Question about Runco VX-1000ci Multimedia Projector
How do i reset the lamp timer on a runco vx1000ci
Reset lamp timer
  • Anonymous Jan 31, 2009
    same
4 Suggested Answers
  • 17 Answers
SOURCE: reset lamp timer runco vx-5000
Using the remote control for your projector, turn the unit on, then select 'menu' on the remote. On the menu that pops up in the screen, select 'SERVICE', then 'DISPLAY DEVICE', then 'INSTALLATION'... once you select that, scroll over to the "RESET" under the lamp hours... this should reset it.
Here is a link to the owners manual for your unit.
http://runco.com/legacy_prods/legacy_manuals/VX4000d_5000d_manual-v3-1.pdf
Posted on Dec 09, 2008
leethedeuce
  • 4472 Answers
There is a service reset "button" located on the input panel on the bottom of the projector. This should be what you are looking for you can also download the manual at this link.
http://www.runco.com/legacy_prods/legacy_manuals/VX-5000ci-DHD_6-07-04_v2.pdf
If you need further assistance please let me know. Also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
Posted on May 07, 2009
aviral_srms
  • 1216 Answers
SOURCE: Runco vx1000ci stem. I ran the
there is nothing of sort of a system shutdown just because of not changing a bulb.either the bulb is faulty or you had undergone some sort of internal damage with your projector.
moreover did you reset the projector
It turns out when you power down the controller, unplugging it, you are not powering down the projector, which has its own power source. All you had to do is to get the projector to reset by unplugging it, waiting 10 seconds, plugging it back in.
Posted on Jul 07, 2011
The lamp does not attempt to turn on anymore on my Runco VX-1C projector. Power to the projector is good but lamp does not turn on.
I was about to chime in that you should reset the lamp hours after inserting the new bulb ... until I read that you couldn't see the menu because the bulb still doesn't turn on. Hmmm...
Have you checked all of the filters to ensure they're free of dust build-up? I'm wondering if it overheated which caused the fault.
Due to the fact that this model is out-of-production your options have become limited. I recommend at this point you give them a call:
Tech Support at 800-23-RUNCO
Jan 02, 2015 | Runco Reflection VX-1c Multimedia...
Runco picture upside down
Yes possibly because you have done a complete system reset and not a lamp hour reset so you will need to go into image or screen settings and select front view ceiling mount configuration
Apr 14, 2013 | Office Equipment & Supplies
On my runco vx101c , after changeing the old bulb to a new bulb . The runco turns on but the lamp wont turn on . Just a clicking sound from the lamp driver and 2 led light green and orange on the led...
You only want to reset if the projector doesn't turn on because it is a safety feature so the lamp does not explode. They get really hot and need to be replaced when due.
There is a reset button on the inside of the
RGB connection bay(look deep) for a reset button, hold it down until the lamp light turns blue.
If flipped over on it's back, you would see it straight down beyond the connectors. Of course this will reset to factory settings. let me hear how it goes good luck!
Mar 13, 2011 | Runco Reflection VX-1c Multimedia...
Unit not powering up. New lamp installed but
a couple of things did you reset the lamp timer? Sometimes if the panel door lamp is open or not closed you will not be able to power up. Have you tried removing the lamp and reseating it? Perhaps the fuse is blown...you will need to remove the cover and look to see. fuse should be located in the area of where you plug the power cord again you will need to remove the power cord.
Jun 02, 2010 | Runco CL-510LT Multimedia Projector
Reset lamp timer runco vx-5000
Thank you,
Lee
May 07, 2009 | Runco VX-5000ci Multimedia Projector
Nov 01, 2008 | Runco VX-5000ci Multimedia Projector
Service menu passcode for runco vx-1000d
I understand you have a VX-1000d.
You only want to reset if the projector doesn't turn on because it is a safety feature so the lamp does not explode. They get really hot and need to be replaced when due. You can buy one from the supplier or online.
Do you have the processor?
Normal 0 MicrosoftInternetExplorer4
Aug 21, 2008 | Runco Reflection VX-1c Multimedia...
Projector problem
I have a great deal of experience with that projector in particular.
The burning smell along with the circle on the screen can be one of two thing in the same general area. Both are not good.
The lamp assembly has its own dedicated cooling fans. these fans can sometimes **** in dust and insects. the lamp runs at a very high temperature and can burn those things quickly. I have often found old lamps with particles fused to the glass.
The other situation is that the lamp burned something and it got stuck to the glass somewhere in the light path.
if I remember right the projector monitors the temprature of the bulb and will shutdown if it gets too hot.
Runco is based in california and has a great turn around time on projectors. Unfortunately with Runco you would be hard pressed to find a technician that wouldn't just send it to them for repairs anyways. The major down side with Runco is that customers cannot talk directly to engineers or service men.
Locate a Runco authorized retailer in your area, check runcoes site. and give them a call to see if they cant send it to runco for you. if you cannot find one in your area call Roscor or Blair & Associates in Chicago.
May 02, 2008 | Runco CL-510LT Multimedia Projector
Runco VX-1000ci Multimedia Projector Logo
351 people viewed this question
Top Runco Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Are you a Runco Office Equipment and Supply Expert? Answer questions, earn points and help others
