Question about Brother HL Office Equipment & Supplies
Brother printer not printing dark enough - HL Brother Office Equipment & Supplies
SOURCE: Toner issues
If you are using generic toner it might be a big problem, if original try changing the developer assy.
Posted on Jan 27, 2009
rtrahan
  • 741 Answers
SOURCE: my hp 1200 printer is not printing dark enough.
If you have installed the toner cartridge correctly then it is a hardware problem called the Fuser and is the most common problem with printers...the fuser is a part of the printer which actually melts the toner onto the paper. The fuser has to get up to a high enough temperature to be able to melt the toner, if it is malfunctioning then it cannot give you a dark print. You may search google for Fuser information: Recommendation is change out fuser to repair problem. Pls rate this solution.
Posted on Apr 20, 2009
  • 1550 Answers
SOURCE: printer not printing dark enough
go to the print settings select the dark scale
u can get print darker than the previous
Posted on May 27, 2009
pineworks
  • 4041 Answers
SOURCE: the black print is not dark enough
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on May 08, 2010
  • 1456 Answers
SOURCE: Brother laser printer MFC9840CDW prints
Hello
Did you replace only the cylindrical drum?or the whole drum unit as sold by Brother.(replacing the whole drum unit is as good as buying a new printer).
clean out the drum unit thoroughly, except for the transfer roller. The instructions say don't vacuum that unless you have a "Statically grounded Vacuum cleaner"
Also if the drum is exposed to light for too long you will get that grey sheen on pages printed. Usually keeping the drum unit in the machine overnight will correct the problem.If that doesn't fix the problem then i believe you might need a new toner.
Over time, apparently some sort of electrical charge develops in the "waste section" of the toner cartridge. This leads to the remaining toner being inappropriately deposited onto the page resulting in the grey background.
If you keep printing with an empty toner, then the background is getting darker and darker. Then it's possible that you damage your drum-unit.
So change your toner and clean the drum-unit.
Posted on Apr 23, 2011
Printer prints dark pages
Sir/Madam
I suggest You Go to Official Brother Printer trouble Page For You Brother Printer Problem On Below Brother Printer forum URL Link:
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/002900/000044/faq002944_000.html?reg=eu&c=eu_ot&lang=en&prod=mfc297c_eu
I Hope You resolve Your Brother Printer Issue,
OR
In case You Need Online Assistance Then follow Us For ON:
Brother Printer Support
Jan 31, 2014 | Brother MFC-7340 All-In-One Laser Printer
Copier will not print dark enough even with new cartridge
Your laser module is dirt, disassemble laser module and clean dirt with cloth and alcohol.
May 20, 2011 | Brother Office Equipment & Supplies
BROTHER MFC-8860DN EVERY TIME I PRINT TWO DARK LINES PRINT ON EACH SIDE OF THE PAPER?
I had a similar problem but it was only one dark line on the right side of each page. I just changed the drum while keeping the same toner and the problem is gone.
Dec 11, 2009 | Brother MFC-8860DN All-In-One Laser...
When printing with my Brother MFC, the pages are dark.
Did you change the toner cartridge with a new genuine oem cartridge?
Do a report print <settings> page from the menu and check the 'Drum life' Bar graph. If close to, or at 0%, get a new Drum unit
Dec 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
Zebra Z4MPlus not printing dark enough
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
Sep 30, 2009 | Zebra Z4Mplus Label Printer
Printer not printing dark enough
May 27, 2009 | Samsung CLX 3160fn All-In-One Printer
My hp 1200 printer is not printing dark enough. this problem just started/ I can barely read the print. MY hp 1200 printer is not printing dark enough I installed a new toner cartage but it still does the...
Apr 20, 2009 | HP LaserJet 1200 Printer
Toner prints to dark
hi!!!!!
try to re-install the driver of your printer!!!
or try to figureout the settings of your printer
Oct 29, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother HL 1440 Printer Density Adjustment
For sure u can increase the darkness and there are settings to increase but u need to browse through the menu to locate the darkness increasing options. The mannual should definitely help.
Thanks
Feb 08, 2008 | Brother HL 1440 Laser Printer
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
