Question about Toshiba 57HX81 57" Rear Projection Television
Rolling lines from bottom to top on Toshiba 57hx81
Hello! I have a Toshiba 57hx81 and recently began having problems with it. At all times when tv is on, there are lines that roll from bottom to top, sometimes slowly, sometimes fast. The lines are seperated about 2 feet, always seperated the same distance. I thought I might have been getting intereference from something but couldnt eliminate a possible source. This is happening when I watch both cable and dvd's. Thanks, Mike
Hyper module out, picture become spuratic, due to frequency
drift in tuner sub assy. , module 23148024 , needs new
capacitors, 10mfd X 16 vdc....problem is! this module is no longer available, so if you can find a source great!.. expect to
dish out $230.00 + for part, not unless your an electronics guru,
and replace capacitors...AP
Posted on Nov 20, 2007
Sounds like filter cap in the main ac power supply if you can spare 100.00 you can buy a incircuit cap tester from mat electronics they work great make sure tv in not plugged in and caps are discharged get back to me
Posted on Nov 02, 2007
    Scholar:
  • 150 Answers
Mike I suppose it might be the Flex converter failing on you, you will probably want a repairman on this one, these are really complicated to work on and if there is about 5yrs of age on set it may need sent in for a rebuild on the flex.
Posted on Jul 09, 2007
SOURCE:
Toshiba 57hx81 tv has a bow at bottom of screen and blue in color tried using toush focus & got error then tried to focus manually & couldn't get the bottom lines to focus all the way down
noted in the owners manual, if auto focus returns message "error" , it suggests to use manual convergence setting..failing that, is it resonable to suspect that the STK-392-110 (convergence (2)chips)are beginning to fail, bendt horizonital lines is the effect. you can check all the resistors and pico fuses (power board)near the chips for shorts, chances are they are ok. seeing that there is somewhat of a picture (kinda like 3-d). i would repaired it!.. while your there do the hyperboard repair as well by replacing the 10 caps with [email protected] (causing a wavy vertical distortion effect).
Jan 12, 2010 | Toshiba 57HX81 57" Rear Projection...
Hello I have a Toshiba 57hx81 projection TV and one day It just went out blank screen it gets power just now sound or picture. so my question is where are the fuses located? i looked and cant seem to find...
pico fuses are located on the brown board left side after the back cover is removed. they are scattered all over that board, but are reconized by the board markings Example: F470-120v @2 amps.
check all solder jionts, a common problem
Jan 03, 2010 | Toshiba 57HX81 57" Rear Projection...
Toshiba 57hx81, has a slight squikgly line near the top of screen, colors seemed faded, not bright. i did the convergence adjustment and adjust the colors/focus with front lower right screws..Is there a...
jhinsincity: you dont need to be here, do you? the problem are the caps on the hyperboard, 10 [email protected] 10uf, rear access right hand green board, model 57hx81, the hyperboard must desoldered from main board. read the post on wavy lines,,
Dec 30, 2009 | Toshiba 57HX81 57" Rear Projection...
My 57hx81 has a slight concave bow in the middle top to bottom
Sounds like a problem in the vertical sweep circuit. Check voltages to your convergence ICs. If they are  not to spec then look for bad fuses and capacitors on the power board. These will throw off the DC voltage to the convergence chips causing the bow effect. I've had a single bad pico fuse ($1) cause this symptom.
Dec 06, 2009 | Toshiba 57HX81 57" Rear Projection...
57HX81 projection tv,color is mostly red and picture is double.
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 28, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 57HX81 is all wiggly and distorted (youtube video attached)
I don't know about that. Someone probably was rough with it and messed them up. You should have a technician look at it.
Jun 16, 2008 | Toshiba 57HX81 57" Rear Projection...
Distortion
It could be 2 things...
1. Bad filter capacitor on Verticle B+ supply.
2. Bad Screen voltage Capacitor.
Geno
Mar 18, 2008 | Toshiba 24AF41 24" TV
Convergence problem
sounds like bad solder connections on convergance ic solder then if the problem still there replac ic
Oct 24, 2006 | Toshiba 57HX81 57" Rear Projection...
Toshiba 57HX81 57" Rear Projection Television Logo
59 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
