Jan 29, 2010 | Food Mixers
Seemingly well maintained H600 mixer only runs in reverse...
whoever wired the mixer in , hopefully 3-phase made a mistake on the incoming pwr to term block or the contactor switch any 2 leads this should reverse rotation of the mixer
Nov 04, 2009 | Hobart H600 Stand Mixer
Hook EQ to my mixer
I assume you want to put the EQ on the mains output of the mixer -- is that correct?
Just run the left/right out from the mixer to the left/right in on the EQ, then run the left/right out on the EQ to your amp.
May 27, 2009 | Behringer ULTRAGRAPH PRO FBQ3102 Turntable
KitchenAid 2671 onmly run Stir and Second at high speed
Hi. Goto kitchenaid.com and download the parts catalog for your mixer model, these drawings will assist you in the disassembly and reassembly of your mixer.
You'll need to replace the speed control in your mixer. This is a common problem. Be prepared to wait at least a month for your parts to arrive. Unplug your mixer before you open it up.
If you're still under warranty call kitchenaid!
If this solution has assisted you, please rate it. Good luck! ricardok45
Jan 28, 2009 | KitchenAid KP26M1X Stand Mixer
West bend stand mixer # 41039 dial won't turn
If the mixer does not work on all speeds, then check motor wiring and control board.
If the mixer is less than one year old call manufacturer at the number listed on the owners manual.
To get parts for your mixer you can contact West Bend Appliance Parts - Bettervac 1-800-675-9491
Dec 08, 2008 | West Bend 41125 Hand/Stand Mixer
Open Questions:
Coffee Makers & Espresso Machines Logo
119 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
