Question about Canon Vixia Hf-r300 Full Hd Camcorder Hfr300
Will not record. Just purchased out of box and error that reads: cannot record check the memory card
  • 36 Answers
SOURCE: Memory Card Error
Use USB card reader&writer to retrieve the pictures directly from the card.
Posted on Dec 28, 2007
Sounds like the camera does not support SDHC. Check manual to see if this camera supports high capacity SD cards.
Posted on Mar 31, 2008
  • 51 Answers
SOURCE: Camera reading memory card error, cannot get it to work. Tried removeing the card and replacing batteries. Checked and it is not locked.
try formatting the card once on a pc and then plug it in your camera....if that does not help either, you'll have to try a different card.
Posted on May 20, 2009
t00nz
  • 4738 Answers
SOURCE: My camera keeps reading memory card error, i took
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see this.
Posted on Aug 06, 2009
Tri3mast
  • 747 Answers
SOURCE: when I press button to
Card may have been locked I'll send you a diagram so you can see beside it's faster then i can type.
The other thing is you need to format the memory card Format not delete. Each time you download pictures to the computer you need to format the memory card. Instructions to do this are in your owners manual. most likely in your set up menu.
Diagram
Posted on Jan 13, 2011
When i select the power switch to memory to use the memory card it says format error, i used the memory card using the reader it reads the card, wht is the solution, denzil_1965@yahoo.co.in
If the memory card came with the camera, I would suggest checking the little metal sensors on the memory card to be sure they are flat and in good condition.
Also, be sure the memory card is being installed correctly. Some of them go in (what I would call) sideways, and some up-side-down. If the memory card does not go into the slot easily, then try another way.
If you purchased the card separate from the camera, check to be sure it is the correct one. There are so many different options when buying memory cards. Even when they seem to look just alike, some are specific to certain cameras or types of quality and types of media you want to record on them. This determines the memory card formatting, and not all formats go with every camera. (I found that out the hard way.)
May 15, 2011 | Sony Handycam CCD-TRV40 Camcorder
My FujiFilm FinePix F47 fd has an error message that keeps saying 'Read Error' Help Please!!!
The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Thanks for using FixYa.
Jan 21, 2011 | Fuji FinePix F47fd Digital Camera
Baby Lock Embroidery Sewing Machine "ELLURE" Model ESL- Problem: Defective Embroidery Memory Card (part#35205-4) used with the "PTS BOX" and the Palette Ver 1.0 Software Program to transfer embroidery...
I had the same problem and after buying a new card, found out that you get that message if the pattern you are trying to transfer is too big. reduce the size of the pattern and see if that works
Jul 11, 2009 | Baby Lock Ellure
16G Memory Gets "Memory card Error Please Check Memory Card"
You may try to format the memory card and then try again. If needed, you can use a camera photo recovery tool to recover photos from memory card.
Card Recovery Software Free Download
Apr 10, 2009 | Panasonic DMC-TZ5 Digital Camera
SD Memory Cards to record in MPEG2
To achieve MPEG2 video performance, large amounts of data must be written to the SD Memory Card in real time. The read and write speed of the SD Memory Card may differ from manufacturer to manufacturer, so we recommend using Panasonic SD Memory Cards with the high-speed transmission rate of 10MB per second (SD Memory Cards that are 256MB* or higher have a transmission rate of 10MB per second). FINE Mode recording (High image quality 704 x 480 pixels) recording requires an SD Memory Card that is 256MB* or higher. NORM Mode recording (Normal image quality 352 x 480 pixels) recording requires an SD Memory Card that is 32MB* or higher. *Usable capacity will be less. The use of SD Memory Cards other than the ones mentioned above may result in the following error message: [This card cannot record in MPEG2 mode.]
Sep 01, 2005 | Panasonic SV-AV25 Digital Camera
SD Memory Cards
Sep 01, 2005 | Panasonic SV-AV10 e-wear Digital Camera
SD Memory Cards
Sep 01, 2005 | Panasonic SV-AS10D Digital Camera
SD Memory Cards
Sep 01, 2005 | Panasonic SV-AS10 Digital Camera
Aug 31, 2005 | Panasonic D-Snap SV-AV100 Digital Camera
Record in MPEG2
Aug 31, 2005 | Panasonic D-Snap SV-AS30 Digital Camera
Canon Vixia Hf-r300 Full Hd Camcorder Hfr300 Logo
15 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
