Question about Dell Inspiron Computers & Internet
Y cant i get my dell tower pc to start
I try to turn my pc on and all i get is it will start then stop it will do this for ever if i let it and i have i brit yellow light on then inside top right on mother board and the buttin on front is orenge coler
  • Dell Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 14, 2013
IB4G2008
  • 3587 Answers
SOURCE: pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Posted on Feb 15, 2008
  • 51 Answers
SOURCE: Yellow Light Blinking-Tower Will Not Turn On
This is a sign that your memory has failed. You need to install a new memory card. go to Tigerdirect.com for good prices on memory cards.
Posted on Mar 15, 2009
  • 190 Answers
SOURCE: Scaleo P Does not Start up, No Fan, No Boot Up Nothing at All
something is shorted or PSU has failed
make sure cards are seated down (with power cord out)
try if works ;) your good
if not next step is cord out an remove power and cable off the CDROM drive
try it, just go through all hardware till it starts
to determin what failed, if still same no boot then PSU has died
Posted on Apr 16, 2009
  • 3 Answers
SOURCE: Number 3 and 4 on front of the PC are flashing and
3 and 4 for that model correspond to a memory issue. There is possibly a chip that has come loose or has gone bad and needs to be replaced.
Posted on Dec 11, 2009
  • 561 Answers
SOURCE: solid amber light ON Dell Inspiron 530 desktop.The
Hi
Please try the following
1) Remove ALL wires from thw back of the PC
2) Press and hold the power button on for approx 15 seconds
3) Replug only the mains power wire and the monitor cable and then retest
Please advise of outcome
I hope this has been useful
Posted on Mar 05, 2010
Stop computer feom going into power save mode by itself.
You should be able to stop this by going into the control panel, select power options and change the settings for the hdd, sleep etc.
Just set them to 0 and that should stop it powering off.
May 22, 2014 | Dell OptiPlex GX260 PC Desktop
When pushing the power button on the tower, the power lights on the tower, mouse, and keyboard continually flash, and the computer does not actually turn on. The only way for the flashing to stop is by...
The power supply is receiving power from the source but is unable to properly distribute it to the components. This means that either your power supply is bad or the motherboard. Try removing all devices attached to your computer and check your USB ports to see if they are damaged.
Jan 09, 2011 | Dell Dimension 2400 PC Desktop
Just hooked up my pc yesterday worked fine. I shut down by going to start & turn off computor. Came back later to start back up. Monitor tells me in power safe mode. Tower doesn't seem to be starting...
You can try removing external devices like (ex. usb printer, external Hard drive) and try to start the computer again. And see if there are lights on the tower
Hope this helps
Jan 03, 2010 | Dell E173FP 17" LCD Monitor
My Dell xps 400 will not boot up completely, then won't power off
It sounds like the machine is experiencing hardware problems. You will either need to call Dell or take it into a local computer repair place.
Nov 16, 2009 | Dell Dimension XPS PC Desktop
Dell vista will not boot up
Typically, it's a memory problem. If you have multiple memory modules, leave one in the CPU at a time and boot your system todetermine which module is bad. Good luck.
Jun 27, 2009 | Dell Dimension 4550 PC Desktop
Dell dimension 8400
IT MEANS that the processor is not getting cooled enough, try turning on the comptuer with the side panel open, dont reseat the cooling tower, however also check for the four lights on the back of the tower and post the same,,
Jan 25, 2009 | Dell Dimension 8400 PC Desktop
Dell XPS 400 tower does not power up monitor?
The “self test” on the monitor displays when not plugged into a computer. This means that it’s working. The LED error code 2 and 4 means the video subsystem has a problem. Either your video card is bad or bad memory module. Try reseating video card and/or memory.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 26, 2008 | Dell XPS 200 PC Desktop
Computers & Internet Logo
29 people viewed this question
Alun Cox
