Question about Stoves Ovens
How do you take the infinte switch cover off on a JDS26GOT1AD ge slide in ? Stove
Its an old one 27 inch wide
2 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Replacing a 30 inch wall oven -
a number of solutions for your problem a little smaller better then a little larger, iv seen depending on surrounding cabinetry, either wood fill strips, lexan(plastic) strip added as a filler. depending on what the installation guide recommends for opening , that is all that would be required what you fill if with will be a purely asthetic choice
Posted on Nov 13, 2008
Where can I get a heat resistance double sided tape to affix the external glass of the oven to the SS frame on my slide in GE stove .
Most of the time that GE attaches any type glass to hot metal these days they use silicone seal. It is uses to attach glass cooktops into the metal frame of the cooktop. Get a tube of GE clear silicone seal and glue the glass around the complete edge getting a good seal and contact at the glass edge and metal panel. Let it dry 24 hrs before reassemble. The silicone seal turns to rubber when dry and is quite heat resistant. It won't stand up to direct flame but should hold your glass well.
Apr 27, 2015 | GE Ovens
We have unplugged the stove but as soon as we plug it back oven stays on and will not cutoff
not sure what u mean by check ur infinte switch and or oven clock setting
Mar 09, 2015 | Ovens
Where can I find an electric range with depth less than 28 inches
Bertha, most stoves are going to be anywhere from 26" deep to 29" deep. Most any stove that I have used or worked on has never been a counter depth stove unless it was a slide in or a drop in stove. When I went to GE's website, I did not many stoves that were less than 28" deep until I got up to $1000 in retail pricing. The only one under that price that was less than 28" was also only 24" in width. Hope this helps!
Dec 08, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
The gas in the oven goes on then off
follow this instruction. God bless you
    • 1
      Unplug your unit and turn off the gas supply at the saddle valve near the unit.
    • 2
      Lift up the hood of the oven. If you have sealed burners, the lid will not lift up. Locate the ignitors near the burners of the unit. Clean any gunk away from the ignitor using a toothbrush. Test the unit.
    • Sponsored Links
    • 3
      Pull the burner dials off the front of the unit if the ignitors won't work.
    • 4
      Remove the screws at the ends of the front cover, where the gas supply knobs are located, using a screwdriver, and remove the cover from the oven.
    • 5
      Slide the wires off the burner valve switches and pull them off the burner valve by sliding the switch forward. The switch will have wires attached to it. Loosen the screws holding down the wires of the burner valve. Pull out the wires carefully. Place the wires in a new switch. Slide the new switch onto the burner valve. Replace the knob, and turn on the gas supply and power. Ignite the burner.
    • 6
      Follow the switch wires into the oven if the new switch doesn't work. Locate the module box, which is usually 2 inches by 3 inches. Slide the wires out of the module terminal by pulling on the wire connectors. Remove the screws from the old module and pull the module out. Insert the wires into the new module, using the same wire orientation as before. Reassemble the oven. Turn on the electricity and gas, and turn on the burner.
Read more: http://www.ehow.com/how_7925141_repair-electronic-ignition-gas-stove.html#ixzz2ZPuc5nad
Jul 18, 2013 | Ovens
How to remove the touchpad on ge profile stove, I have f7 code
On most GE ovens you open the door and across the bottom of the control panel there are 3 1/4 inch screws, one in the center and 2 on either end going straight up into the console. remove the screws and slide the control panel up then out to you. Thats how you do it.
Aug 28, 2011 | GE Profile JTP18 Electric Single Oven
When trying to heat oven up the "F-3" flashes The stove is almost 19 yrs old Model: JGSP30GER1BG
Your oven temperature sensor located on the rear wall of the oven has failed and must be replaced.
It is about 4 inches long,silver colored metal and smaller than the diameter of a pencil.
Apr 15, 2011 | GE Ovens
Burner Igniter will not Spark
No, actually each knob has its own switch and any knob will energize the spark module which sparks at all burners. So, just replace the defective switch which slides over the shaft of the gas valve. Careful! unplug the unit, these are 120 volt switches. Good luck.
Jan 12, 2010 | GE Ovens
Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Jun 18, 2009 | GE Profile JT912 Electric Single Oven
Nov 13, 2008 | GE Ovens
Ovens Logo
16 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
