Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch she43f16uc replace control panel
2 Suggested Answers
  • 3247 Answers
SOURCE: bought a Bosch floor model she43f16uc/56 no
Try this installation guide for location of hoses.
Posted on Aug 07, 2011
Bosch SHE55M16UC/64 Dishwasher replacing control panel fascia or cover. How to remove chrome handle cover from old part and reinstall it?
You will have to take the door apart. Be very careful not to break any clips. The screws for the handle are on the inside of the door.
Mar 13, 2014 | Bosch Dishwashers
I have a Bosch model number she43m02uc/50... I need to replace the buttons but cant figure out how to do it myself and disassemble the panel.
Hi.
To remove the control panel on the machine there are a total of 6 screws holding it on. Four screws across the top of the inside of the door and 2 more on the sides.
Once you have removed all the wire connecting plugs from the control unit you should lay the control panel on a towel face down to work on the four clips holding the metal frame onto the plastic control panel. Be careful not to break these clips as they are delicate. Don't force them to move more than they need to disengage. Once the steel frame is removed out of the plastic control panel you should have access to the plastic buttons to replace them.
Regards Sam
Sep 30, 2013 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch SHX99A15UC went completely dead. Circuit
no it wouldn't, this is a common failure on bosch dishwashers. you have either a bad control or a bad touch membrane. parts are fairly expensive and only way to know for sure is to replace one. I usually find that the control panel is at fault most times
Apr 23, 2010 | Bosch 24 in. SHX99A15UC Stainless Steel...
Bosch dishwasher shu43c07uc/14 dead
Control is available.
There was a recall on control modual because of fire dangers.
Call and get an auth number from Bosch 800 856-9226
Apr 20, 2010 | Bosch Dishwashers
How do you remove front panel on a Bosch WFO285SGB
This video will show you how to replace the Bosch WFO285SGB washing machine door seal with step by step guide on the process
Aug 13, 2009 | Bosch Washing Machines
Bosch HBN745AUC control panel broken and needs to be replaced. Any DIY advise appreciate, included the parts no. and cost information.
If you mean the glass in front of the display and touch panel is smashed, you can buy a new glass panel, about $200, part 239424 (for a stainless oven), see bosch parts link below. Probably the electronic touch sensor board underneath is fine, but its basically glued to the glass panel so will be a bit tricky to peel off and re-glue to the new one.
http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=HBL745AUC%2f02&ESHOPTYPE=S
Jul 12, 2009 | Bosch HBL 745 Stainless Steel Electric...
2H displayed and pump runs nothing else happens
I would check the buttons on the control they may stuck. check the delay button..
Dec 21, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Dishwasher SGS43E02 Exxcel Control/Display Facia Panel
The panel is replaceable by removing the #20 torx screws inside the door. Once removed the metal outer door cover will slide down and the plastic top housing less switch panel can be unclipped from two locking tabs on either side. You can order via BOSCH service center, check to see if it is warrantied before removing
Feb 06, 2008 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
27 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
