I have workaround for the empty tank issue: - buy or borrow another not empty tank - place it in - start the printer - it recognises the "new" tank - turn off the printer - put back the old, empty, but refilled tank - turn on the printer - print something - it will pop up a dialogue window saying "The ink level of the black/color tank cannot be determined. The ink level determining function will be disabled for the black/color tank. If you want to continue printing without this function press the Start button on the printer." - Press the Start button on the printer and ignore the button 'Cancel Printing' appearing on the dialogue window. - The dialog window disappears.
You can print your refilled tank as many times you want from this time.
When
you go to 'Printers /Canon /Properties /Maintenance / Printer Status /
Ink Information' it says that the ink level measuring function has been
disabled for: black [40] / color[41]. You can ignore this this message,
the printer will work perfectly without this stupid function.
1) Select Print from the file menu, on the page you want to print.
2) When the HP Officejet Pro L75XX Document Properties Box opens select advanced from the tabs at the top.
3) Open the tree under "Printer Functions" or if its already open select "Mirror image" and toggle the on/off selector to turn on the Mirror image function. You are done!
4) Return to the Printing Shortcuts tab to complete your selections for this print project.
Note: Remember to reset this function to Off so you don't waste a lot of paper printing something you can't use...
Press the Rcpt/PO key in the OP X/Z position. This key toggles the receipt printing status ON andOFF.
To check the receipt printing status, turn the mode switch to the OP X/Z position or press the CL key in the REG mode.
When the function is in the OFF mode, the receipt off indicator “_” illuminates.
To issue a receipt when receipt ON/OFF function is set to OFF: If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function in the OFF mode, press the RCPT/PO key. This will produce a receipt. If more than 50 items were entered, the receipt will be issued in a summary receipt format. Your register can also print a copy receipt when the receipt ON/OFF function is in the “ON” status.
Some printers have a function to print in reverse for special purposes (glue-on prints, iron-over-a-white-t-shirt-and-get-it-decorated, and so on).
Apparently this function got switched on in your printer's Properties page, so you'll have to turn it off from there. It is usually called "Mirror" and is either on the Advanced Function tab or the Print Layout tab. I don't have an Officejet handy now, but on my Ricoh I have "Mirror Output" in Properties -> Advanced. Postscript printers have it under Advanced PS.
The following is the process to stop customer receipt printing. It will also describe how to print an individual receipt on demand. Best of luck and thank you for using Fixya! Kindly return to rate this solution. Greg
Receipt ON/OFF function
You can disable receipt printing in the REG mode to save paper using the receipt ON/OFF function. To disable receipt printing, press the Rkey in the OP X/Z position. This key toggles the receipt printing status ON and OFF. To check the receipt printing status, turn the mode switch to the OP X/Z position or press the lkey in the REG mode. When the function is in the OFF mode, the receipt off indicator “_” illuminates. The register will print reports regardless of the receipt state, so the paper roll must be installed. "To issue a receipt when receipt ON/OFF function is set to OFF: If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function in the OFF mode, press the Rkey. This will produce a receipt. If more than 50 items were entered, the receipt will be issued in a summary receipt format. Your register can also print a copy receipt when the receipt ON/OFF function is in the “ON” status."
The following is the method to turn the receipt printing on/off: Receipt ON/OFF function You can disable receipt printing in the REG mode to save paper using the receipt ON/OFF function. To disable receipt printing, press the Rkey in the OP X/Z position. This key toggles the receipt printing status ON and OFF. To check the receipt printing status, turn the mode switch to the OP X/Z position or press the lkey in the REG mode. When the function is in the OFF mode, the receipt off indicator “_” illuminates. The register will print reports regardless of the receipt state, so the paper roll must be installed. To issue a receipt when receipt ON/OFF function is set to OFF: If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function in the OFF mode, press the Rkey. This will produce a receipt. If more than 50 items were entered, the receipt will be issued in a summary receipt format. Your register can also print a copy receipt when the receipt ON/OFF function is in the “ON” status.
Hi cherycooney,
Press the '2nd' button, press the 'M+' button. 'NP' should appear on the display screen, and print function will be turned off. Thanks for using Fixya.
I believe this might help, not exactly familiar with this exact model but here it goes.
When you use the printer to issue receipts, you can disable receipt printing in the REG mode to save paper
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function being OFF
status, press the Rkey. This will produce a receipt. However, if more than 30 items were entered, the
receipt will be issued in a summary receipt.
Copy receipt
You can print a copy receipt by pressing the Rkey when the receipt ON/OFF function is in the “ON” status.
To realize this function, you must enable the function. Please refer to page 62 (Job code 63).
Please perform the following steps to ensure your printer is physically functioning.
1. Turn the printer off and disconnect the interface cable. 2. Load plain, single part tractor paper into the printer. 3. Press the LOAD/EJECT button while turning on the printer.
NOTE: The self test prints over several pages. After the first or second page has printed, press PAUSE and turn the printer off.
If this self test prints correctly, then the printer hardware is functioning correctly.
>Try printing from other applications. >Check cables as they can cause communication errors. >Re-install the driver. >Go to support.epson.com for more information & documentation.
