Question about Microsoft Xbox 360 S9F-00001 Wired Controller - Xbox 360
My wired controller will light up all four spots and stays lit, but wont work, i took the connecter piece that hooks into the xbox and tried it with another and had the same results. maybe a bad conne
Like i said all the lights just stay on, and pressing the sync button on the xbox does nothing for it, even though i knew it wouldnt anyways lol.
  • 13 Answers
SOURCE: I already tried it.
Get someone to press the botton the same time as you but make sure the 4 rings are flashing or doing the same as on your controller, if that does not work then hold your button down and tell them to just press it
Posted on Aug 09, 2009
SOURCE: Wireless Controller not connecting to console.
Hey guys,
I've had the same problem today. The controller wouldn't connect no matter what. The strange thing was I could still turn the console on using the controller, but afterwards it wouldn't do anything.
Now I think I found a solution, at least for my case. All I did was to remove the HDD (that thing on top of the console) and put it back in. Then I started the console again using the controller and it was instantly connected.:)
Now I just hope it stays this way.;)
Posted on Aug 11, 2008
SOURCE: Xbox 360 Wired Controller Busted
Yeah I foudn the problem. I just found out one of the wires was broken inside, right above where the controler meets the wire. It was a grayish wire, probably the one that turns it on. No wonder it would only turn on if the wire was in a certain position, it was connecting the wires! Problem solved.
Posted on Aug 19, 2008
  • 3 Answers
SOURCE: xbox 360 wireless contoller won't sync with game console
If you're using an HDMI connection between the Xbox 360 and the TV, it might be that. When using HDMI, the Xbox won't boot up until it knows what the TV is capable of displaying. Although the controller will turn the console on, it won't sync with the console -- and it's not a controller or console problem, but just a symptom of the fact that the Xbox won't get to the point where controllers will sync until it can properly communicate with the TV. I'd recommend turning off the TV and the Xbox, disconnecting the HDMI cable and re-connecting it after making sure the contacts are clean. Then turn the Xbox back on first; you'll likely to see the same behavior. Finally, turn the TV back on. With it being switched back into HDMI mode, it just might "kick-start" the Xbox into a good communication link across HDMI. Hope that helps.
Posted on Feb 23, 2009
SOURCE: Turns on but no picture or sound and the machine sounds quiet?
I was having the same problem, and what seemed to fix mine was my hard drive. I keep my 360 on it's side and it [hard drive] was falling out a little. I pushed it back in and that seemed to do the trick. Also, when I fix my red rings, I just turn the console off, unhook EVERYTHING and leave it out for a minute. Then I hook everything back in (power cord, hdmi cable, ethernet cable, and hard drive) and it usually works out ok. I'm not saying that fixes everything, but, it has for me in the past.
Posted on Jun 26, 2009
Tony Hawk ride board is not syncing with the console to connect and play the game. It the xbox connect button flashes and then when we press and hold the sync button, nothing happens.
Try to change your batteries even if they are full.
First press the Xbox Guide Button (located on the side of the skateboard) until it lights up and starts blinking. Then press the Sync button on the Xbox console so that the front lights start blinking. Now push the sync button on the skateboard (little button that is to the left of the Back button) until it starts flashing. Both the board lights and the console lights will blink twice when they are synced.
Jul 16, 2010 | Microsoft Xbox 360 Console
I have just purchased another wireless controller for the xbox 360 and do not know how to connect it.
sync the controller to the xbox :-)
press the little button on the controller (near the LT LB buttons) and with-in 2 seconds press the sync button on the front of the xbox !
pressing These will make the green lights on the controller & the xbox rotate until eventually just the first player L.E.D stays on indicating player one :-)
play & enjoy :-)
hope this helps ??
Feb 17, 2010 | Microsoft Xbox 360 Controller
What happens if you press the sync button on the vbox 360 controller and the LED button lights upbut cannot get connection to the xbox 360
There could be a problem with the Controller or the RF unit on the xbox 360 console. Try another controller to make sure its not the RF receiver inside the Xbox 360. Usually when you press the Sync button on either the Xbox or the controller the lights on the X circle should spin and then flash on number 1 and stay a steady green on both the console and the controller
Nov 02, 2009 | Microsoft Xbox 360 Wireless Controller
When trying to link wireless guitar to x-box 360 all four green connection lights come on the guitar
press the connection finder button the little black button on the **** of the guitar then press the little white button on the front of your x box if you already knew that i appologize but i tried anyway.
Jul 30, 2009 | Microsoft Xbox 360 Controller
Wii rockband drums wont sync
the wii drums dont work on the xbox 360.
Feb 28, 2009 | MTV Games Rock Band Bundle for Xbox 360
Xbox 360 freez crash problem unique
you should at least get the red lights of death. try holding in the sync button and press eject 4 times see if the lights change
Feb 24, 2009 | Microsoft Xbox 360 Console
Xbox 360 wireless controller not connecting.
it sounds like your controller keeps losing sync with the 360.
- turn them both off
- turn on the 360 with the power button on the console
- wait for it to start up, then press the sync button next to the usb flap on front.
- then press the sync button on the controller (by the recharge connection slot)
That should reset it.
Nov 13, 2008 | Microsoft Xbox 360 Wireless Controller
Xbox 360 won't recognize my controller!
If your controller is just blinking you must press the small button on your xbox and at the same time press the small button on the back of your xbox controller and the xbox will pick controller signal.
Jul 06, 2008 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 S9F-00001 Wired Controller - Xbox 360 Logo
175 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
