Question about Dmm Vision Fitness T9500 Treadmill
Diagram for Vision Fitness T9450HRT Treadmill
Want a diagram of this treadmill
maxtreadmill
  • 832 Answers
SOURCE: Just bought a 9250 vision fitness treadmill and
First Your outlet to see if power is their, then check on/off switch usually their is an internal light in the switch to show power is to the switch then check the breaker button next power switch. these are a few things to look at. Check if the safety key in place on the upper console
Posted on Feb 28, 2010
maxtreadmill
  • 832 Answers
SOURCE: my vision fitness t9450hrt stopped mid run
Use your multi meter check continuity on motor leads if you get about 1 to 1.5 ohms if not leads may have open. You may also need to do calibration if the above check a ok.
Posted on Apr 15, 2010
  • 9 Answers
SOURCE: I have a vision fitness T9450 treadmill. My wife
first thing to do is to enter the calibration mode. First remove and replace the safety key. Press and hold the elevation up and the speed down buttons until the machines beeps at you 3 times consecutively. You should also see either the model "9450" or the software code which varies from machine to machine. You should now see one of two things - "eng1" may be displayed in which case just use the elevation keys to get to "eng4" and hold enter for 3 seconds - then press start - this will calibrate your machine and confirm if there is any speed reading issues.
If your machine displays more numbers as it would on the deluxe and premier consoles of this brand then you should see the model of your treadmill at the top left. hold enter from here until "eng1" appears and the perform the steps as above. If the speed is not calculating properly during the calibration the magnet or the speed sensor may have been moved or the magnet could have gone bad - usually slowing to one speed and not changing is the sign of a bad speed sensor. If the control board had any irregular voltage it would shut down as a safety precaution.
Posted on Aug 05, 2010
vetteman3002
  • 2299 Answers
SOURCE: My Vision Fitness treadmill reads E6 when I turn
This just means that the elevation is out of range. It probably lost its signal when you moved it. The way to fix this is to recalibrate it. You can do an auto recalibration.
Posted on Nov 30, 2010
ercupa190
  • 12223 Answers
SOURCE: I have a Vision Fitness T9450 HRT everything works
Dear Sir:
Hello I hope that everything is o.k
Now I will help you, only thing is you need to know how to handle the DVOM(digital Voltimeter)
To use these instructions, you need to have a familiarity with electricity and a working knowledge of a voltage multimeter. With all of
these tests, USE EXTREME CAUTION!!! Never let the voltage ground directly to any part of the treadmill or your leads ground while you
are testing voltage.
To begin, set your volt meter to AC volts. We are going to trace the power from the wall outlet through the
treadmill to see where it ends.
With the treadmill unplugged, test the wall outlet. You should have from 115 to 125 VAC. Optimally, you will
have at least 120 VAC.
Follow the power leads from the power cord to the lead ends. With the treadmill unplugged, connect your
meter to the lead ends. Plug the treadmill in and check your reading. It should be the same as your reading
from the wall outlet.
Continue this process with the electrical system, following the leads, as they pass through, breakers, fuses,
and the like.
Where the power flow ends is where your problem is. Sometimes it will be in a bad connection, sometimes
it will be in a shorted breaker or blown fuse, at times it may be as simple as a safety switch not working
properly, or it may be a major problem with a component.
In some cases, components work in tandem (i.e.- a controller may need a signal from the console
computer to release voltage to the motor) so if you have a question concerning where voltage ends, email
us at doc@treadmilldoctor.com.
TESTING FUSES, BREAKERS, WIRING, AND SWITCHES
1) One of the most common problems with power outages is problems with fuses, breakers, wiring, or switches.
2) If your treadmill is equipped with a safety switch, set your volt meter to continuity. Touch your test leads together to make sure you
are getting a closed circuit. With the treadmill unplugged, back the leads off the safety switch, usually near the upper display computer.
With the safety key out, test the switch. It should be open. Push the safety key in. Your circuit should be closed. If this tests ok, move to
the next step.
3) While testing for voltage, you can unplug your treadmill and test the fuses, breakers, and wiring harnesses. Sometimes a breaker may
have shorted open and not tripped. Test these components individually. You want a closed circuit on all of them
instructions Things You'll Need
  • Digital multimeter or analog multimeter
  1. Using a digital multimeter
    • 1 Connect the test leads to the volt-ohmmeter. Plug the black test leads into the black jack marked "Com" or "Common" on the front of the meter. Plug the red test lead into the red jack marked "Volts/Ohms" on the front of the meter.
    • 2 Set the meter's function switch to "Ohms" and the range switch to the "R x 1" scale. If your digital multimeter is an auto ranging meter, you will not have a range switch. Instead, you'll have just a function switch because the meter will automatically select the right range for the quantity that you are measuring.
    • 3 Turn off the power and remove the fuse to be tested from the circuit. Never test a fuse for continuity while it is still connected to the circuit that it is used to protect. If the circuit still has voltage, the meter will be irreparably damaged. If the fuse is still in the circuit when tested it is possible to get a false indication that the fuse is good if the meter gets a completed circuit through other circuit components. To be safe, always remove the fuse from the circuit before testing it.
    • 4 Touch the black test probe to one end of the fuse and the red test probe to the other end of the fuse. It does not matter which probe you touch to which end because fuses are not polarized. You are checking to see if there is continuity through the fuse element. A reading of approximately 0.5 on a digital meter's LCD indicates a good fuse. Most digital meters read their own internal fuses resistance, hence 0.5 Ohms and not 0.00 Ohms. LCD readout of "O.L." indicates no continuity through the fuse. The fuse is bad and needs to be replaced
Thank you in advance, best regard. Blessing.
If you need additional Help, please contact me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Posted on Sep 28, 2011
How to fix error E9 on vision fitness T 9200 treadmill
If you wish to get some details; check the site linked here. Pull up older posts treadmill . Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 10, 2016 | Vision Fitness T9200 Treadmill
Vision fitness premier T9550
please see the chart attached. However Tight the upper and lower connector +ribbon cable inside, and clean it. Adjust the REED swtich attached diagram, clean it, and tight very well the connector.
Merry Christmas
Dec 18, 2013 | Vision Fitness - T9550 Folding Treadmill...
Vision fitness premier threadmill
see the chart attached. Tigh the upper and lower connector+ribbon cable inside, and clean it. However adjust the REED swtich see the diagram attached. , tight the connector and clean it. If your system has battery, replace by new ones with the same type, and clean the contacts spring from oxide, corrosion, and dust,
Vision Fitness T960 treadmill error code E4 I was going to recalabrat hit start could hear machine turn off
please proceed according and fix it. See the diagram for troubleshooting and see my personal TIPS for motor help.
"E04": Incline motor wrong, check if the VR of the incline motor connects well or replug it. The
mark of the DC motor and control board should be matched connected. Sometimes you also test the wires from motor and restart the treadmill
Jan 08, 2013 | Exercise & Fitness
M tf40 vision fitness treadmill wont change incline or speed only just got today
Please RUN the software calibration for easy diagnose, troubleshooting and fix it.
God bless you
Dec 18, 2012 | Vision Fitness TF40 Classic Folding...
ERROR CODE E9 VISION FITNESS TREADMILL T9200
If you wish to get some details; check the site linked here. Pull up older posts treadmill . http://electro-medical.blogspot.com/ Surf the site with patience.
May 08, 2012 | Vision Fitness T9200 Premier Treadmill
I have a vision fitness treadmill T9250 and now the console display isn't working properly. Some of the
Dear Sir:
Please see the diagram attached from REED switch, adjust, clean, and tight the connector wires very well.
2) change the batteries by new ones, use the best.clean the contact batteries.
3) tight the ribbon cable from keypad .+ tight the connector from display board vs lower board.
4) after you fix it RUN THE sofware calibration for diagnose, troubleshooting, See my personal tips for help
sincerely. God bless you
Apr 30, 2012 | Vision Fitness T9250 Deluxe Folding...
THE T9500 TREADMILL SEEMS TO SLOW DOWN AND INCREASE IN THE INCLINE ON ITS OWN.
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=AZSMLpXm-tA&feature=related
Please see this videos and make this.Finally you have very strong 2 possibilty:1)Main motor 2) Control Board motor.
see the block diagram attached, and see how the main controller board has 90% aprox function of any treadmills. sincerely. G-d bless you
ernesto cuadra
managua, nicaragua. c.a
Dec 16, 2011 | Vision Fitness T9500 Treadmill
My vision fitness t9450hrt stopped mid run yesterday and the belt wont move..the inclene still works and everything else works fine i have took the cover off checked the drive belt from the motor and it is...
Apr 15, 2010 | Dmm Vision Fitness T9500 Treadmill
Vision Fitness Treadmill belt started making noise
That model is probably at least 10 years old. They are very well made but it is long overdue for a new belt. Belts need to be replaced every 7-9 years depending on a million different factors. Whatever the noise is it's almost certainly due to the belt being old. My guess is that it's a bearing noise in the motor or the rollers. Roller bearings are cheap and easy but motor bearings are much more expensive to fix. You should find a local service person to come figure out the noise and replace the belt at that time.
Jun 24, 2017 | Exercise & Fitness
Dmm Vision Fitness T9500 Treadmill Logo
65 people viewed this question
Top Dmm Exercise & Fitness Experts
fretlessbass
fretlessbass
Level 1 Expert
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Dmm Exercise and Fitnes Expert? Answer questions, earn points and help others
