Question about GE Spectra JBP78 Electric Kitchen Range
I have a spectra gas range and 2 ignitions does not spark.
Is it difficult to replace the two bad ignititions?
How do I lift the top of the stove to get at the ignition switches?
    Sergeant:
    Champion:
  • 338 Answers
The easiest way to explain it would be to goto partsdirect.com and type in your model number that usually gives a very descriptive picture
Posted on Jan 24, 2009
The gas range spark igniter does not work. I have a new part. How do I access the range top to replace it?
The whole top of the stove lifts off. You need to pull it out from the wall, unhook the gas, loosen and remove any screws that are on the back that hold the back to the top section. Open the stove doors and look up from the bottom to see if there are screws holding the top down, take those out and lift the top off. You can then access all the parts for the burners.
Oct 31, 2014 | Kitchen Ranges
GAS COMES ON BUT STOVE WILL NOT IGNITE
check the pilot with the stove off lift the top see it there is a little fire between both burners or you might have a bad igniter
Sep 22, 2012 | Five Star Kitchen Ranges
I smell gas and my burners wont light - is there a pilot light in these ranges?
The best way to find out if if your stove has a pilot light, is to lift the top panel of the range . The pilot will usually be located between the burners. Typically you will have two pilots. One for the left and one for the right. The pilot light will ignite with a match without having to turn the burner knobs to the "on" position. Good luck
May 20, 2010 | GE Spectra JGBP35 Gas Kitchen Range
One of my gas burners won't start
Only 2 potential culprits in this case.
The Control Valve (behind the control knob) is bad... or the gas outlet on top of the stove is clogged with food :D
Take it apart and give it a good cleaning or replace.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 29, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove Ignitor makes tik tik sound and the sparks continuously
may be a loose wire on the spark ignitor ceramic or if you run via main electic it may be your spark generator
May 14, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven won't work on gas with electric ignition stove
The glow bar for the bake burner is bad, needs to be replaced. Remove oven bottom to get to it, and also the utility drawer.
Feb 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
None of my igniters on my gas ge stove no clicking no lighting
the spark ignition module, needs replacing, it's call a spark module,many times is behind the stove.
Dec 11, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge gas kitchen range 2 igniters work and 2 don't
Lift top upward & look under, you'll probably see small wire(s) running to ingnitors, see if perhaps wire fell off side not working.
Dec 10, 2008 | GE Profile Spectra JGBP85 Gas Kitchen...
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra JBP78 Electric Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
