Question about Ashton Digital Passport 2000 Notebook
I want to upgrade my RAM memory.What type of memory chip does this PC use? Model Green732,Ashton Digital laptop.
What is the fastest compatible CPU for upgrade Asus X50GL series laptop
changing chips most time requires a mother board up date to cater for the extra chip pins
best advice here is to take it to a computer repair shop and they will be able to tell you right off if what you want to do is possible with that board
point of interest here
chips are only as fast as the hard drive and rams will work
if your unit has a disc type hard drive consider upgrading that to a solid state hard drive which handles data much much faster than a disc type
just a bit of info when you are talking to the computer geek
Oct 05, 2016 | ASUS Computers & Internet
How to buy addtional memory 256MB, now 256MB. may need more memory for Windows XP Home grade-up from Win 98.
You need 100 MHz SDRAM SoDIMM 144 pin ram to match this laptop. You can put in a maximum of 512 MB (take out the current memory and put in 2 256 MB sticks). One source for this memory is http://www.pcmemorystore.com/Ashton_Digital-MaxiMate-420-ram.htm .
I hope this helps.
Sep 05, 2010 | Ashton Digital Maximate 420 Notebook
Can I upgrade memory to only one gb of memory or install 2 512 mb on a toshiba satellite m35x series
http://www.shopping.com/xPF-Toshiba-Toshiba-Satellite-Notebook-PC-M35X-S114
Looking at the specs, the max is 2gb for your Toshiba. According to this website, its only a 256mb ddr sdram. So my guess is you only have 1 slot for the ram. I'd go with a 2gb ram if you can afford it, 1gb just don't cut it in todays technology.
I believe its the PC2700 model, so find a 1gb or 2gb PC2700 @ 333mhz and you should be set.
Sep 09, 2009 | Toshiba Satellite M35X-S114 Notebook
How do I add more RAM memory
It is easy to add more RAM to the laptop, the first thing you need to know is the type of memory you model uses. Your model uses DDR2@533MHz up to 2 GB RAM (2 chips 1 GB each).
PLACE THE LAPTOP UPSIDE DOWN ON A SOFT CLOTH. MAKE SURE YOU DON'T MISPLACE THE SCREWS.
1. Remove the larger cover in the back of the laptop (2 screws) ; the memory chips are under this cover.
2. Replace the chip(s) with larger capacity chip(s).
3. Put the cover back (using the 2 screws you safely removed in step 1). Thats it!
Mar 13, 2009 | Acer Aspire 3680 Laptop
Cpu upgrade
Upgrading the CPU in a notebook is a bad idea.
Even if you get a compatible CPU, a faster processor means more heat, and notebooks are not design to handle it. You would risk major damage.
If you want to make it faster, try increasing the memory.
Dec 14, 2008 | Ashton Digital Passport 2068 Notebook
Laptop memory upgrade
Your Laptop is using DDR2 Memory, just find your nearest retailer that sells memory and go buy you a chip, ur laptop ships with 1024mb of ram as standard, if you want to get a decent boost pretty cheap then i would just buy another 1gig chip and put it in beside the one already there.
Not sure what your system maxes out at but the average is 4gig of ram so you could try a couple of 2 gig chips if you feel you need that much ram
Aug 22, 2008 | Computers & Internet
Ashton Digital Passport 2000 Notebook Logo
43 people viewed this question
Top Ashton Digital Computers & Internet Experts
David Payne
David Payne
Masood Rasool
Level 1 Expert
Are you an Ashton Digital Computer and Internet Expert? Answer questions, earn points and help others
