Question about Lexmark Z645 InkJet Photo Printer
Printer will print test page and nothing else
Tried to print e-mail and the printer will show up on the bottom of page but nothing else
SOURCE: Can not print at all.
I found a similar error on a Vista 32-bit OS when I tried to print using notepad. There's no dot before dll.
PSW_Resdll.
I wouldn't suggest simply deleting the printer from the Control Panel's "Printers and Faxes" folder since that will still leave the printer drivers behind.
Try this instead:
1. Make sure you have the installer CD of the printer, and if not try to download it from the manufacturer's website. Make sure you choose appropriately if you're using Vista or it can cause problems. If you don't do this, Windows won't always download the proper driver for you.
2. Go to Start > Programs (or All Programs) > (Printer Brand) > Uninstall to make sure it's uninstalled, and also check it from the Add/Remove Programs (or Program Features).
3. Restart PC.
4. Use the installer CD, or downloaded installer, to reinstall printer.
5. Test printing from different programs.
If after all of these are done and you still have the same problem (unlikely, but hey, anything can happen), you need to call either the printer or computer technician. Most likely the first.
I tried this process and it printer worked fine.
Posted on Apr 05, 2009
Roop1980
  • 228 Answers
SOURCE: Vista Printer problems - Printer not printing Test page or docs
You may have to change the communication format called the "Spool format."
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark 1200 series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
If this does not help the situation, please describe any differences it does make.
Posted on May 14, 2009
  • 217 Answers
SOURCE: Error light on
Could be drum unit (imaging unit) at end of life
Posted on Mar 30, 2010
  • 10406 Answers
SOURCE: Status idle + Test page onl shows top (reddish). Rest is blank.
Check that you're not out of "blue" and/or "black" ink.
For example, no "green" on the page means that the printer did not mix "yellow" and "blue".
Also, the "rest" of the test-page should be "black", if any black ink is available.
Posted on Jul 04, 2010
  • 3278 Answers
SOURCE: When I attempt to print anything from my computer,
Hello, Corinne.
For some reason, even though your printer is seen by your wireless network, not seen by your computer.
From your responses, I was unable to tell if you have:
Removed and reinstalled the Lexmark x4650 on your computer
If you have reinstalled and are still experiencing problems, set up your wireless printer on your network again. Let me know if your don't have the setup instructions. Then, you may need to reinstall the printer on your computer.
Hope this helps.
Posted on Aug 02, 2011
My printer prints the same document over and over even though the queue has been cleared. It is not a test page, but a different document that we had tried to print when it wasn't printing initially.
In the right bottom of the computer screen you will see the printer icon. Click it open and delete the print queue. Now when you order a new doc there is nothing but the new doc to print. If this does not work then re-install the printer drivers.
Oct 29, 2013 | HP "LaserJet P2035n Printer"
Have tried printing from computer and tried printing test page from printer. both times the pages come out blank.. how do I check the toner levels in printer. thank you
The draw back of inkjet technology printers are, if it is not using quite long period of time,cartridge nozzles will dry up, result printer will act just like a printing some thing but nothing will come on paper(blank page) even ink levels are showing full.
Try to recover the both cartridges through 'clean print cartridge' process from the system,if not better consult cartridge re-filler to clean the nozzles..Replace new cartridges if above said methods are not worked out.
Nov 10, 2012 | HP PhotoSmart 7760 InkJet Printer
HP 5600 printer won't print
Is your HP printer having printing problems due to incorrect printer configuration and driver installation? For the quick tech assistance, you can also go to the Printer USA Support, which is an online directory, offering the certified HP toll-free number that is helpful to directly get in touch with the technicians and get your printer problems repaired in no time. HP Printer Tech Support Phone Number HP Printer Help
Apr 26, 2017 | HP Officejet 5610 All-In-One InkJet...
When tried to trigger print through a application error @ hp laserjet p4515n screen is displayed as ' 49.4c02 error, to continue switch off and on '. Able to take test print page from the same pc.
Did you try and print from other applications.
You say a 'test print' works.
Try printing something from e-mail or word or off the internet.
If they work then nothing is wrong with printer. It's your application.
What you have is a critical firmware error, which can be caused by invalid print commands, corrupt data, electrical 'noise', or poor cables.
I would also consider going to www.hp.com/#support and upgrading the firmware.
Feb 01, 2011 | HP Laserjet P4515n Printer
I tried to print a document from internet, there is a message on my monitor telling me that J4680 is printing, but the hardware (printer) is not doing anything. I did run the Self-Test and the printer...
go to the printer page right click on the printer icon that shows the name of your printer
and select as default porinter
if there is any docements in the que try and cancel the documents and see if it gets deleted
again select teh printer as online
and go to the properties page and try to print a test page from teh printer and it should print
and if it does not print disconnect and reconnect teh USB cable from the back of the printer
and try again to print a test page from the printer and this should resolved the problem and still if nothing happens let us know the status and we will help you further with the issue .
BEST OF LUCK
thanks
regards
Hamid
Feb 19, 2010 | HP J4680 Office Jet All-In-One Printer
HP JetDirect 500x to HP DesignJet 450c printing issues
connect the jet direct card to plotter ,press the print test button locaed on jet direct card, it will print a configuration page & locate the hardware address from that page .Then try to iunstall it using hardware mac address
i m very sure it wil resolve the issue
mail me for further information
Regards
Neeraj
neeraj1412@gmail.com
Mar 24, 2009 | HP JetDirect 500X Print Server
Printer shows color cartridge m/t
Have you replaced with original HP cartridges? HP mark is well known for sensitivity to non-original cartridges.
Jan 25, 2018 | HP PhotoSmart C3140 All-In-One InkJet...
Not working on window 2003 server as a network printer
I have had a similar issue with both laserjet 3005N and 1320N machines setup as network printers on a windows 2003 print server. Both machines install correctly and print test pages but once you push to much of a print job to it (in my case it was a 12mb pdf file) the printer stops printing and never prints again for some reason. After a quick reboot a test page will print but what gives?? Buffer issues? Not enough ram? None of this makes sense since the printer displays nothing and just stops printNo test pages or anything. I tried re-installing it and rebooting it. Nothing.
Jul 12, 2008 | HP LaserJet 1320 Printer
Trendnet TE100-P1U won't print
open the print server utility and the doc can be cancelled or deleted from there. (this is the server utility inthe toolbar at the bottom of a windows screen. failing this go to the printer shortcut and from control panel>printers> select printer and faxes>select the printer (open) >select "printer" from menu bar, pause printing,then cancel all documents. Afterthis you can delete printers that are excessivly created, or delete all of them and start again with only the one or two printers you need. even if one is for network use and the ther is direct connect. You canuse direct connect to verify proper printer operation until te100 is working properly
Mar 31, 2008 | Trendware TRENDnet TE100-P1U Print Server
Lexmark Z645 InkJet Photo Printer Logo
91 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
