Question about Spark Plugs BR4HS Plug 10/BX #3322
2006 700 classic smokes alot and is foulin up plugs
    Champion:
    Scholar:
  • 227 Answers
Change the oild more often, but you will need to rebuild the engine.
Posted on Oct 31, 2013
The smoke come alote frome the pointson pipe
White smoke in the exhaust once the car has warmed up may indicate a water leak into one of the cylinders. Pull the spark plugs and look for signs of water
Jan 15, 2014 | Cars & Trucks
Was cutting grass on my troybilt pony got real loud and shut off now wont crank just spins over replaced sparkplug and it keeps foulin out
Sounds like the plug has stripped the threads, any good machine shop will fit a heli coil ( thread insert ) in the head to restore the thread.
May 12, 2012 | Troy Garden
1982 suzuki gs850 three of the carbs have the passage plug under neath the 40 jet and the 4th one dont. well im only firing on two cylinders and the other 2 are loadin up and foulin out the plugs? and...
not certain on some of your terminology, passage plug? and 40 jet?
if you mean the syncronizing plugs, where the gauges connect too, then the missing one has the hose for the vacumn fuel tap, but this wouldnt foul 2 cylnders
1 and 4, run off one coil 2 and 3 run off the other coil, if one of those pairs is fouling it could be electrical.
Mar 17, 2011 | 1981 Suzuki GS 750 L
1996 geo Car idles a little fast but drives fine. After driving it for a couple hours. Turn off car and then back on immediately, it will only drive n reverse .with alot of smoking. Then wait around 30...
This is a classic sign of a locked torque converter and/or siezed rear brakes since the age of your car add something called no smoke to your oil it will help it also check you transmission fluid level
Dec 25, 2010 | 1987 Toyota Camry
When I plug in my 36" Zenith TV the screen stays black, a clicking and popping noise comes from the back and I smell acrid smoke like from an electrical fire. What is going on, and is it repairable?
Caution: Never power on the TV set again until this fault is retified.
It is anode arcing takes place inside the TV. Its final anod cap is arcing with neighboring surroundings. A smoke like fume along with a foulin smell will be there. It is repairable. Its Line Output Transformer [LOT] shoud be replaced with similar type and number. Before connecting the anode cap to the final anode of the picture tube, cleen the anode hole and surrounding area with some sort of cleaning solvent [we uses pure turpentine for that purpose], throughly, and wipe it out to dry out well.
Oct 16, 2010 | Zenith D32D51 32" TV
Blown head gasket or not?
check oil dip stick for water/antifreeze and radiator for oil in antifreeze but usually alot of white smoke-steam from tailpipe usually indicates head gasket blue smoke means oil black smoke carbon
Sep 29, 2009 | 1993 Acura Integra Hatchback
It smokes alot from the hood
check your raditator hoses, water pump and your thermostat. your engine could be overheating in which the radiator fluid can't get to it to cool it off.
Sep 22, 2009 | 2003 Chevrolet Impala
Car smokes alot
a few things if it hasnt started in a while it will probablyt smoke..also coilpacks are notourious in going in fords also if you see white smoke it usually means water and especially if you smell antifreezecoming out of the tail pipe could also mean youhave a blown headgasket or cracked head/block another way you can tell if gasket /head/block is blown check oil and see if there any water in the oil it will be a nasty greenish color usually denotes a blown head gasket-z
Feb 17, 2009 | 1994 Ford Escort
Fuel leaks from tailpipe,with smoke while running.
Bad injector first, or bad intake gasket, then damaged head. Good Luck contact me if you need more help. Its has to one of the above.
Dec 16, 2008 | 2001 Chevrolet Blazer
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
19 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
