Question about Audiovox Energizer Lithium Batteries 2 Pack Aa Cell Lithium Battery (Energizer)
How many hours will 4 AA lithium batteries power a constant draw of 2.5 watts?
Powering a LED light strip
    Scholar:
  • 155 Answers
2.5 Watts sounds pretty high for an LED strip. If the batteries are paralled and the applied power is 1.5 Volts, then you will be pulling 1.6 amps - the batteries won't last long at all. The batteries are good for around 2500maH, (Milliamp hours). so figure you may get around 2 hours of life for the batteries.
Posted on Jan 16, 2013
  • Ryan Jan 18, 2013
    I was informed by an electrical engineer that the AA lithium batteries have apporximately 3+ volts each and if placed in series would equal 12 volts of power (3x4=12). Does this help or change the outcome?? Thank you!!
  • Bill Chestnut Jan 18, 2013
    The AA batteries are 1.5Volts each, so in series you will get 6 volts. The batteries are good for 2500 maH, and at 6 volts, you will be pulling about 0.4 amps, so figure the batteries will last about six to eight hours.
Where can I get a wiring diagram for a Porter Cable20volt battery
images for Porter Cable20volt battery wiring
Power Tools - Porter-Cable
www.portercable.com/20Volt
Get Linked with the Power and Performance of the 20V MAX* system of tools. Powered by a lithium ion battery platform which delivers the performance and ease ...
Shop PORTER-CABLE 20-Volt Max Lithium Ion Battery, 2 ...
www.lowes.com/pd_472386-79992-PCC680LP_0__?productId...
Lowe'sPORTER-CABLE 20-Volt Max 1.5-Amp Hours Power... ... PORTER-CABLE 20-VoltMax 4.0-Amp Hours... ... PORTER-CABLE 2-Pack 20-Volt Max 4-Amp Hours...Missing: diagram
Jan 20, 2016 | Porter Drills
Why doesn't it charge batteries?
Some nickel Clyde batteries have different impedance and need a certain charger to charge that battery.
If you read this web page you can see what the differences are between certain nickel batteries.
http://www.powerstream.com/NiMH.htm
They have to be from the same company that made the charger to be exactly sure that they will charge and they have to be NiMH to charge is that charger. Any lithium polymer battery will not charge in that charger as far as I can understand it.
Dec 28, 2015 | Vivitar V-Power 2 Hour Ac/Dc Charger With...
Stanley fatmax instructions
Leave it on the charges as much time you can. Even though the charger indicates that is charged after 1 - 2 hours allow it to be on it as much time as you can (even 2 days). This procedures maintains the battery to be used more times.
Nov 23, 2013 | Stanley Fat Max 10 Watt Lithium Ion LED...
Petzl Tikka switch is not working properly. Light not steady.
Would you describe the light as flickering and fading perhaps? Are you using rechargable or Lithium batteries?
Here's an excerpt from a Petzl alert put out a couple of years ago. It may shed some light on your problem..
LED light sources are susceptible to being damaged by the use of lithium batteries due to the different characteristics of lithium batteries in discharge. This has meant that some people have had problems with their headtorches failing when using such batteries... Petzl have reported this problem and other manufacturers are expected to follow suit. However this does not affect all head torches...
There are problems being reported over the LED lamps in certain headtorches when used with lithium batteries. Incandescent bulbs will also suffer a reduced burn-time when used with lithium batteries although this is less severe.
This is because the lithium batteries have a higher output during discharge.
The benefits of a lithium battery are the increased burn time, especially at low temperatures over the traditional alkaline batery.
LR6 or AA and LR03 or AAA are the two size of battery litkely to be used in a headlamp.
Petzl are one of the few manufacturers to advise on this at the moment. Other manufacturers products will also be affected.
The following Petzl headlamps should not be used with lithium batteries:
  • TIKKA / ZIPKA range: TIKKINA / TIKKA / ZIPKA / TACTIKKA / TIKKA PLUS / ZIPKA PLUS / TACTIKKA PLUS / TIKKA XP / TACTIKKA XP / TIKKA XP ATEX / TIKKA XP HAZLOC.
  • MYO range: MYOLITE 3 / MYO 3 noir / MYO XP.
  • DUO range: DUO LED 5.
  • SAXO AQUA.
  • MYOBELT 3
  • DUO LED 3.
  • Oct 12, 2009 | Petzl Tikka Plus
    The led on my lxa 600 watt amp in my dodge magnum
    If the light is all that is on then it will be fine. It would take days to weeks for it to kill todays car batteries. If the amp is drawing more power than just that though, I would move the remote wire to the ignition or the headunit, because the fusebox is getting constant power to tell the amp to stay on.
    Oct 10, 2009 | Car Audio & Video
    I am looking at the same problem/solution
    Ok, Heres the deal. A gel cell battery is 7.2 Ampere hrs, so to get 14,4 Ampere hours you would need two batteries connected in parallel. A F&P machine such as mine consumes around 60 Watts of power. Using Ohms law we get W= IxE or Watts = volts X amps[or amperes = watts / volts] so that a 60 Watt machine has a current draw of 60/110< =0.55A so that a 14.4 A/hr battery will run this machine for around 20hrs (allowing a residual charge of 25%)
    Jun 23, 2009 | Duracell Standby Power Plug 400 Watt...
    LED Light on or off indicator
    on my charger the red lights are only to tell there is power connecting especially when you have two battery's behind each other on the bottom of my charger there is a guide as to how long you should charge each battery as to size which are aaa 7hours max
    aa 24hours
    c 24hours
    d 24hours
    9v 24hours
    hope this helps glenn............
    Nov 20, 2008 | Duracell AAA NiMH Battery Charger with 4...
    Type of batteries
    You can use two LB-01E 3V lithium batteries, four B-01 4PE AA Ni-MH batteries (BU-40SU charger and batteries), four AA Ni-CD batteries, four AA Alkaline batteries the B-10LPB Lithium Polymer Battery or the New B-12LPB Lithium Polymer Battery . Please note: the B-10LPB Lithium Polymer Battery, B-HLD10 Power Battery Holder and the B-20LPCE charger are included in the B-30 LBS kit, and the B-12LPB Lithium Polymer Battery, B-HLD10 Power Battery Holder and the B-20LPCE charger are included in the B-32 LBS kit.
    Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
    Audiovox Energizer Lithium Batteries 2 Pack Aa Cell Lithium Battery (Energizer) Logo
    66 people viewed this question
    Top Audiovox Camping, Backpacking & Hiking Experts
    Tom Chichester
    ray gallant
    Are you an Audiovox Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
