I need an owners manual for a RUUD UBHB Series Air Handler and RUUD air conditioner UPNJ series. I can't find any online. Thanks!
I can't find UBHB series--is it now UBHC?
  • 20 Answers
SOURCE: Wiring Diagram
here is a basic wiring diagram for all air cond systems your thermostat consist of treminal r w y and c run a four conductor wire fromm thermostat to ai handler the air handler should allso have eather have red blue white wires or a teminal block marked r w c r stands for red w for white c for comon allso blue run color for color from the thermostat to ai handler with exeption of yellow yellow runs straigth to condenserand retuns in white wire to air handler wich gets conected to comon hope this help[s you
Posted on Jul 23, 2008
  • 20 Answers
SOURCE: Old Ruud Air Conditioner
all heat pumps follow the same schematics universal get a hold of any heat pump schem and you should be able to aplie it to yours
  • 4 Answers
SOURCE: How do I change the filter in my Ruud Achiever series
I'd look in one of 2 areas.
1. often there is a central return in the house. This is the place where the air gets pulled back to the unit and is likely very close to your thermostat. Check for a filtered louvered grill there and see if your filter is located here. If so, you can access the filter by opening the filter frame with a screwdriver or even a coin.
2. Otherwise I would expect that your filter is on the return-air side of your air handler (where the blower is) Older models have the filter actually inside the air handler in the blower compartment. Newer models may have a small separate filter door. I'd look in these areas.
hope this helps
ghoff
Posted on Mar 21, 2009
manhandy
  • 146 Answers
SOURCE: What air filter size fits a Ruud model UBHC
well go to the forced air unite and open up the fan compartment and measure the size. or find out the air returns and there should be filter in there.
Posted on Jul 13, 2009
pilungu
  • 30 Answers
SOURCE: Air Conditioner (RUUD model: UBHC-14J06NFD) is
1) you probably have a clogged drain line and
2) your air handler coil may be dirt.
Solutions:
1) Using a dry/wet vacuum cleaner, attach it to the drain line outside and **** all the gunk out of a drain line; or using a water hose, attach it to from inside right by the air handler and push the gunk out with the force of water - be careful using this method. Or simply pour draino into the air handler pan, wait for 10 minutes and using a cup pour water in the pan to see if it drains fine.
2) if the coil is dirt and it ices up, call a technician to for coil cleaning.
Posted on Oct 12, 2009
I need exact replacement ac air handler Weather King model RCBA4882GH21...4 ton 10 kw elec heat with the I need to replace my Weather King ac air handler unit...4 ton, W shape evap coil ,elec...
What's wrong with your current AHU? Any Ruud dealer can assist you. Most 4 ton units work with r-22 or 410a. As a side note, most parts in an air handler can be replaced unless the case is rusted thru.
Sep 24, 2013 | Rheem Air Handler 4 Ton With Rhplhm Series
My system uses a permenant air filter. It's missing. It's a Ruud Model UBHC-21J18SHG. What size filter should I put in this system?
The Ruud UBHC-21J18SHG has a nominally 21" cabinet width. So the needed filter is 19.75" x 21" x 0.375" (502 mm x 533 mm x 9.525 mm). The Ruud part number for the filter is 54-23217-03 .
The specifications sheet for the Ruud UBHC series air handlers is available here: http://www.coburns.com/images/PDFs/h22-517rev1.pdf . The filter size information is on page 3 and page 12.
I've found the filter at one online vendor: http://www.patriot-supply.com/products/showitem.cfm/RHEEM_68_101807_03 . (This is a common filter that fits several manufacturer's air handlers.)
I hope this helps.
Sep 10, 2011 | Ruud UBHC Air Conditioner
I am requesting an owners manual for My recently installed Ruud Air Handler unit Model # RHPN-HM3624JC Thank You
The right path for getting this manual is from the installers as it is a requirement by law for this to be left with the home owner. Is it a new unit ? If not then there is a couple sources for manuals. Such as calling RUUD customer support. contact info at at www.ruud.com
Aug 18, 2010 | Ruud Heating & Cooling
Air Handler leaking
First make sure unit is level. Drain pan may be dirty. On the rheem or Ruud unit the back of the pan gets stopped up. Ithas small holes that let the water by and they get stopped up. Now even though your drain is clean you may have a stopped up dain pan. Check this > These are problems you can take care of your self. Open up the top panel of your unit and you can look down on the drain pan. Check for dirt and stoppage near the outlet of the drain pan. You amy also have a cracked drain pan but I doubt it. Rus
Jul 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
hope this helps
ghoff
Feb 21, 2009 | Ruud UBHC Air Conditioner
Need to find ac coils for RUUD ac in the Air Handler
follow the copper lines coming into the air handler.1 will be large and insulated and the other smaller and uninsulated.They attach to your evap coil.
Aug 18, 2008 | Ruud UBHC Air Conditioner
Ruud RKKA Series Split Unit
the pressure switch has to pull in for the gas valve to be powered so check switch and venting
Apr 02, 2008 | Ruud Handler Air Conditioner
Wiring Diagram
Sep 02, 2007 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
