Question about Koiiler Car Audio & Video
Koiiler xm7605 dial readings - Koiiler Car Audio & Video
I have a koiiler xm-8787 1000w amp. the problem is when i hook everything up correctly, the dual 10 inch sub make a repeating papapapapapapa none stop and doesn't produce bass. could it be the amp is...
I HAVE THE SAME AMP IN MY CAR RIGHT NOW ! THATS NOT NORMAL THATS FORSURE THERE SHOULD BE A X-OVER SWITCH ON THE SIDE OF IT SWITCH IT T0 LPF (LOW PASS) THERE SHOULD BE A DIEAL LABELED THE SAME THING ADJUST IT TI 75% TURN YOUR BASS BOOST TO 25% AND THE LEVEL SWITCH TO 25% THE HPF DIAL WONT WORK UNLESS YOU SWITCH YOUR X-OVER TO HPF BUT YOU DONT WANT THAT, THAT HAS TO DO WITH THE VOICE3 COILS IN THE SPEAKER THATS PROBABLY YOUR PROBLEM! YOU WANT TO RUN YOUR SPEAKERS WIRES PARRALLEL WITH A DOUL VOICE COIL SPEAKER IT SHOULD HAVE FOUR TERMANALS ON IT RUN YOUR NEGATIVES TOGETHER THEN RUN YOUR POSSITIVES TOGETHER AND SEE IF THAT WORKS! GOOD LUCK!!!!!
Oct 22, 2010 | Koiiler XM-6666W Car Audio Amplifier
My koiiler fuse is bad how much is one
you will want the one with the 40 printed on it
and you can get them from 1 to 5 dollars depending where you buy on the internet
Sep 27, 2010 | Koiiler XM-7676W Car Audio Amplifier
Need wire diagram koiiler xm 7676
U CAN GET ALL UR WIRE DIAGRAMS FROM PIONEER WEBSITE JUST OUT IN UR MODEL NUMBER THEN TYPE IN WIRE DIAGRAM
Feb 13, 2010 | Koiiler XM-7676W Car Audio Amplifier
Koiiler XM8787 Amp power problem
Sometimes i goes into protection when the amp is overloading with power.. Or the amp is touching metal.. Or the ground wire aint in the right place..Or check your RCA's, Speaker wires? if their earthing your amp..
Jan 13, 2010 | Koiiler XM-8787C Car Audio Amplifier
Blows fuses koiiler amp mx-8686
check your ground thoroughly make sure it is making good metal on metal contact and that there are not breaks or cracks in the outer coating. Most times amps throw fuses for that reason.
Mar 09, 2009 | Car Audio & Video
Car Audio & Video Logo
23 people viewed this question
Top Koiiler Car Audio & Video Experts
xxxxxx xxx
Are you a Koiiler Car Audio and Video Expert? Answer questions, earn points and help others
