Question about Lexmark ImageQuick SIMM (15W0000) for PC, Unix
LEXMARK PRINTER WONT PRINT
LEXMARK X5495 WONT WORK WITH CHEAP CARTRIDGES
    Habit-Forming:
    New Friend:
  • 18 Answers
If Lexmark Printer has stopped printer, there could be various reasons behind the same. It might be because of paper jamming or corrupt printer driver. To identify the cause of the lexmark printer won't print and shows error, get their easy solutions, it is important for you to contact the experts. You should dial Lexmark Support Phone Number to get in touch with them, and they will help you out with your problem.
Posted on Nov 22, 2017
    Problem Solver:
  • 5 Answers
Lexmark printers usually won't work with cartridges other than lexmark's. You should use genuine lexmark cartridges, otherwise you may experience problems.
Regards
Posted on Feb 20, 2009
The Lexmark x5495 printer is not printing correctly. The printout is not aligned properly. The printout is crooked. How can you solve this problem?
Try to re-seat your cartridges and make sure they are properly inserted in the cartridge carrier.
If that doesn't help, please do the Align Cartridges function on your printer. From the printer operator panel, while on Copy mode, press the Menu button > Tools > Maintenance > Align Cartridges. You printer will then print a test page that will help align the cartridges.
After the page is printed, try to print a document again to verify that the problem is fixed. Thanks.
Feb 25, 2012 | Lexmark X5495 Printer
Ihave a Lexmark x5495 It says left cartrage incorect Its a genuine Lexmark cartrage
It could be just a slight communication problem between your cartridge and the printer. Try to remove the left cartridge from the printer > close the printer cover > unplug / re-plug the printer into the power source to reset it > when the printer turns on, reinsert the cartridge and then close the cover. If no error appears, try to print a document to verify that the problem is fixed.
You may also try to insert your old cartridge or a different known working cartridge to determine if it's a faulty cartridge issue.
If you still need assistance, please contact Lexmark Technical Support Center.
Sep 12, 2011 | Lexmark X5495 Printer
I have a Lexmark X5495 printer, and I refilled the black cartridge. Is there any way to override the ink levels?
Once a cartridge is refilled, it can no longer report it's true ink level. Just an FYI: you might not get the print quality you expect from ink that is specially formulated by Lexmark to pass through microscopic nozzles at extremely high temperatures.
May 17, 2011 | Lexmark X5495 Printer
Lexmark X5495 printer cannot communicate with the printer, I can scan images from the same printer, but cant print. Tried to unplug the cables, restarted the systems, uninstalled and re-installed the...
If you can scan the USB port, it should be OK. If "copy" works correctly and you have recently installed drivers, try resetting your computer and selecting the printer as "default." Check if there is an impediment on the printer panel, blank cartridges or another error. The printer can scan but can not print if it has empty cartridges. Study the user manual on http://publications.lexmark.com/publications/pdfs/2007/5400-plus/v6592051_en.pdf
Nov 04, 2017 | Lexmark X5495 Printer
I own a Lexmark X5495 printer. for the past 3 days, any time I try to print, I can't b/c error messages appear on the screen and on the printer that 'Left Cartridge Incorrect'. Both cartridges are...
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . press down the cartridges to contact before it is reset back to the PC.
Sep 28, 2010 | Lexmark X5495 All-in-One &USB...
Lexmark x5495
Lexmark does not allow refilled cartridge on any of their products.
Lexmark, HP and Canon and-many other vendors use proprietary code to protect themselves against the damage of OEM inks.
All companies will void warranties.
Apr 24, 2009 | Lexmark X5495 All-in-One &USB...
Lexmark wont print with windows vista printer is
Go to lexmark.com and download the latest Vista drivers. If problem persists, contact Lexmark customer support.
Mar 03, 2009 | Lexmark X5495 Printer
Refilling Ink Cartrdige failer!
I have a Lexmark X5495 printer and I had it refilled a couple of weeks ago, suddenly i have a message that goes "Order new ink" or something and i check the cartridge but it is still full. I try restarting the printer and even the computer but the printer STILL won't let me print.
Oct 11, 2008 | Lexmark X5495 Printer
HOW TO REFILL LEXMARK X5495 PRINTER
When you try refilling your ink cartridges, you are taking chances that something may go wrong. I would search the web and purchase re-manufactured ink cartridges, which would be less expensive than the new ones from Lexmark.
http://www.ink-refills-ink.com/printer/Lexmark+X5495+Ink/15981/?src=gpsearch&gpprod=Lexmark+X5495&gptype=bulk
http://www.internet-ink.co.uk/lexmark-ink-cartridges-X5495/
Please remember to rate all users who assist you for free :)
Sep 20, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5495
Lexmark advertises the cartridges supplied with this printer as cart. #28 and #29. They claim these are nonrefillable. The refillable cartridges are #28a,29a, 34 and 35, the last two being the high yield carts. Make sure you have one of these.
Mar 29, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark ImageQuick SIMM (15W0000) for PC, Unix Logo
165 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
