Question about Xerox Office Equipment & Supplies
Xerox 6180 MFP port set up problem
Just bought Xerox 6180 MFP that has a port setting of 25 that can not be changed. I can't believe it won't allow you to change the port to 80 which is GO Daddy. Xerox tech support is clueless and only offer the solution to find a server who has port 25. I cant find one and xerox can't even suggest one, so what use is the machine. I thought I was buying the best name brand with up to date features. Any suggestion?
I have the solution. I own a Xerox 6180 MFP, and I could not send over port 25. My ISP said they weren't blocking port 25, and my web server wasn't supposed to be blocking port 25, but something in EXIM (that has something to do with email) was blocking it, WHICH CAUSED THE PROBLEM. The solution is:
For your SMTP login name and password don't enter your email address's u/p. Instead enter your website's cPanel (or whatever) u/p. For me it's the same u/p I use to log into www.yadayada.com/controlpanel to control my website. THEN choose "SMTP AUTH (Login)" as the 'email send authentication' type.
I'm still using ports 25 and 110. And I still am entering my SMTP server address as whatever I use (mail.yadayada.com). The only thing I'm really changing is the above. Other than that, follow Xerox's instructions to do it over port 25.
Oh. And for your POP3 server address, in case you don't know, don't enter mail.yadayada.com. For some reason you gotta just enter yadayada.com here (where 'yada' is your domain).
Posted on Aug 18, 2013
Connect 6180 MFP scanner to Toshiba laptop
Press the document to be scanned on the Platen glass. Press the Scan button, an Utility will appear. Select required size and resolution. Upon scanning document, save it in compatible format and attach it to email.
Jan 08, 2014 | Xerox Phaser 6180 MFP/N Letter-Size Color...
Phone line and fax machine
ou may have inadvertently changed it from "Auto Fax" to "Manul". From the Xerox knowledge base website at:
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=12,E=0000000000022752235,K=612,Sxi=13,Case=obj(18044)
Print the fax received in manual mode by:
When a fax is received, your machine sounds the ringer. Then you will hear a fax tone. Press On Hook Dial and then Start Copy/Fax. The machine prints the fax and returns to Standby Mode when the reception is completed.
To change back to "Auto Mode", follow the instructions at:
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=53,E=0000000000022752268,K=612,Sxi=14,Case=obj(18040)
Jan 07, 2014 | Xerox Office Equipment & Supplies
Xerox 6180 James at Tray 1 mpt every time!
Your lower trays are programmed incorrectly. Change the size and or the paper type back to letter and plain paper
Aug 23, 2012 | Xerox Phaser 6180N Laser Printer
ERROR 093-951
http://www.refillbros.com/en/manuals/p1643-xerox-phaser-6280-service-manual?page=199
see this page for detail and how to repair
i hope this helpfull, if you think this helpfull please rate very helpfull
thanks for using fixya
Jan 23, 2011 | Xerox Phaser 6180N Laser Printer
We have hosted Exchange email and I've been tasked with getting a xerox 3635mfp to scan to email. So far no luck even though I believe I've input all the correct information.
for scanning with Xerox MFP it is convenient to use MFP TWAIN Importer (http://www.scanworkssoftware.com/twainimportermfp.aspx ) It allows scanning from Xerox MFP directly to user's workstation with secure way and without any additional efforts.
Nov 05, 2010 | Xerox Phaser 3635MFP/X Multifunction...
I have a Xerox Phaser 6180 MFP, and it keeps saying paper jam and there is no jam, what can I do?
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Sep 03, 2010 | Xerox Phaser 6110 Laser Printer
Xerox 6180 MFP N error 016-782 Windows 7 x64
did you get a solution to this problem. i have the exact same situation.
Feb 16, 2010 | Xerox Phaser 6180N Laser Printer
Xerox phaser 6180 mfp error code 133-290
Before attempting to resolve the error 133. -290, print a copy of the configuration report on the copier / fax. Use the navigation on the front panel to access the configuration menu to get the impression. Review printing to make sure it understands the network settings. This is a protection against configuration settings being lost when you troubleshoot.
Clearing Memory reset the memory of the Xerox Phaser 6180MFP, Dell 3110cn or Dell Machine 3115cn to erase the stored contents and eliminate corrupted data. Disconnect the analog line and power cord from the printer. Wait at least 10 minutes. Then reconnect the analog line and the power cord. As the machine starts, press the "All Clear" "Stop" buttons to prevent automatic printing of the status page. Check the error display panel 133 to 290 times the machine is fully initialized.
Corrupt Adjustmen
Jun 20, 2009 | Xerox 6180MFP/N Printer
Scan to email
Scan to email needs an IP address or the SMTP server name and the port. Now it depends if you use an SMTP server or are you just at home? Normaly the SMTP port is 25. The SMTP server could be the one you use in your email account as well. Something like mail.upc.ie. If you dont have a SMTP server you cant set up scan to email.
Aug 29, 2008 | Xerox Phaser 3200MFP/N Laser Printer
257 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
